I have been told it is dust inside the projector and have replaced bulb but problem persists. How do i clear the dust. Thanks
SOURCE: how achieve maximum resolution acer projector
When you connect a source to the projector, the unit will match the resolution input to it. As long as you don't exceed the max resolution, which is considerable, the unit will display it. Go into the menu and select auto-image to have the projector give you the best quality image. Hope I helped you!---Rick
SOURCE: Is there a Manual or handbook for Acer X1160PZ
Click on the link below to open an online manual in pdf. If you want to save it first, right-click on the link and select, 'save target as'. The manual is in english.
Acer X1160PZ Projector
To download the manual in other languages, visit this page and select your desired language.
SOURCE: acer projector not clear on screen having many
Firstly, try the focus function on the lens...
If spots are still present, then there is either:
a) foreign particles inside the lens
b) the LCD panel/s (guessing it's LCD, as you did not specify) have dead pixels
c) the colour filters are damaged
Cheers,
"If this has helped you in any way, please rate this solution" :-)
SOURCE: my acer X1260 data projector one day had a
Sounds like a technical problem, no matter how long I've had this I would call the manufacturer and try and have them troubleshoot and then possibly have it looked at or replaced without you having to fork over any money.
