Question about Linksys Wireless-G VPN Broadband Router WRV54G - wireless r
I am trying to set up PPTP connection to the internet on my WRV54G router (behind a cable modem). The set up calls for a fixed IP address, mask and gateway address, but my ISP is not providing those - only a host name of destination. How can I set up the PPTP connection on this router (note that when setting a PPTP on my XP, am not required to provide a fixed IP and other parameters - only the host address). Thanks.
  • dedeg Mar 12, 2009
    Thank you for trying but I need to connect using PPTP protocol to the ISP (the cable company is not the ISP here).
    Problem Solver:
  • 19 Answers
Most cable companies are dhcp configured. so you would leave the wan config as default. the only thing i would do is mask the computer mac address. this should give you the access you need.
Posted on Mar 12, 2009
Connect motorola modemsbSB6121 to Belink N600 wireless router with out losing internet signal
Step one turn on PC directly connected to ModemsbSB6121 without Wi FI router being involved.
Step two go to Command prompt type in ipconfig (press enter)
Step three note IP address of default gateway and ip address issued to P.C.
Step four type in default gateway address into browser and log into Modem.
Step five look for DHCP Server and allocate IP addresses from at least 50 for example 192.168.0.50 starting ip lease ending ip lease 192.168.0.254
Step six connect Wi Router to P.C. via ethernet cable only - remove ModemSB6121
Step Seven shutdown and restart p.c
Step Eight go to Command prompt type in ipconfig (press enter)
Step Nine note IP address of default gateway and ip address issued to P.C.
Step Ten type in default gateway address into browser and log into Wi Fi Router
Step Eleven Change IP address on Router to 2 as example 192.168.0.2. (it has to match in that modem device would have been 192,168.0.1)
(if it was 10.0.0.1 make wi fi 10.0.0.2 make sure subnet mask is the same like 255.255.255.0)
Step twelve Change DHCP Server to off
Step Thirteen may need to set default gateway to MODEM IP address for example 192.168.0.1
Step Fourteen plug modem router into Wi Fi router may need to plug into WAN port on WI FI router .
Step Fifteen shutdown and Restart Computer
Step Sixteen go to Command prompt type in ipconfig (press enter)
Step Seventeen type in PING 192.168.0.1 (if this is modem IP address and default gateway IP addess)
All this above is to avoid IP address conflicts or mismatching
Subnet mask should be 255.255.255.0
either it uses 192.168.0.1 or it uses 10.0.0.1 make sure Wi FI router is set to different address to Modem Router.
I suspect either a clash occurs or your P.C gets a different IP range from ther WI FI DHCP server.
Happy troubleshooting !
Sep 16, 2014 | Arris Sb6141 Surfboard Cable Modem Sb 6141...
No connection
Ok here is what you do
1.) disconnect your internet cable
2.) connect your router to your computer
3.) in internet explorer type 192.168.1.1
4.) enter your username and password
5.) click on Lan
6.) In the ip address box change your router ip to a new ip
e.g. 192.168.1.2
7.) Click on DHCP AND ENABLE THE DHCP SERVER
8.) Click on wan
9.) In Wan settings choose static ip address
10.) set the static ipaddress to the ipaddress you entered for your router
11.) set your subnet mask
12.) In the isp gateway enter your modem ip e.g 192.168.0.1
13.) as your primary dns enter your modem ip e,g 192.168.0.1
14 save changes and exit
YOU CAN HAVE THE ROUTER AUTOMATICALLY ASSIGN AN IP ADDRESS TO EACH SYSTEM OR YOU CAN SET IT AUTOMATICALLY
FOR AUTOMATIC ASSIGN JUST CONNECT THE CABKLE
FOR STATIC IP(recommended)
double click on the network icon to the buttom of your screen e.g LOCAL AREA CONNECTION
Click on Properties
Double Click on Internet Protocol(TCP/IP)
Enter the ip address you want the computer to have using the same 3 bloacks as your router e.g 192.168.1.10
Enter your sub net mask
Enter the ip for your moden in defaul gateway e.g 192.168.1.1
Enter the Prefered Dns as also your Modem ip 192.268.1.1
cheers
Jan 05, 2008 | Linksys Wireless-G WRT54G Router
How do you get your IP Address, Subnet Mask, and your Gateway codes
Connect your computer wired or wirelessly to your router.
in windows based comp
open command prompt
type -- ipcofig
you will get your answer
Jun 10, 2014 | Linksys -Cisco Wireless-G VPN Broadband...
Linksis router wont work help me out
First of all contact your isp and get your connection settings. If you are able to setup the router using the cd provided then good. If you are still having problems then go ahead and contact linksys (remember linksys charges for the support). I suggest get a technician to assist you in setting up.
Jul 22, 2009 | Linksys Wireless-G WRT54G Router
Dlink WBR 2310 cannot connec to internet
Try to bypass the router and connect to your modem. Make sure you have Internet connection.
>If you have Internet connection. connect back your modem to the router.
>access the configuration page of your router.
