Question about Pioneer GM-5200T Car Audio Amplifier
I have a sony explode 4 channel 300 watt amp i took it out of the car foe a couple of weeks to make some adjustments on the car and re-wired my amp back in everything else works except the amp any suggestions please.
  • 102 Answers
Always verify the grounding circuit and trace all connecting wires back to their sources. Also verify with a voltmeter if you have 12vdc at the amp.
Posted on Mar 09, 2009
I have the Sony explode 1200 2/1 channel amp and 2 comp series lighting audio 10s 8ohm 900 watt max best way to hook up for loudest bass
You will have to wire subs together for a 4 ohm load. Then bridge amp (1 channel). Look on amp speaker outs to see what leads to use to bridge. Run positive and negative to one speaker then use a jumper wire from that positive and negative to the next speakers positive and negative
Sep 28, 2016 | Sony Car Audio & Video
Can I hook two 12in. Subs up with a 1100w amp. Sony explode, pioneer subs
Yes....hook one up to the left channel and one up to the right.....once everything is wired up.....keep gain down on amp and turn stereo on.....turn up stereo with amp gain down to right before high end speakers start to distort......then while its playing, turn amp gain up about 1/2 way. close your trunk and hop in drivers seat....sound gd????? You might have to adjust level on amp and bass on head unit to taste.....Be careful though....pioneer subs are only rated around 300 watts continuous.....dont want to blow them...gd luck....
Mar 20, 2012 | Pioneer Car Audio & Video
My stereo in 1997 chevy caviler is turning off and on when turned up to a high volume. I have a sony xplod 52 watt by 4 channel radio. With two 6x9 sony xplod 50 watt rms and 300 watt peak power in the...
Most likely cause is heat. The clearances behind the radio are often not sufficient to provde the proper air coolling that the higher power radios need. The heat sinks on the rear of the radio require a certain amount of air flow to dissipate the heat generated under high load conditions. If you add summer heat to the equation, you can have the radio going into thermal cutout to protect it circuity.
May 27, 2011 | 1997 Chevrolet Cavalier
If i have a 4 channel 2000 watt amp, can i use 1600 watt wires if i only have 2 subs hooked up to it?
Yes, you will be fine. 4 gauge power wire is sufficient for a couple of reasons, the primary one being that most of the companies that are boasting 2000 watts for a 4 channel amp are off brand "web-retail only" companies, and they severely over rate the power output of their amplifiers. Secondly the supposed 2000 watts is peak power and not rms power. Peak power means how much power that amp can put out during absolue climax of the music or during a tone burst. RMS power is how much that amp will put out continously to your speakers or in this case, your subs. If you look at the spec sheet of that amp, in all actuallity you're probably only getting 200-300 watts rms even bridged.
On a side note, if you really want to push your subs hard, you might want to consider getting a mono block or "class d" amplifier and use that 4 channel amp to push your surround speakers. Class d/mono block amps are specifically designed to push subwoofers and will give you the most efficient power out and the best heat dissipation to withstand the output required to drive subwoofers. You'll get better bass and also more adjustability to tweak the sound levels coming out of your subs. Hope that helps.
Apr 02, 2011 | Car Audio & Video
I have two 12 inch rockford p1 punches powered by an 800 watt sony explode amp (2 Channel) and i want to install another 15 inch kicker with a 1200 watt amp not sure the model, i got it from a friend and...
I have a similar setup & I just run the second amp straight off the other amp by running positive & remote wires directly from 1 amps positive & remote inputs to the others amps inputs. But my head unit has RCA inputs, (sub in & front & rear inputs) so from my 4 channel amp I run 2 6 inch alpine S's to the front to the front RCA inputs of the head unit, & 2 Pioneer 440w 6x9 inch speakers to the rear inputs. & my 800w 12 inch sub from my 2 channel amp to the sub woofer inputs on the head unit. Has blown my eardrums for nearly 12 months now great stuff! Hope this has helped
Mar 12, 2010 | Sony Car Audio & Video
How to hook it up to system with two 10s 400 watts per sub and two 6x9s at 200 watts each?,subs behind seats, 6x9s in doors. IF i need another amp i have one,to help push. But either way i need your help...
Hello www_mitzjohn,
I'd definitely use another amp.
The 2-channel Sony is well suited for powering the 6X9's but a monoblock would be better for the subs. The different types of speakers running from the same channel will not sound very good and likely it'll be impossible to get the impedances to match.
You'll want to set the Sony to send higher frequencies to the 6X9's, but not to the subs. You can't adjust the channels individually. So, just connect each 6X9 to one channel of the Sony and use a monoblock subwoofer amp for the subs.
Hope this helps.
Oct 31, 2009 | Sony XM-2150GSX Car Audio Amplifier
I have 3 hifonics zeus Size: 12 inch Impedance: Single 4 Ohms Peak Power Handling: 800 watts RMS Power Handling: 400 watts Sensitivity: 89.9 dB Aluminum Cast Basket American Spider For Reliable Performance...
Hello king3132,
Three 4 ohm subs can be wired parallel for a 1.34 ohm final load or series for a 12 ohm load. If you have the channels of the amp bridged, I hope that the subs are connected in series because the Sony XM-2200GTX is NOT rated for or stable at 1.34 ohms. It's only stable down to 4 ohms.
You definitely will not get the maximum potential of the subs from that amp. They can handle 400 watts RMS each (total 1,200 watts) and the amp is only capable of 500 watts RMS into 4 ohms (less at higher impedance), so each sub could only be getting a maximum of 166.6 watts RMS.
Hope this helps.
Jul 20, 2009 | Digital Audio Car Audio & Video
How do I fix the problem so they work again.?
A 1000 WATT AMP HAS PROBABLY GONE INTO PROTECTION MODE BECAUSE YOU ARE TRYING TO RUN 1600 WATT SUBS COMBINED
Jun 08, 2009 | Car Audio & Video
Is amp big enough for speakers
To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
Hope this helps!
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Pioneer GM-5200T Car Audio Amplifier Logo
137 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
