Question about Bionaire BCM7207-U Humidifier
I need a owners manual for a Bionaire digital Cool Moisture humid
Model # BCM7207
  • 114 Answers
Http://www.bionaire.com/Manuals/MANUALS/BCM7307-U_43_88825170.PDF
i do apologize for the inconvenience. out of everywhere that i have looked this is the closest manual that i could get to your unit. if this helps that's great. if it doesn't i do apologize and let me know i will keep looking.
Posted on Aug 21, 2009
I need a manual
Try google.
Humidifiers Instruction Manuals at Bionaire.com.
www.bionaire.com/...manuals/humidifiers/humidifiers-manual.html
Browse our Humidifiers Instruction Manuals to find answers to common questions about Bionaire® products. Click here to view on our FAQs now.
[PDF]Crane Owl Cool Mist Humidifier Owners Manual - Sylvane
Dec 18, 2015 | Humidifiers
Model RCM-832. On/off switch works, blows air but no moisture seems to come out. I left it on for at least one day and the water level in the tank remained the same.
First check humid-stat setting make sure that the room is not above setting. Second check that float(water level) switch is being made. Hope that helps
Feb 08, 2011 | Robitussin Cool Moisture 1 Gal. Humidifier
How can i change the filter in my bionaire model bcm 7207
on that model that you have you need to turn the unit off , take the water tank off, then the base where the fan is should come off. under the main base the filter will be under that. all you do is take the old filter off and put the new filter on. if you have any other questions please let us know.
Feb 26, 2010 | Bionaire BCM7207-U Humidifier
How can i change the filter? I bought a BCM7207- used, and has the filter separate. where does it go?
the filter goes under the base. when you take the tank off you should be able to remove the reset of the unit off the base. inside you will see a round part that has your current filter on it. that's where the filter goes. now if there isn't a filter on it already and you have one that's where you put it. if you have any more questions please feel free to ask.
Aug 27, 2009 | Bionaire BCM7207-U Humidifier
I need a manual for a Bionaire digital Cool Moisture Humidifier Model #BCM7207. How can I print one off from the computer. Jan Sitter
Please visit website for Bionaire. Direct link to product manual page is http://www.bionaire.com/Support.aspx?c=pm. Enter your model number.
Aug 05, 2009 | Humidifiers
Air/no moisture
the reason why you might not see the moisture coming out cause it's a cool mist humidifier. to test your humidity in your house you might want to get a humidistat which will letyou know if your getting the humidity in your room or not. now if it's a warm mist you will see it but it's a coolmist so you won't see moisture coming out.
Jul 16, 2009 | Hunter 33201 Humidifier
I need help
amazon.com has the manual for you to download or purchase. and also does the bionaire website. which is www.bionaireproducts.com
Apr 22, 2009 | Bionaire W7 Humidifier
Replace humidifier filter
turn the unit off then take the tank off then the base which is the fan portion and the filter fits right there.. if it's a round filter then it slips right on. now if it's the squares they will slip into some slots and usually they will take about 4 if that's the case. if you have any other question please feel free to let me know.
Jan 09, 2009 | Bionaire BCM7207-U Humidifier
Fan is running but humidity is not changing
Q: My unit has been running for several hours. I hear the fan spinning, but I do not notice the water level in the tank decreasing.
A:
First, check the filter to ensure it is wet. If the pad appears dry, remove it from the Base and gently rinse under cool water. Reposition wet filter in the Base. You may also want to note the current moisture level in your home. If the humidity level is over 60% the unit will not put out much moisture
as your air is already saturated.
UV bulb and filter are user replacement items
see manual from my other post
Owners manual LINK
Comment by Soulvisitor, posted on Jan 20, 2008 You should notice moisture on the widows in the room after unit has run for awile, this unit carries a 3 year warranty. More info coming...
Comment by Soulvisitor, posted on Jan 20, 2008 see this
4b54ac1.jpg Comment by Soulvisitor, posted on Jan 20, 2008 If water level in tank is dropping and fan runs then I'd say it is working.
OK?
Comment by Soulvisitor, posted on Jan 20, 2008 Q: I hear the fan turning, but I don’t see any mist. Is my humidifier operating properly?
A:
Dry air is pulled through the system and a fan disperses invisible, moisture balanced air. There is no
“mist” emitted. When operating normally you will feel only cool air coming from the unit. Monitor the
water level in your Tank/ Base. If you notice a decrease in the Water Tank over 24 hours then the unit
is operating normally.
Dec 02, 2007 | Honeywell HCM-300T Humidifier
Hunidifier doesn't add enough moisture to air
here is the link to the manual for the w7 - they suggest a replacement wick filter would solve the problem due to bacteria or mineral build up - i would expect this to solve your problem as the only way these wicks can not soak up the water to the top is if they are clogged or the tank is empty. try the cleaning routine on page 9 first - might be enough but the wicks probably will need replacing soon anyway. http://www.bionaire.com/manuals/W7_English.pdf Hope this helps :)
Mar 08, 2007 | Bionaire W7 Humidifier
Bionaire BCM7207-U Humidifier Logo
409 people viewed this question
Top Bionaire Humidifiers Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a Bionaire Humidifier Expert? Answer questions, earn points and help others
