FixYa.com
Tags:
Sony Internal 52x CD-ROM Drive
Sony Vaio Woes :(
By Duke - usenet poster
My girlfriend's got a laptop with these specifications:
SONY PCG-Z600TEK
Windows XP Professional.
P3 700MHz
Video Card:
ATI RAGE MOBILITY-M1 AGP
CD-ROM Drive:
TOSHIBA CD-ROM XM-7002Bc SCSI
Modem:
Conexant SoftK56 Data,Fax PCI Modem
Network Card:
Intel 8255x-based PCI Ethernet Adapter (10/100)
Sound Card:
YAMAHA DS-XG PCI Audio CODEC (WDM)
Current BIOS Version:
R0203Z3 / RK203Z3
autoexec.bat
MSCDEX.EXE /D:MSCD /M:12 /V /L:G
config.sys
DEVICE=ANSI.SYS
DEVICE=VA16365.sys /ne
DEVICE=VA16CD.SYS /D:MSCD
However when she plays MP3s through Windows Media Player the songs jump/skip
a lot. This is a
very serious problem.
Recently we bought a ARTEC DVD & REWRITABLE CD DRIVE, Model - ARTEC 52X
EXTERNAL. When we
play DVD movies it's fine but frequently the movie slows down and goes
jerky. Very annoying.
Does anyone know what the problem is?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Riddle
Riddle - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Further to Chris's comments, run disk cleanup and defrag. If it is a
small HD, 8MB, you should check that there is at least 500MB free, and
if not, make that much free. Start/Run command/type: msconfig. Select
the startup tab. Uncheck the box for any entry that does not need to
run. Use this site to determine if an entry needs to run:
# Make a note of the
application that is unchecked, open that application and find the
preference or option to prevent running on startup. You might empty the
contents of C:\Windows\Prefetch. The computer will boot a bit slower
until the contents are rebuilt, but it will remove any corrupted
entries.
Q
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Odud
Odud - usenet poster
Rating: 0%, 0 votes
You don't mention how much memory she has in it,specs say it comes with 128,
max is 256, that'd be my guess as to the jerkiness. Along with the 8meg
video chip, that doesn't help either. Also, why does it need an autoexec.bat
and config.sys file running XP?
system specs at
Chris L
Can you Help with these CD ROM Drives problems?
CD ROM Drives
cd rom for a206x
need cd rom for this model... Answer This...
CD ROM Drives
LG GDK 70
I am looking for LG GDK 70... Answer This...
CD ROM Drives
cdrom often lostii
i am having compaq presario... Answer This...
CD ROM Drives
cd drive
do you know thw dimensions for... Answer This...
CD ROM Drives
Message indicates the dvd drive...
I have a ccd-52X6D model star... Answer This...
Repair Service
Find CD ROM Drive Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
