Question about Electrical Supplies
Need to replace the HPM dimmer switch with a normal switch
Need to replace the HPM dimmer switch with a normal single post switch as new lights do not allow dimming. Note: lights are controlled by 2 switches
  • 10,865 Answers
This is not a difficult job. First of all go out to a home depot or other hardware store and purchase one three way switch. They come in white, cream, and brown.
Back home, kill the power to the lights you are working on. Then open up the dimmer switch, the other switch doesnt need to be changed. Now, simply draw a diagram of where each wire color is now connected and remove the old dimmer. Reconnect the wires. Remember that the white wire goes on the dull color screw and the other two go on the brass screws. Turn the power back on.
If you do all this and the switch only works correctly part of the time just reverse the two wires on the bright brass screws. Please mark this answer as a fixya!
Posted on Mar 09, 2009
I would like to connect a two way dimmer to a one way circuit.
Do you mean a three way dimmer?
How many switches do you want to be in the circuit when you are finished?
A three way switch can be used in a circuit where one or two switches are desired.
What you need to find is which two wires go to the light, and which two come from the power.
Are you in the US, if so, there will be a white wire which should be a non current carrying conductor. It will not be attached to the switch.
Without understanding the number of switches that are currently in the circuit, I'm going to tell you if you just are wanting to replace a single switch with a three way, than "yes" that is not a problem.
Hit me back when you can with the rest of the information.
Feb 09, 2016 | Electrical Supplies
I replaced a two gang light switch and now only the bathroom light works landing no help
Assuming both switches are single pole...
One black wire from connects breaker connects to each switch.
One black wire from light goes to light
http://waterheatertimer.org/How-to-wire-switches.html#gang
If your switches are 3-way... then re-post new question.
Gene
Water Heater Timers Save Money
Mar 14, 2015 | Electrical Supplies
Hpm wiring diagram
Neutral is required to complete circuit in 120V 2-wire circuits
Gene
Aug 15, 2014 | Electrical Supplies
Hpm doorbell
I think there is a problem in your back side connection. You need to check that one or otherwise you should call the electrician.
Jun 22, 2013 | Electrical Supplies
How to fit dimmer switch
The dimmer switch you select will depend on the type of bulbs you will be using. The 'original type ' of dimmer works with regular incandescent bulbs and halogen bulbs only. They cost around $15.00. Then there are dimmers for compact florescent (cfl) bulbs and LED lights that are dimmable, as well for regular light bulbs. These types of dimmers are more expensive, ranging in price form around $40.00 upwards.
Light Switches Dimmers
If you are replacing a single pole switch ( just one switch that operates lights) you'll need a single pole dimmer. If you are replacing a 3-way switch ( two switches that operate the same light) you'll need a 3-way dimmer.
Installing the dimmer is pretty straight forward. All dimmers come with installation instructions. Make sure you turn off the circuit breaker for the particular switch you are replacing.
May 29, 2013 | Electrical Supplies
Leviton 6793 does not work on LED lamps?
Look at product number again to see if numbers posted are correct.
Also include what type of device this is: rotary dimmer? slide dimmer? touch dimmer? Switch? single-pole application or 3-way? And include what you are replacing.
Aug 06, 2012 | Electrical Supplies
I have a DL-3PSLHW-WH switch with no wiring diagram. It is single pole or 3-way. Need diagram.
You posted under Lutron 3-way dimmer.
You didn't say the number of screw terminals on device or color of those screws.
If your device has two brass screws, then it is single pole.
If your device has 2 brass screws and 1 dark screw, then device is 3-way
If you are replacing 3-way switch, identify wire on dark screw >> connect this wire to dark screw on dimmer. Other two wires connect to either brass screw.
If device has wires instead of screws, the color of those wires is an important clue.
Answer back with the colors of those wire and it is easier to help.
Different dimmers are suitable for different types of lighting.
In an effort to help you, I searched my files for Lutron dimmers.
Lutron has 17 dimmer types, with numerous models under each type
They don't show DL-3PS
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/Pages/DimmersSwitches.aspx
Lutron has NT-3PS
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/NovaTDimmer/Pages/ModelNumbers.aspx
The NT-3PS is a 3-way dimmer.
Here is wiring manual:
http://www.lutron.com/TechnicalDocumentLibrary/wallbox_wiring_6_7.pdf
If the help above does not get you going, answer back with more information and we can help.
Oct 24, 2010 | Lutron Dalia 3Way Dimmer 600W- White -...
Problem w/new sliding dimmer
The problem is that the Cooper #9530DS-K-L is actually a 3-way switch and you need a single pole dimmer switch to replace your existing single pole toggle switch.
If you want to use the Cooper switch you have you can take one of the black wires and cap it with a wire nut and connect the other two wires, but frankly, you'd be paying about 2 times the price for a 3-way dimmer switch when you only need a single pole switch.
You should be able to return the switch and get the correct one.
You should only have (2) black wires on the proper replacement switch, plus a ground wire
Hope you found this very helpful and best regards!
Aug 07, 2009 | Electrical Supplies
Electrical Supplies Logo
2,709 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
