Question about Mantis Tiller
The tiller bogs down, loss of power.
I lent my tiller out and when I got it back it now has no power. Some smoke from under the motor at times. Really bogs  down in a few minutes of use. The guy said he had lots of rocks in his garden.  I have not taken anything apart yet.
Please guide me for making this repair.
Walt Swanson
I have had same problem. First time, I sent it out for fixing. They told me exhaust was clogged. They clean and it ran great. From then on, I started cleaning exhaust and intake myself. Also found manual online, which helped a lot. I've since then found out that the Mantis motors are similar (or a branch off) of Echo. So many parts are similar to their gas blower pack. Home Depot had a kit that had spark plug, air filter, and fuel filter in it all for ~$12. Had to tear off rubber from around air filter, but other than that had it running great in no time. I've also learned since finding the manual online, that the gear box should be checked/lubed each year, and also how to reseat motor on drive shaft, if slips off.
Good luck
Posted on Apr 27, 2009
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
How do I keep the tiller from bogging down when it goes in the dirt.
Adjust the depth bar on the back higher and push the handles down to rasie the tines somewhat.
Sep 12, 2014 | Garden
Snowblower problems
Possible problems
Belt slipping ( too loose or worn out )
Snow too wet and plugs up.
Motor not powerful enough could be running too slow
Could be the gas screw on the carb set too rich and floods or too lean.
Could be trying to blow too much snow at a time.
Depending on the machines age could be just wore out
In saying this I don't know what type or age of your machine
Feb 22, 2014 | Garden
If you lent your tiller to your "know it all"
While having your brother buy you a new tiller sounds good, it just might not be practical or posible. So drain the fuel from the tank, fuel lines and the carb., clean the spark plug and replace fuel filter if installed. Put the proper gas in and start it, should be good or clear up pretty quick. Hopefully it did not run with the wrong fuel for too long where the spark arrestor in the muffler would get clogged up.
Good luck.
If really helpful, please rate.
Jul 13, 2011 | Yard Machines Tiller 208cc 18in Tilling...
My tiller was working fine. Then it acted like something had jammed the blades. I removed the blades and nothing is wedged. The engine runs but bogs down because the shaft is not spinning. It acts like...
Sorry Bob, it needs shop time. The part under the motor and between the two blade sets is the transmission. The input shaft from the motor is geared to turn the blade shaft; either may be frozen if there wasn't enough grease in the trans or it's possible a gear tooth broke and jammed the system. You have to remove the trans, take off the blades and get inside it to see if the grease is contaminated or if it even has any in it. Check for peices that may have jammed in the gears also. If all of the parts are intact, clean out all of the old grease and pack as much new grease in as you can get in it.
Oct 28, 2010 | Mantis 2-Cycle Tiller
Tines turning, mantis 2 cycle tiller
sounds like a piston seizure. are you using correct oil and ratio. carb could be going lean and causing the cylinder to over heat, adjust high speed mixing screw and hope no damage has resulted.
Jun 30, 2010 | Mantis 2-Cycle Tiller
Engine bogs down when speed is increased.
Ok I have r Royobi Tiller (30CC Gas) And last year it ran fine after rebuilding the Carb. This year it was "hard starts" Idles fine, (Tiny whisps of blue smoke in exhaust with correct ratio) Even seems to run better with the choke "on" but idle only. as soon as I touch the throttle...its bogs down in tune with how much gas I give it. Little throttle? Little bog down, Little more throttle? Almost stalls, a normal throttle rev? it stalls dead! Then starts right back up again in 1 pull and idles fine again!? WTF? So after cleaning a clean carb again, (twice) and seeing no change I thought I'd go look at the original diaphragm and compare it with the rebuild kit diaphragm (which is the one in the carb.) And guess what? The replacement has a larger rivet by a factor of "2". So basically it was flooding the carb, I bent the needle tang down, better but no cigar. But I could rev it half way now. A second disassemble to bend it yet a bit further and Vrooom vroom vrooom ****! So check your needle valve even though you think its 100%. (Especially if you rebuilt the carb with a kit!)
Mar 27, 2010 | Honda 25cc 4-cycle Mini Tiller
It idles fine. When I press the throttle, it bogs down and stalls. I replaced the spark plug when this initially occurred.
The problem is that your carbeurator is gummed up. Get a can of carbeurator cleaner spray at any auto parts store. remove the air filter and put two squirts of cleaner into the air port hole. start it up. with the assistance of a helper, run it and squirt one squirt of cleaner at a time into the air hole until it no longer bogs down.
Aug 12, 2009 | Mantis Tiller
Difficulty adjusting carb for smooth idle and full power tilling
Your quickest fix for this problem is to simply replace the carburetor, a Zama K54A. Do it all the time. After that, if you can find a 2 cycle oil, Opti-2, it's the best you can use and it's a one mix for all your 2 cycle equipment (blowers, trimmers, chainsaws, etc.) It's the only 2 cycle I sell in my shop.
Apr 05, 2009 | Mantis 2-Cycle Tiller
Troy Bilt tiller dies when I engage the tines.
Bogging down may indicate debris or old gas in the carb. Try doing a carb cleaning, and add a small amount of Seafoam gas additive to your gas.
Mar 21, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Mantis Tiller Logo
796 people viewed this question
Top Mantis Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
