Question about Sanyo DS32224 TV
Component code need the sanyo tv code for my ds32224 tv component code to enter into a new control
    Sergeant:
    Champion:
  • 318 Answers
Codes-0154,0159 this is for the tv
Posted on Apr 24, 2009
I have a sanyo ds32224 tv and a phillips universal remote what are program codes
These are the codes to check with Sanyo brand TVs. If you wish to get more details about setup, check this link.
Feb 13, 2013 | Televison & Video
I need the code to my sanyo tv
Hello
According ro RCA Codes for sanyo are detailed as
Code 004 for sanyo tv Code 048 for Sanyo TV Code 049 for Sanyo TV Code 073 for Sanyo TV Code 080 for Sanyo TV Code 107 for Sanyo TV Code 162 for Sanyo TV Code 169 for Sanyo TV Code 180 for Sanyo TV Code 196 for Sanyo TV
Just check with these codes according to the proceedings.
1. Manually turn on the TV.
2. Locate the enclosed TV Code List. Find
your brand of TV.
Note: If your brand is not listed, use one
of the Code Search methods to program
this remote control. (See section on
Code Search.)
3. Press and hold the CODE SEARCH key
until the indicator light illuminates.
Then release the CODE SEARCH key.
4. Press and release the TV key. The indicator
light blinks and then remains lit.
5. Use the number keys to enter the first
code listed for your brand. After you
enter a valid three-digit code, the
indicator light turns off.
Note: If you enter an invalid code, the
LED flashes rapidly for two seconds.
Start over at step 3.
6. Aim the remote at your TV and press
the ON•OFF key. If your TV turns off,
you have found the correct code.
7. Enter the code in the box provided on
this page for future reference.
8. If your TV doesn't turn off, repeat steps
3-6 above, entering the next code for
your brand.
Manual Code Search
1. Manually turn on the component you
want the remote to operate.
2. Press and hold the CODE SEARCH key
3. Press and release the component key
that corresponds to the component you
want the remote to operate (TV, VCR,
DVD, DBS•SAT, CABLE, AUDIO). The
indicator light blinks once and then
remains lit.
4. Aim the remote at the component. Press
the ON•OFF key continuously until the
component turns off.
Important: Because there are so many
codes, you may have to press the
ON•OFF key many times-possibly up
to 200 times.
5. When the component turns off, press
the ENTER key to store the code.
6. Use the Code Retrieval section on the
next page to identify the code for your
component for future reference.
OK
Feb 15, 2011 | RCA RCU600M Remote Control
Where is the mode button so I can sync the remote and the tv? what is the 3 digit code
Hello
Three digit universal remote codes for Sanyo are:-
004/ 013/ 049/ 108/ 110/ 180/ 209
Four digit universal remote codes for Sanyo are:-
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON the tv by its front panel power control switch [Not by remote control handset] each time before an other code.
OK
Wish you Happy Peacefull 2011.
Dec 30, 2010 | Sanyo DS32224 TV
Can you hookup a computer to the sanyo ds32224
Yes, if you get the appropriate converter. You will need either a VGA to component video or VGA to composite video converter. Some of these are available here: http://www.svideo.com/pctocomponent.html . Since the computer VGA port provides an RGB signal and the component video is a YPbPr signal, the converter is essential.
However, the cost of the converter may not be worth using this method when replacement monitors are fairly cheap. (Christmas sales had 19" LCD monitors for under $100 with VGA input.)
I hope this helps.
Dec 27, 2010 | Sanyo DS32224 TV
Lost remote control can I get another one
contact sanyo at sanyo.com follow instructions to replacement parts
Mar 09, 2009 | Sanyo DS32224 TV
32" sanyo model ds32224
picture 330 lines
video input 700 lines
16.9 full HD has 1080 resolution and this is for a ds 32224
Jan 28, 2009 | Sanyo DS32224 TV
Sanyo DS32224 tv remote
It sounds as if you have inadvertently selected the 'Aux' function. Pressing the 'TV' button (should be close to the Aux and others) should restore full control.
Since the volume generally means 'TV Volume,' this function often stays effective but the other controls will not respond, including 'Power.'
This happens to us all the time with our Dish remote which also has 4 basic functions.
Apr 26, 2008 | Sanyo DS32224 TV
Sanyo DS32224
Maybe buy a new one? Maybe LCD? Maybe keep up with technology? Feb 09 they will no longer have Analog Tuner so you need to get a New one anyways , it will all be digital according to the government!
Jan 12, 2008 | Sanyo DS32224 TV
Universal remote control
Existing 'universal' remotes will often have no codes for later TV sets; we have a number of useless 'universal remotes.'
Many of them do have a 'code search' function and you might find a code set for an unrelated TV that will give you some basic functions.
Dec 24, 2007 | Sanyo DS32224 TV
Sanyo DS32224 TV Logo
163 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
