Question about GE 17.2 cu. ft. Top Freezer Refrigerator with Factory-Installed Ice Maker
We have a leak in the back bottom of our refrigerator , ice maker
We have a leak in the back bottom of the refrigerator , it seems to come from the fill area of the ice maker .we have a 10 year old model GE top freezer refrigerator. the leak seems to come from the area wher the new copper line was attached, but it seems tight. so the leak is from some where else , but where? and is it worth having it fixed? the model number is TBX24JI .
  • 400 Answers
You say there was a new copper line attached? I assume that this means a repair has been done. If the unit has been slightly overcharged with refrigerant, this can cause excessive condensate to build up on the return copper tubing and would then drip in the back of the fridge. Or you should check on the drainpipe which often has a drainpan built either over the compressor dome or somewhere within the compressor area. Make sure the drainpipe is not missing the pan and that the pan is not leaking.
Posted on Mar 09, 2009
The freezer has an obvious leak. When we wait a few days, we can see that water leaked into the freezer and it turned into a large brick of ice? What does that mean?
Hi Monica,
This seems to be a problem with overflow of water into the ice maker, or a leak in the feeder to the ice maker. My suggestion is to turn off the ice maker by raising the lever on the unit, and see if the ice re-accumulates. This would mean that the water is leaking from the inlet, and the ice maker has no obvious fault. If you find this, you can remove the ice maker from the freezer by removing the screws holding it to the inside, unplug the unit from the back of the freezer, and pull straight out. Look at the inlet of the water at the rear of the freezer and see if there is a break in the line or a crack somewhere along it. You can replace it from the back of the refrigerator itself, going from the bottom where the water is hooked up to the top by removing the panel that guards it.
I hope this isn't too confusing.
Sep 13, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have an Electrolux EW28BS71IS and I have water dripping from the ice maker. When I take the ice maker tray out it has water sitting in the bottom of it. I can't tell if it might be overfilling the...
i have an elecolux ice maker leaks water into the bottom trays from the back of the fridge and water always drips from the front dispenser. the ice freezes in a solid block can anyone help me please. ew23bc71is3 is the model double door freezer on the bottom tks.
Mar 31, 2011 | Refrigerators
Water seems to be leaking into the freezer before it reaches the cube maker. No water outside the refrigerator so I think the leak is where is in the back of the freezer wall before reaching the cube...
Actually your evaporator drain is clogged, take your freezer back panel off. At the bottom there is a drain hole, stick a flat head screwdriver and see if there is something blocking the drain hole. You will have to defrost your fridge first. Good luck!
Aug 20, 2010 | Kenmore 21.7 cu. ft. Top Freezer...
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
Jun 29, 2010 | Maytag MSD2732GR Side by Side Refrigerator
Kenmore bottom freezer refrigerator warming up
There is a definetely leak in the cooling gas.
Firstly... You will need to find from where the gas has leaked. It is usually on the compressor pipes..... but not always.
Secondly you are right about the Water Valve... it needs to be changed.
Feb 02, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Ice building up in the bottom of the freezer
The water supply line is leaking.Put some paper towels down after you clean up and check real often to back track where leak is coming from,maybe your ice maker is over flowing with water.When was the last time you replaced your water filter?Could be backing up,just replaced mine,it was leaking under the fridge,mine is a Sear's Kenmore,ordered a filter from Sear's,Cost me 50 buck's,My filter is at the bottom front,your's may be inside the freezer.
Apr 13, 2017 | KitchenAid KBLC36FKS Bottom Freezer...
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
When ice maker is filling with water it leaks.
It could be that the dual valve(located in the bottom back of the refrigerator ) is leaking and when the ice maker calls for water there's already some in the ice maker and it'll overflow, if the valve is not leaking the ice maker module is bad and has to be replaced but it will probably cost you with parts and labor almost as a new one and you can do it yourself.To check the water valve turn off the ice maker for about a day and see if is any water in it .
Apr 28, 2009 | Kenmore 22.4 cu. ft. Bottom Freezer...
Water leaks
I have the same problem- had service man out & he replaced the ice maker- not a cheap fix, especially since the ice continues to accumulate at the bottom, then melt onto the floor.  no good answer yet---
Apr 20, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
192 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
