Question about Canon PIXMA MP780 All-In-One InkJet Printer
When i plug the my pan drive with USB then my computer display such type of massage "one of the USB attached to this computer has malfunctined , and window does not recognize it"
  • 158 Answers
Try to attach that pen drive in another slot and if its work fine than always use that slot.
If its not working fine or showing that malfunctioned error than please update your USB driver of your machine.
Posted on Mar 09, 2009
USB Device is not Recoynized.
I would disconnect it reboot and then plug it back in. Sometimes an error occurs for no apparent reason.
Jan 10, 2014 | Computers & Internet
Hi, I have LG MP3 PLAYER LGT-UP-S(B) but when I put it in usb laptop the massage displayed the it unrecognized usb, can you help me to fix it? thank you
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Jul 05, 2011 | Computers & Internet
Hello , I used my sim (mic d33193) in many computer and got the same message: "USB Device Not Recognized" One of the USB devices attached to this computer has malfunctined, and Windows does...
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery program to recover your files.
http://www.asoftech.com/adr/
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
4 Gb pen drive can't poen
Your drive could be corrupt. The first thing I would do however is make sure you are plugging it into a good USB port. If you are using a desktop with USB ports in the front, and are plugging the drive in there, remove it and plug it in to one of the USB ports on the back of the computer. Many times the front ones will have issues with certain USB devices. If that doesn't work, you very well may have a bad usb drive. I would try it on another computer if switching the usb port doesn't help, to see if the drive is truly not working or just a driver problem on your computer.
Apr 20, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I m not being able to copy mail massages from
By a pen drive I'm guessing you mean a USB flash drive like thing. When you plug the pen drive in, your computer should automatically detect it and open up a window that has its contents. Leave that open and find the file that you need to move onto it and just drag and drop it into the Pen Drives window. Its as simple as that. Then close the window and disconnect the drive.
Mar 18, 2010 | Dell Inspiron 1525 Laptop
I just plug a USB dongle Bluetooth into the computer so i can access my phone and it does not download, what do i do?
Take the cd came with bluetooth insert it into drive and install it. complete the instsllation then open the blue window and bring the arrow on different option select internet option keep mobile near computer then select search option computer will search phone ane will give massage after faund out and phone will show display the press any password on mobile and same on the computer then open the internet
Mar 12, 2010 | Computers & Internet
I cant open it
W 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if you need more help with this or if i have missed the problem post a reply
May 29, 2009 | Kensington Electronics - Others
Pendrive light not blink error massages.
Apr 06, 2009 | Kensington Electronics - Others
Usb pen drive corrupt data coludn't delete
while starting your computer press f8
choose start windows with command prompt
plug in your pen drive
type following things
format g:
i have typed if my drive is g:
if your drive is f: then type
format f:
by-nischal(nisc)
Mar 18, 2009 | Electronics - Others
Canon PIXMA MP780 All-In-One InkJet Printer Logo
43 people viewed this question
old marine
old marine
