Question about Dirt Devil M087700SV Bagless Upright Vacuum
Dirt Devil Upright Bagless Vibe Vacuum no longer sucks
When trying to vacuum carpet it seems to spit or blow out instead of sucking in anything. When using the hose separately it has suction on its own but nothing is going into the bagless canister. Have replaced hepa filter, belt and checked hoses for clogs. I'm stumped.
Thanks, C
Sounds like there's a clog in the long hose that connects to the dirt canister. Remove the hose completely and check for clogs. There is a blue plastic piece that the hose is attached to. You can remove it by taking out the two screws in the back, and the four screws behind the dirt canister. Once those are removed, the hose comes away from the vacuum with the blue plastic piece attached. That should allow you to check for clogs. If necessary, take the hose outside or a place that is well lit, so you can visually verify the absence of clogs.
Posted on Oct 29, 2009
  • 294 Answers
From the problem you are describing, you are on the right track of locating the issue. It sound as if you hav a blockage in the lower foot of the vacuum.
Posted on Mar 09, 2009
I dont have a manual for the dirt devil vibe bagless cleaner. It's depositing dirt instead of picking it up. Is there a belt? i don't see one and maybe that's why
Information on your Dirt Devil Vibe Bagless Quick Vac M084500V can be found here:
http://www.dirtdevil.com/products/details.aspx?id=M084500V#parts
A link is available to download the manual as well as for replacement parts.
Yes this model has a belt to run the power brush; the manual has replacement instructions.
If dirst is being left behind it could also be a problem with a blockage, overfilled dirt cotnainer, or problem with the filter.
Mar 27, 2011 | Dirt Devil M084500V Vibe Quick Vac Bagless...
Brought a dirt devil envision vacuum cleaner yesterday, assembled it and tried to use it. as i am running it, the dirt/dust seems to spread on the carpet/nothing seems to go in the dirt camister. The...
Fro what you say, the unit is blowing instead of sucking, There must be a pipe that is connected to the wrong outlet. Feel where there is suction instead of pressure, that is where your vacuum pipe must be connected.
Jan 30, 2011 | Dirt Devil Vacuums
Dirt Devil bagless upright. sucks up dirt in the front and spits it out in the back. I have taken it apart to check for visible clogs in hoses and checked belt and rollers all of which are fine. what next?
There seems to be no vacuum drawing the debris away from the brush head. Remove the debris canister to check for air blowing into it. Check particularly, the area where the brush head pivots off of the upright portion. Hope this helps!
Jul 26, 2010 | Dirt Devil M110000 Bagless Upright...
The vacuum is blowing out a lot of air, doesn't ****
make sure the dirt cup is empty and the filter cleaned .. once the filter is clogged it wont work ...make sure everything is assembled correctly to seal the cup ... this nice little vacuum should work good except on deep carpet ..
Sep 28, 2009 | Eureka Boss SuperLite Bagless Upright...
Lost suction
TOSS IT and forget it! I have never used a hand vac that worked that was worth the effort of turning it on .... I suggest they are all junk ... I found very few vacuum cleaners ... actually **** especially anything made by dirt devil ... I do have a bagless Bissell 6579-2 that I purchased 4 years ago at walmart for $49 ... It outperforms any vacuum I've ever used, including my worthless Shop-Vac that I paid a lot more for ... this Bissell vac SUCKS ... It could **** the barnacles from a steamship!
Apr 28, 2009 | Dirt Devil Vibe AllPurpose Hand Vacuum...
The Dirt Devil 085850 doesn't pick up anything!
the intake hose is clogged thats the clear looking hose that comes up from the bottom on the back side.you will need a coat hanger wither the end bent so its rounded.on the back where you sere the clear hose it conects to a fitting that is held in by one or 2 screws take them out and work the coat hanger down through the intake hose.you should be able to push the clog out through the bottom
Dec 04, 2008 | Dirt Devil Featherlight Bagless Upright...
Help!!!!
it's likely wrapped around the brush
pull out the roller and un tangle it
Aug 12, 2008 | Dirt Devil M084600 Dynamite Bagless...
Dirt Devil Breeze-Bagless Vacuum
You probably have a clog either in the hose , wands, or the dirt inlet by the brush roll.
Mar 08, 2008 | Dirt Devil Breeze Canister M082550 Bagless...
Dirt Devil M087700SV Bagless Upright Vacuum Logo
482 people viewed this question
Top Dirt Devil Vacuums Experts
Roger Potts
Jim Parker
Jim Parker
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
