Question about HP Pavilion dv2890NR Notebook
No digital line in or stereo mix option vista hp artist edition
There is no extra options for line in etc, just microphone, in recording tab, no hidden devices, would really appreciate stereo mix or similar so i can record with audacity
google gives loads of advices to find the "hidden" stereo mix etc, but none of them worked for me
conexant sound card artist edition hp last year, latest drivers (autumn 08)
maybe if i installed some other soundcard driver it would work
any suggestions?
  • Anonymous Mar 26, 2014
    I upgraded from Win 7 Home to Ultimate...and with all the zillions of updates...somewhere along the line, I lost my Stereo Mix recording ability. How do I get back/re-install it?
    Scholar:
  • 180 Answers
Your sound card fitted to you unit can not support what your trying to do - end of story
Posted on Aug 08, 2009
Gigaware no sound
If you have audio cables from your source connected to the capture card, then your Recording device needs to be the Line In of the capture card.
If you connect the source to the Line In on the computer, then you use that as the default recording device. Until I set this, the default audio recording device was my microphone (not connected at the time). In Windows, you need the Manage Audio Devices Recording tab. (In Windows 7 and 8, it's under Control Panel > Hardware and Sound > Sound > Manage Audio Devices.)
If you are recording something playing on your computer, then the stereo mix option may work.
You should be able to use any video&audio software if the drivers are compatible. Thus the software you used for the video recording should work. (Stereo mix may be an exception - not all sound cards actually work when you try to record that content.)
I hope this helps.
Dec 03, 2013 | Televison & Video
Hp pavilion running vista. Can't turn on stereo mix to record the sound the computer is making
1. Click the Start Button, type "MMSYS.CPL" (without quotation marks) in the Start Search box and press Enter.
2. On Recording tab, right-click on the blank area
3. Check “Show Disabled Devices” and “Show Disconnected Devices” and the Stereo Mix should show up.
If it is disabled, right click on it and choose Enable it.
Check the further steps in following link:
http://www.vistax64.com/sound-audio/194885-how-unmute-my-line-need-regedit-professional.html
Regards,
Umair
Jun 26, 2010 | HP Pavilion dv9000z Notebook
Logitech Webcam Microphone not working
You may have a laptop with another mic installed or other mic software installed
try setting the webcam mic as default
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Jun 14, 2010 | Logitech QuickCam Communicate STX Personal...
Imic mon only-left channel is all that is seen
Audacity with Griffin iMic under Vista
There is limited and conflicting advice on the web about whether the iMic audio-usb adaptor can be used with Vista (for those who discover that new laptops commonly lack a stereo line-in port, and seek some way to use Audacity as described in the tutorial on capturing music files from vinyl, tapes etc).
In my case at least (Vista business 32 on a Thinkpad X200 with inbuilt Conexant Smartaudio 221 soundcard), it could be made to work as follows:
1. Plug the iMic device (iMic2 in my case) directly into a usb port on the computer. Allow the automatic loading of drivers by Vista.
2. Via control panel or right-click on the speaker icon in the system tray, access the Vista configuration for Sounds.
3. In the Recording tab, you should now see the added iMic usb device (probably designated as a microphone). The default set-up seems to be mono - so you need to make this change for this device: select Properties, Advanced, "2 channel...44100 Hz... CD quality".
I also disabled the built-in laptop microphone so there would be no chance of it interfering with recordings (or software conflicts?) - not sure if this is relevant but easy to test in the event that you strike a problem.
4. In the Playback tab, decide what you want as the default speakers.
The default seems to become the usb adaptor, but I changed back to the built-in speakers for monitoring - not sure if this is relevant but easy to test in the event that you strike a problem.
5. In Audacity (1.3.6 beta in my case): under Edit, Preferences, Recording, choose the iMic device and stereo. Project rate at bottom left of screen should match the quality chosen in Vista set-up for the device (44100 Hz).
6. While in Audacity, Edit, Preferences, Playback, choose the desired speakers (the built-in laptop set in my case) and click "Software playthrough" if you want to monitor what is being recorded (with a slight delay).
7. Immediately testing the set-up to record generated an Audacity "error while opening sound device". This only seemed avoidable by going back to mono settings in various places. BUT all is not lost...
8. Reboot! (With the iMic device connected in my case - not sure if this is necessary.) Ta-da ... all now works as desired for stereo recording. Use the same usb socket for the iMic in future, or you will have to repeat the set-up for each usb socket.
9. The Audacity volume sliders do not work under Vista, but you have several options to adjust recording volume:
(i) Use the slider under the Vista configuration for Sounds, Recording, iMic, Properties, Levels. For me this introduced a lot of hum at high settings, so I recommend keeping it below 5/100.
(ii) Use the iMic slider switch in the Mic position rather than the Line position, and fine tune as in (i) above. For me this gave the lowest background noise/hum.
(iii) Use the headphone out from your hi-fi amplifier and control volume there. This gave more background noise for me.
10. Keep the iMic device away from power supplies (it can pick up hum) and any source of vibration (if you tap it you will see a spike in the signal) while recording.
If you get hum, check whether it is from your laptop power supply (unplug and record using the laptop battery to see if the hum disappears). In my case there was unbearable hum from an iGo Juice supply, but much less from the Lenovo power brick.
After all that it is just about as good as my old Thinkpad X31 which has an inbuilt line-in socket and Soundmax audio card under XP.
With any luck the same approach will help with other ‘new, improved’ (but lacking line-in) Vista computers.
Aug 15, 2009 | Apple Griffin iMic External Sound System
I inadvertently deleted the Line-In Realtek High Definition Audio
Simply re-install the software and all your original data will be restored. If you purchased a downloaded version, go to the site from which your purchased it and request your keycode again, and permission to re-download. Then burn the text file with the keycode and the downloaded installer onto a CD so you won't lose it again. Another solution is to get Nero.
Jul 17, 2009 | Roxio Creator 2009 Ultimate for PC
Hp sterio mix problem
What exactly is your problem?
Please explain a little better what you are needing.
Jun 26, 2009 | HP Pavilion dv9000z Notebook
No recording devices except a microphone
See this article and read the comments for wav files.
Also see this link...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Google is your friend, google is your friend, google
May 04, 2009 | Dell Studio 1537 Laptop Computer PC...
Stereo mix option not available
hi i am ashfaque from Bangladesh
Apr 14, 2009 | Intel D101GGC Motherboard
Built in mic
Goto the Volume icon in the tray on the right hand side of the taskbar.Open it.Goto the recording properties and change the recording option to microphone.The initial setting could be with a Stereo mix.Once you did the necessary change, the recording should be normal.Please do rate if this solves the problem.
Dec 06, 2008 | Toshiba (P000257700) Microphone
Boss BR900CD External MIDI
I'm not totally familiar with that Boss Digital Audio Workstation but it sounds like what you want to do is record both the music and vocal track at the same time. If that's the case I believe you can push both "Line" and "Mic" input buttons (perhaps not exactly named as such) at the same time to record both simultaneously. Otherwise I would suggest copying the music to it's own stereo track (or two individual tracks, each panned opposite from one another to maintain stereo) and then record your vocal track separately. That way you can record several takes and edit down the best parts to one final track.
I hope that helps.
Dec 02, 2017 | Boss Micro BR Digital Recorder
HP Pavilion dv2890NR Notebook Logo
433 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
