Question about Dell E228WFP LCD Monitor
I have same problem despite truning off screen saver and setting power options to NEVER SLEEP! I have same dell monitor, running wondows vista basic in dell vostro! anyone with a solution. this PC is less than 1 yr old. thanks so much. chris
    Problem Solver:
  • 7 Answers
If the problems happens on another computer then call dell to get the problem resolved. You could also go into the system setup by pressing F2 when the computer loads up and see if it happens in their, or you can also put the known good monitor in your system and it you get the same problem the problem is with the computer and the issue is either a hardware or software issue. If the problem happens in the system setup or during the diagnostics then the issue is hardware. Please call dell tech support if you find out the issue is points to the monitor and we would be glad to replace the monitor, if the monitor is not tied to the system(not in the order details or was purchased later) then the monitor has a 3 year warranty, if the monitor was purchased with the system , the warranty is the same as the system or if that warranty more than 3 years than the warranty for the monitor is still only 3 years. Thanks and please reply back if you still need assistance.
Posted on May 14, 2009
Dell Inspiron 530s Desktop fan motor keeps running
It\'s NOT the fan. Check the power save settings on the computer ITSELF. Check your BIOS settings as well. Inspirons ALL do the same thing with waking up.
Nov 05, 2013 | Dell Inspiron 530s Desktop Computer
How do I turn off the sleep mode on my monitor?
Control panel Power options adjust time for monitor time to sleep you can adjust 5 minutes to never the option available same can be done for hard disk. This is necessary as even monitor is active and when hard disk goes to sleep you may end up in same situation
Alternatively you can activate screen saver by
right click on desktop, settings screen saver choose screen saver set time to activate screen saver.
Sep 03, 2011 | Computers & Internet
How can I disable my monitor's sleep mode? I don't want the screen to go black, I want to be able to see the screen saver as it cycles. Thank you.
You can do this in the Power Savings options with Windows. For Windows 7, rght click on the display (anywhere with no icons or running programs) and choose Personalize. Click on Screen Saver in the lower right hand corner. Adjust the Wait time for the screen saver if desired and click Apply. Then click on Change Power Settings. This brings up the Control Panel > Hardware and Sound > Power Settings. Then click on Edit Power Settings for the active power plan. (For desktops it is usually the balanced power). Then change the setting for Turn off monitor to Never when plugged in. Also change the Sleep time for the computer to Never. You can do the same for when on battery but it will shorten the length of time that the computer will be able to run on the battery for laptops. Then Save Changes and close the windows.
For older versions of Windows, these advanced power settings are also available from the Screen Saver settings page but details may differ.
I hope this helps.
(for most monitors, as long as the computer is sending a signal the monitor will stay on)
Dec 23, 2010 | Dell 22" SP2208WFP Widescreen Flat Panel...
My hp L1506 going to sleep again and again
Follow this instructions to disable sleep mode
In windows XP
1)Right-click the desktop, and select "Properties."
2)Click the "Screen Saver" tab, and click the "Power"
button at the bottom.
3)Change the option next to "System Standby" to
"Never" for either "Plugged in" or "Running on
batteries" or both if that is what you want. Click
"Apply," "Okay" and "Okay" once again to close the Display Properties dialog.
In windows vista
1)Click the "Start" menu, and then click the Control Panel.
2)Click "System and Maintenance," and then select "Power Options."
3)Select "High Performance" to disable the overall sleep mode. The monitor will still go into sleep mode unless you click "Change Plan Settings" and disable all sleep options.
In windows 7
1)Click "Start," and then select "Control Panel."
2)Double-click "Power Options."
3)Select "High Performance" under "Additional Plans," and then click "Change Plan Settings." Change all of the options to say "Never."
Dec 16, 2010 | HP L1506 15" LCD Monitor
Monitor goes into sleep mode as I'm working on it. How do I shut off/
How do you shut off sleep mode? I take it you're using Vista, as XP has "standby:" mode rather than sleep. You first right-click the desktop, then click "personalize." from there, click on "screen saver," and then "change power settings." from there, look on the left hand side of the window and choose the option you want to change. Probably, you'll want to "choose when to turn off the display." Hope this helps,
DH
Sep 22, 2009 | Dell E173FP 17" LCD Monitor
Computer asleep
If you go to control panel > display settings > Screen Saver > Power (win XP) or Control Panel > Power Settings (Vista).
This will allow you to turn off the sleep or change the amount of time until the computer goes to sleep or turns the monitor off.
Mar 26, 2009 | HP w1907 LCD Monitor
The video goes to sleep.. and I can only get it back by powering down and back again.,.,..what a pain..???
Hi there.
Go to the control panel, select power options and set the computer to never go to sleep, all the options and quick links are down the left hand side in Vista.
Good luck and thanks for using FixYa!!
Mar 11, 2009 | Dell OptiPlex GX280 PC Desktop
Monitor "sleeps"
There are two places where the sleep time can be affected, both of which are accessed through the Control Panel that is normally an item on the Start menu.
Check the Display folder first and look for Screen Saver. This can be turned off completely or set to longer delays. The second, is the Power Options provided more for laptop users to conserve battery life but also can control the shutdown of your monitor.  Power Options aren't too important to desktop machines but the options are still listed.
Dec 25, 2008 | Dell E173FP 17" LCD Monitor
Dell E178FPf LCD monitor goes to standby and won`t come on again
Check your Power options in Windows.
right click on the desktop. select properties, Gop to the screen saver tab, click on the power button at the bottom right and check to see if its set to turn off or standby the monitor, turn this off.
Keep the screen saver on and set it for like ten minutes.
Also, on the monitor itself, it may have a sleep or power save option set as the default. check all the monitor settings on the actual moniotr itself.
Mar 31, 2008 | Dell E173FP 17" LCD Monitor
Dell E228WFP LCD Monitor Logo
142 people viewed this question
Alun Cox