>If you are given a specific IP by your Internet Service Provider, use that one.
>Login to your Dlink (type in on the address bar 192.168.0.1)
>Click Setup and Internet > Click on Manual Configure
>My Internet connection would be Static IP
>Type in your IP address, Subnet Mask, Default Gateway, Primary and Alternate DNS
>Click on Save Setting on top.
but if your Internet Service Provider did not provide you those informations
> Under My Internet connection Type choose DYNAMIC IP
>Click on Clone Your PC MAC address
>Click on Save Settings
>If it ask you to reboot, click on Reboot.
>At the very top click on Status
>Under Status look for WAN
>Under WAN look for IP address
>If you have values beside from zero it means you have Internet connection otherwise, call your dlink manufacturer for manual configuring your router for Internet connection.
Jan 30, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Ps3 to internet
Difficult to explain but i'll try:
You got 2 options.
1. Buy a router and connect the modem to the router wan port and find a manual how to set it up. Then through your router you can connect (a lot of) pc's, laptops or ps3.
2. Buy an extra network card and a crosslink network cable cat5e. Use software like gatekeeper to connect both to internet.
maybe the second option is the best because sometimes isp providers register you mac adress(unique adress of your network device). It's not the fastest solution.
The first is the most professional but require some knowledge of routers, ppoa, pptp, fixed ip, Wan ip, and lan ip.
I did the second option a lot with speedtouch modems and draytek routers.
Good luck, let me know if you need more assistence.
Dec 29, 2007 | Computers & Internet
How to set up for internet use with muliple pc's
I assume you router came with a configuration manual or CD. Its very easy. Once by following the instructions, go into the router like:
http://192.168.x.x (whatever IP is suggested by the manufacturer) and make sure the internet connection type. Mostly the ISP's use 'Dynamic IP' (if you scroll other ones will be like PPPoE, PPTP etc). Select Dynamic IP and restart your router and you will see after few seconds that your router has started to offer IP's to the internal Lan Pool. connect your ethernet cables from the computers to the router (behind the router you will find the ports to connect them)
In your Network settings in the router assign an internal IP to the router like '192.168.x.x' subnet mask 255.255.255.0, enable DHCP server and assign the internal LAN ip pool like 192.168.x.20 to 192.168.x.100 and you are all set.
Very important:
Security settings Always make sure your router (if in case its wireless router as well) assign and use an authentic security feature like 'WPA, PSK or WPA2, PSK' you could also use WEP (but WEP its getting old) I recommend WPA higly for wireless clients. If you have NONE wireless connections to offer than do not worry about it.
OR
simply put the CD inside your system connect it with router and it will guide you through for configuring it.
I hope it helped
Dec 16, 2007 | Linksys EtherFast Cable/DSL Router
DIR-635 can't access the internet
I think you have wrong configuration of your router.
1. Some xDSL Internet Service Providers may assign a Fixed IP Address for your Broadband router. If you have been provided with this information, choose this option and enter the assigned IP Address, Subnet Mask, Gateway IP Address and DNS IP Address for your Broadband router.
2. If you connect to the Internet using an xDSL Modem and your ISP has provided you with a Password and a Service Name, then your ISP uses PPPoE to establish a connection. You must choose this option and enter the required information.
Nov 04, 2007 | Computers & Internet
Setting up a PPtP server behind a WRT51AB Router
You?ll need to setup Port Forwarding to set up a PPtP tunnel behind a Linksys router. Please follow these instructions to setup the router to forwarding incoming PPtP traffic to your PPtP server: Getting Started 1. You must set a static IP address on the server. If you're unsure of how to do this please go to our Answer ID 534 for information on setting a static IP address in Windows. 2. Once the static IP address has been assigned please go to your desktop and double click on Internet Explorer (Located on the Start Menu in Windows XP) 3. Once "Internet Explorer" opens, please type http://192.168.1.1into the "Address Bar" and click GO 4. The "Enter Network Password" window will appear. Skip user name and type admin (admin is the default password) as the password, and click OK. 5. This will bring up the routers "Setup" section. Look under "Domain Name" and check what version of the firmware you're using. 6. You will need to click on the Advanced tab to the very right. Once the "Advanced" tab comes up please go to the Forwarding tab. Firmware prior to 1.32 This will not work with firmware prior to 1.32 Firmware between 1.32 and 1.36 Service Port Range 47 ~ 47 1723 ~ 1723 IP Address 192.168.1.3 192.168.1.3 Firmware after 1.36 up to 1.40m Service Port Range 47 ~ 47 1723 ~ 1723 Protocol Both Both IP Address 192.168.1.3 192.168.1.3 Firmware after 1.40m Customized Application VPN VPN Service Port Range 47 ~ 47 1723 ~ 1723 Protocol Both Both IP Address 192.168.1.3 192.168.1.3 Finishing up Click Apply, then Continue. Restart your computer
Feb 16, 2006 | Linksys WRT51AB Wireless Router
Linksys Wireless-G VPN Broadband Router WRV54G - wireless r Logo
102 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
