Please help me about my power supply it is compaq (24 pins)model no. ps-7231-6cf..the resistor is burned..i dont know color code or the value number of my resistor..only i know is in the circuit of my power supply every parts has a number,,resistor,diode,capacitor,etc..and the resistor burned is R18..plsssss help
R18 is near optocoupler it is 2K resistor. ¿do you know the wires I must join to start up this power supply.
Posted on Jun 13, 2009
  • 32 Answers
pls dont try it your self. you should better call a repairman for it. He will if possible repair it or you would have to buy a new one.
thankyou for using fixya
dont forget to rate the solution
Posted on Mar 09, 2009
Value of R065 on power supply module of the RX-884V
value not cost $ but a resistor is it to hard to say resistor.?
OHMS and color bands all that is easy but no VALUE eve guessed
and if burned up and my guess it did (not said)
and guess what even if you had a correct resistor
it too will burn up, due to other part is shorted 99% chance.
HP does not publish schematics.
what we do is buy a new one. every time.
Feb 21, 2016 | Compaq rx884-69001 - 2.4x Ide Hd Dvd-rom...
Power supply damaged, Can I replace it with any other model power supply?
A standard ATX PS won't fit in your low profile case. The plug types can be different too. Usually there's a schematic with a PS that describes the wire color of each voltage. So you could conceivably shove the pins out of one PS plugs and insert them into the different plug, or solder the wires to the correct pins, and leave the PS outside of the case.
Nov 16, 2013 | HP Compaq dc7600 Small Form Factor PC...
Power supply
What is the brand name and model number to your TV? Provide more details please. To give you the proper value of that resistor, i must get its position or part number. for more information go to It has schematic diagrams to many popular TVs' power supply. Hopes, it might help you.
Nov 12, 2013 | Televison & Video
Need wii electrical schematics for motherboard repair
Are there any colored stripes on the parts? I can read color codes on resistors, and tell several things about them by the stripes ... if you can tell what the colors were or are.
May 10, 2017 | Nintendo Wii Console
Error Code 2-2. (Low Voltage Supply) What now?
That is a power supply issue and this requires a skilled person to do it.Trouble shooting in this kind of problem includes voltage measurement and resistance reading of the components/parts inside the high voltage section This is not a DIY problem but if you still want to do it yourself then I can give you some guide that you can try.
1.Check the power supply board,this board is where the power cord is connected.The common problem on this circuit are the filter capacitors .A leak and shorted capacitors always cause that kind of problem the worse is dead set.To visually identify a defective capacitor is their appearance they look to be bulging on top blown,theirs a liquid leak on the body.replace the defective capacitor if you found any.with the same rating and value..
2.Resistors -change value resistors and open resistance can cause the same problem this resistors usually near the regulator transistor.They appears as burned and overheated replace it with the same rating there is an available color code calculator of resistor in the internet click this link and key in the color of the resistor to get the value..
3. check the voltage regulator transistor if it is shorted .the first pin and second pin must not have a reverse reading..
4.Check also the two big IC marked with STK xxxx this IC are the convergence IC it controls the horizontal pin of picture..when this IC are defective this will shut down the power supply ..
The steps I mentioned must be done with a skilled personnel If you feel you can do it,well you can try or better yet bring it to the service center or call a service this link for service center
good luck hope this helps!
Feb 06, 2011 | Mitsubishi VS-60705 60" Rear Projection...
How to use ATX-250-12z SMPS with 24 pin
Chances are that 250w power supply is not going to power a motherboard with a 24 pin connector, but you can try.
You will need to purchase a 20 to 24 pin adapter cable.
Google Search Terms: 20 to 24 pin adapter
Oct 27, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Resistor problem in sanyo
I can not even begin to help without the model number as each model is slightly different. Can you post that please?
Oct 29, 2008 | Televison & Video
Computers & Internet Logo
135 people viewed this question
David Payne
David Payne
