Question about Air Tools & Compressors
Wont kick off, runs constant
When i manually turn it off, it wont turn back on,its a 2 hp 2 1/2 gallon tank, the motor is almost bigger than the tank lol, help friends
  • 400 Answers
It is possible that the capacitor is bad, check the mfd rating on the capacitor which will be probably around 35mfd or 45mfd as example. Replace capacitor with exactly the same microfarad rating as the original.
Posted on Mar 09, 2009
My 60 gallon kolbalt was running and stop when it filled now it wont go o ever with the tank drain it spins free it does nothing no sounds either
When you say it does nothing do you mean the motor wont come on or the motor comes on and it wont build pressure? if the motor comes on, there are several possibilities:
1. The unloader valve is stuck open
2. The valves in the head are bad
3. The flywheel is loose
If the motor wont come on, the pressure switch is bad (which holds the unloader valve open)
http://www.mastertoolrepair.com/air-compressor-parts-vt6362-p-60727.html
Oct 10, 2016 | Kobalt 3.7-HP 60-Gallon 155 PSI Electric...
All Trade 5 Gal just humms wont turn on
The start capacitor has gone bad. Needs to be replaced. That's what's inside that bump on the side of the motor.
Mar 25, 2013 | Alltrade 830241 5 Gallons 3 HP Twin Tank...
After first full tank on air, and you used it, when it kicks back onto recharge the the tank, the motor runs slow and blows 15amp fuse.
Sounds like you need a bigger fuse.What happens is there is no load (air) in the tank so their is no compression and the motor isn't working as hard as when it reach's the cut off point and restarts.Now there is air in the tank which makes the motor work harder and that pulls more than 15 amps and blows the breaker.I would start with a 30 amp and go higher if need be.Thank You for choosing FixYa.com
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
May 26, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have a 5 HP Coleman air compressor. I was using it to provide air to my plasma cutter which requires 60 psi to operate. Basically, air compressor's motor keeps running, but it's stopped creating air...
You did not list model number, however if you have oilless type check the cylinder/piston by manually turning crank until piston is at top and examine cylinder for wear or scratches. If worn replace cylinder kit for full pressure. If ok check reed valves /valve plate for wear or broken reeds. If oil bath type, problem is usually air leak or reed valves / valve plate. As a general rule, you can keep track of wear by noting how many minutes it takes to fill the tank to cut-out. As the compressor wears it will take increasingly longer to fill. When new, and depending on tank size/ hp, most compessors fill within 2 ~ 5 min. Good luck
Sep 24, 2010 | Coleman Air Tools & Compressors
IR 2475E Wont start up 220 everywhere No LOP switch
did you check for a motor reset button on the motor??
Feb 20, 2010 | Ingersoll Rand - Rand Type - 30...
Wont air up tank pressure. motor runs & tank pressures to about 25lbs
below the pressure switch is a unloader valve which has a tendency to leak, undo that line and block it off, if this works you probabaly can leave it blocked off.
Dec 02, 2009 | Senco PC1010 1/2 HP 1 Gallon Mini Air...
My Craftsman 4 Hp. 15 gallon horizonal air wont tun on
There may be a thermal overload reset button on the back of the motor that was tripped. If you press it in it should reset it.
If this is not the problem, post a comment with more details including model number for more advanced troubleshooting.
Thanks,
Tim
Jun 30, 2009 | Air Tools & Compressors
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Dec 30, 2008 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Kicking overloads but not consistantly
First: Most all compessors use check valves at the tank and an unloader to allow the compressor to start without a load. Make sure that system is unloading and that check valve is not leaking causing head pressure at start. Second: Too frequent starts and stops will cause motor to overheat. Check Quincy manual for max starts per hour. enjoy
Nov 14, 2008 | Honda Quincy 17 - Gallon Air Compressor...
Tank size question
Tank size only becomes a factor for one reason – A larger tank for air. A compressor will run until the pressure in the tank builds to its high-pressure point. Obviously, the bigger the tank, the longer it takes to consume the compressed air. However, the downfall is that once the air is depleted, it takes a lot longer for the air tank to refill with pressurized air. I would only go with the bigger tank if I am concerned about the motor starting and stopping too often, or if I know that I will need a constant flow of air in longer intervals. You have a choice between a larger tank and a constant-run unit.
Aug 27, 2008 | Campbell Hausfeld 04 Gallon Twin Stack...
Air Tools & Compressors Logo
88 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
