Question about Galaxy Radios DX-2547 40-Channels Base CB Radio
No rx the radio will talk but you cant hear one thing no matter what you turn nothing anyone got any ideas plz help me
  • 2 more comments
  • daylonrrober
    daylonrrober Mar 09, 2009
    this is on a uniden washington base by the way
  • daylonrrober
    daylonrrober Mar 13, 2009
    antenna is a a99 rg8 large coax uniden washington 8719 radio swr is 1.5 this is radio has about 100 feet of rx nothing more
  • daylonrrober
    daylonrrober Mar 14, 2009
    very true but no kids around the radio . it was working fine put it in a box for four years and when it was pulled out this is what it is doing i have no clue
  • james morgan May 11, 2010
    tell me more about the antenna, coax, radio. it sounds to me as if the coax could be shorted or the swr is really high. check the swr and let me know?
  • 40 Answers
So the swr is fine antenna has not been hit by lightning i assume as the swr would be all wacke out check to see if the rf gain is turned all the way down maybe if you have little ones they play with everything as i know all so well. or mabe the squelch was turned allt the way up if either turn squelch down all the way and turn the rf gain all the way up if not the audio chip on the rt side of the board could be shoted out if the radio has pa put switch to pa with external speaker attached key mic and talk if you here yourself talking the chip is good. by the way has the radio been tweaked any time recently it may be also alignment problem??
Posted on Mar 13, 2009
  • james morgan Mar 15, 2009
    does it have a 5 pin connectro on the mic end if so remove the small screws and chec to see if the recieve wire may be broken if so just resolder it back to pin 5 on the mic plug.
    james
I cant hear the caller.
have you tried speaker phone sometimes I have to turn my phone off totally then turn back on give that a go .
Mar 04, 2015 | Cell Phones
I can talk but cant hear
Check your Code setting. Both the frequency and the code must be identical for the units to communicate. Shut off any special features and keep the radios at a simple setting until you get communications back.
Apr 02, 2014 | Motorola Walkie Talkie 2-Way Radio
I can talk through one device and hear fine on the other, but cant hear anything when i talk into the other device
verify, either the operating frequency is not pair/same with the other radio, check the default frequency, tx/rx on the simplex mode should be the same frequency
Nov 21, 2013 | BellSouth Radio Communications
I have a General Lee radio. Bought it used from a pawn shop for a really good price ($70, don't think they know what it is). I turned it on worked great, for maybe 12 hours off and on. The next day it...
depending on how old it is, it could have bad caps. Could be the switching transistor, mic... Any number of things. It is the kind of thing where you have to start checking things down the line looking for the issue. Start with the simple things like the mic, cold solder joints. Look for obviously burnt parts. After that it gets a bit more technical checking parts in the TX section.
Hopefully its just a bad mic wire which would cause the radio to have no RX. Try a new mic. Good luck!
Aug 11, 2011 | Radio Communications
Radio transmits fine but the receive volume is way down. Can hardly hear it with volume turned up full.
If you have talk back in this radio.( you hear your self through the radio when you transmit) then its a good bet that the RX wire in the mic plug has broken off.
The mic switch is responsible for putting the radio into receive mode when you release the key. If the RX wire is broken, the radio will not go into receive.
Normally when this happens you have no receive at all no matter what, but you will have very low sound if you have talk back installed in the radio.
Because of this, if you have talk back in your radio, and the volume is faint even at full blast, its a good bet that its a broken RX wire in the mic cord or plug.
You can attempt to see if the break is at the mic plug. if it is, you can re solder it and it will solve your problem. If you have no clue, then you can just go buy new 4 pin mic.
Nov 14, 2010 | Uniden PRO510XL 40-Channels Base CB Radio
I have a galaxy dx 66 some time I can hear well but most times the audio is real low an the talk back is low if any an no matter what the echo is set at the talk back stays at a faint same. I'm running it...
on a galaxy the mic will not hurt the rx.. nor will echo time/speed change anything. on modulation. there is a problem. i do have time for my customers if you want me to look at it... can look at it and give you a quote. the parts are very cheap for cbs. it just the time cost.. i wouldn't spend more than $45 on it myself. when new exports start @ $199 for a similar model.
Nov 03, 2010 | Galaxy Radios DX-66V Base CB Radio
My general lee cb radio is turning on and displayng all lights but it will not talk at all i cant hear anyone talking and the cant hear me what should i do? i have already checked ground, mic. and antanae...
At that point if you've checked everything else throughly..like the mic, and the coax, and the antenna and the mount, and still nothing? You may possibly have a radio that needs to go to a repair shop. Actually I take back my last sentence....with a radio like the General Lee, its worth quite a bit of money, and if all obvious things are checked and still nothing I'd recommend having a local radio shop open the hood and take a look. I've had many people tell me that there are no radio shops to bring thier rigs to. So if your in the same boat I'll tell you what I told them...call you local police department or sherrifs office and ask them who does the work on their radio system....(just don't call them on the 911 line) I'm just wondering what your SWR readings were when you were using the radIo? Did you use an in line meter, or the one on the radio....cause I'm guessing your levels were high and you didn't recalibrate it and burned the primaries....sorry I don't have an easy fix answer for you....keep me posting on your progress I'm kind of curious
Apr 20, 2009 | Radio Communications
I cant hear anything that has sound on my phone.
Same problem with My 810i.
Problem is speakers are out of connection from the board.
Need to open cell and connect properly to the board.
Mar 20, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Cant hear people on killzone, and COD:3. help me please!
gaaaaah!!! i cant talk either but i play area 51! some games they can hear me...but i cant talk on area 51!!!!!!
Feb 01, 2007 | Logitech (980174) Headset
Galaxy Radios DX-2547 40-Channels Base CB Radio Logo
207 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
