Question about ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth...
Bios not detecting bootable harddisk
I have two sata hard disks installed in my pc one is 160gb hitachi and second is seagate 500gb windows xo pro service pack2 installed bootable harddisk with core2duo 2.2 cpu.after having fresh reinstallation of xp bios giving error ntldr is missing press ctr+alt+del to restart and not detecting 500gb bootable disk.please help me to solve the problem and recover my valuable data from it.thanks
  • 3 Answers
Try bootlive
Posted on Jan 31, 2013
    President:
  • 1,257 Answers
Repair windows xp using bootable windows xp cd..
Posted on Mar 09, 2009
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Hard disk Not Detecting (Media Problem)
may be comming steps you solve your problem
check your bios settings on first bootable devices
check your ide or sata cable interfacing mother board correctly
check the power connections
also you want check this one is your os faulty,now you make master &sleve and boot anther hard drive
Jun 12, 2009 | Kanguru - 500GB Disk (Black)...
Hello, My Harddisk is 6months old seagate.It was working fine b4 4-5hrs and now i turned on my computer it says No Bootable Device Detected -- Insert boot disk Press any key.My HDD is also not...
Seems like the harddisk is broken, and it's not really fixable... The good news, however, is that after 6 months the warranty should still be acxtive, so you can send it back to Seagate and get a new one. I hope this answers your question, Yannick.
Jun 09, 2009 | Toshiba A75-S125 Satellite Notebook
Hitachi Desk star 500GB SATA drive
you can check the jumper, is it on the right place?
besides, some motherboard is indeed do not support hard drive with large size on it...
Jun 08, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
Hard disk not detected but Cd Rom drive detected
reconnect data cable or sat cablew to harddisk
Aslo reattch power cable to it.
Then check in bios that if u have sata then sata must enabled in bios.
May 22, 2009 | Seagate Barracuda 40 GB Hard Drive
New SATA Hdd detection problem
Have you checked in the bios setup of the motherboard if your SATA ports are enabled?
Let me know if you need further assistance.
Regards,
Graemevm
Apr 19, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
Sata Harddisk Not detected in Post operation
Hi vijjis,
Make sure your SATA drive is connected to SATA port 1 which is the bottom port. Double check both the data cable & power cable. The data cable only connects one way at the board & at the drive. Same for the power cable. Your SATA drive must be listed in the bios menu & you must list the SATA drive with-in the boot order. If your cabling is all correct & you still do not see the SATA drive in the bios menu than the onboard SATA controller is defective. This can not be repaired because it is integrated into the board. It will not hurt to clear the cmos. See page 15 in your manual. Your board can only run SATA 1.0 = 150MBs. If your Seagate is pinned for SATA II = 300MBs, change the jumper on the drive. (This may or may not work). See if the bios list the drive.
One other option, you can buy a PCI SATA controller.
Here are a few; http://www.google.com/products?q=Promise+pci+sata+I+controller&btnG=Search+Products&hl=en&show=dd
Link to Mercury P4VM800M7; http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=644#
Good luck vijis!
Thank you for using fixya.
Mike
Dec 11, 2008 | Mercury P4VM800M7 Motherboard
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
My motherboard can;t detect my harddisk.....
Hi modjoguy, the bios must see your SATA hard disk before windows can see your SATA hard disk drive. To check this please press the delete key every two seconds as soon as you power on the system. (Note 1: Some motherboards that do not show the SATA II drive while in the bios may need its jumper set to SATA I in order for the bios to see the SATA drive). (See the drives large white sticker on the hard disk drive for SATA I location of jumper).
(Note 2: Gigabyte GA-K8VM800M rev 2.x & Gigabyte GA-K8VM800M-RH motherboards use the same manual). The Gigabyte GA-K8VM800M rev 1.x manual is slightly different, thus page numbers differ from the other two above.
Here is the link for all three: http://www.giga-byte.com/Search/Search_List.aspx?Keyword=K8VM800M&SearchType=Spec
The bios main menu will open. Open your manual (rev2.0 & RH) to page 38 & read under the listing, "IDE Channel 2/3 Master". The idea is your SATA drives should be listed at 2/3.
Once they are seen you need to open Advanced BIOS Features page 40. You can load the advanced bios features by pressing "Ctrl+F1" keys. You must list the SATA drive you want as the primary hard disk drive (Usually its the model number of the drive), that will have windows installed on it.
Good luck modjoguy!
Run into a snag just post it here.
Mike
Sep 01, 2008 | Gigabyte Computers & Internet
Does Asrock P4VM8 support 500GB SATA hard disks?
near the interface port of the hard drive you have to put a jumper that limit the connection speed from 3.0giga per second to 1.5giga per second, I think that would solve the problem because the hard drive speed goes to 3 giga per second and the motherboard p4vm8 serial ata port can support up to 1.5giga per second.
Jun 23, 2008 | Asrock P4VM8 Motherboard
ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth... Logo
255 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
