Question about Panasonic KX-T7630 Corded Phone
How to do check my missed call log
The incoming calls shows a message on number of calls missed and i would like to know the numbers.
thanks.
  • Anonymous Mar 27, 2014
    phone shows missed calls. how to view the calls and erase the miss call message
  • Panasonic Master
  • 2,460 Answers
A Panasonic TDx system has 2 types of call logs, one personal for the set, and one for the ICD group.
Pick a spare button, press PROG, the button, and dial 54 STORE.
If you had incoming: 00x on your display, that button will light and you can now press it to see who called. Your Navigator UP/DONW key will step you forward or backward through the log. The LEFT/RIGHT key will display the 4 lines of the display if you're not using a 7636 phone.
If you want to see incoming calls to a particular ICD group, pick another button, and dial 54 plus the ICD group number. For example, I used 100 as my ICD group (now 600 by default). I have 2 buttons, one logs my extension calls, one displays the system calls.
Carl
Posted on Mar 09, 2009
Call long not show - miss call, incoming call etc
Dear Harun,
Thank you for contacting Fixya. Just reset your phone. It will fix your problem.
Mar 31, 2014 | Nokia 7210
Problem with the incoming and missed calls in Motorola Silver L7
you must have to make reset to factory default, go to the MENU, and ask to restore. see your owner manual, or download from your supplier company or go to www. retrevo.com and get it.
However you must try to see if the battery charger adapter is o.k or battery this is very importante, because this would be a problem . test it.Otherwise the software is corrupted.
God bless you
Nov 26, 2013 | Motorola Cell Phones
HOW DO YOU CLEAR RECENT CALL AND MESSAGES
Hi trsampson,
To clear recent calls, here are the steps to follow:
1. Go to the 'Menu' option.
2. Scroll, till you get to call register.
3. Select it, then scroll to 'delete recent call list'.
4. After you have selected it, you would be provided with the options to delete,
i. 'All calls', selecting it would entirely wipe off your entire call log.
ii. 'Missed call', selecting it would delete your entire missed call on the call log.
iii. 'Received calls', selecting this deletes all your received calls.
iv. 'Dialled calls', selecting this deletes all your dialled calls on d log.
You could also perform selective deleting. You might want to delete a/some paticular number(s) that is on the log, not the entire log.
To effect this, after step 2 above, you can scroll to either of 'missed calls', 'received calls', or 'dialled calls'. Select the one which pertains to the number you want to delete, scroll through till you get to the particular number(s), select 'options', scroll till you get to 'delete', then select delete, and the number is deleted. Do it for as many numbers as you want to be deleted.
To clear messages,
1. Select the menu option, scroll till you get to 'messages'.
2. Select 'messages', scroll for either 'inbox' or 'sent messages'.
3. Select whichever you want to delete from, scroll to the particular message, and select 'options', sroll again, and select 'delete'.
Hope that helped?
Success.
May 09, 2011 | Motorola Cell Phones
How do I get the Panasonic KX-T7633 to show incoming caller's phone number? Is this a feature the phone automatically has or do I need to contact my telephone provider? Thank You.
You need to have Caller ID enabled by your telephone provider. Most providers charge a fee for the service. (In my area, it is $4.50 to display just the incoming number, $6 for names and numbers or you can get it in a bundle with other services for ~$10. Your prices may vary.)
The incoming calls will be listed in the call log once the service is active. You can clear this information when you are confirming the log information after navigating to the desired item by pressing Clear. You use the left/right arrows to find desired log/directory and then the up/down arrows to select a log.
I hope this helps.
Jan 10, 2011 | Panasonic KX-T7633 Corded Phone
No number or contact name on incoming call.
Hi, I had the same problem few days back. I am using Nokia N95 with a Vodafone service. Any call I receive simply showed "Call" and on checking the call log, says "No Number". this problem is not with the phone, but with the network. I checked with the Vodafone customer associate, I got to know I din't submit my documents to them which is required on an yearly basis and so my phone had this problem. So if u r also having same problem as I had, try contacting ur network service associates and they could help you fixing the problem.
Aug 19, 2009 | Nokia E71 Smartphone
All Incoming Calls Show As Private Number
First thing : the person who's calling you have CLIR . Don't put the same number to phone & SIM. Use the phone memory and also save numbers in international format.
Jul 12, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
Remove message of the middle line of display
Pick a spare button and label it CALL LOG. Now press PROG that button and dial 54 STORE. Ooh, it should light up. Now press it and your display will show 3 of the 4 lines of CID info from the calls to your set. The navigator button will show the rest, just keep pressing the UP, DOWN, LEFT, RIGHT buttons. When you run out of items to display, the light and INCOMING CALL display will go out.
If you press 54 and the 3 digit number of your incoming call group (maybe 601 by default) it will follow the incoming calls to the entire call group.
Carl
Apr 24, 2009 | Panasonic KX-T7630 Corded Phone
Display showing "Incoming Call :001"
Don't worry, if you ignore it will grow :-)
It's a count of the unanswered calls with CID. If you take a spare button and program it for Call Log, it will light up and you press it to start the call log display.
Try this press PROG 54 STORE
When you press it, your display will now reveal the numbers under incoming.
If you put a number after the 54, it will log calls for a particular group. I get my calls on incoming group 100, so I store 54 100 under a button and I can see all system calls. I have a second button for just my extension calls.
Carl
Jan 15, 2009 | Panasonic KX-T7630 Corded Phone
N70 Call Logs
just reset the phone it might solve your problem.
here's the code to reset *#7780#
peace!
Dec 03, 2007 | Nokia N70 Cellular Phone
Panasonic KX-T7630 Corded Phone Logo
1,579 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
