Question about Epson Stylus Pro 9600 InkJet Printer
00010020 error my epson 9800 is showing error 00010020.Can i know how will i remove this error on the panel shows error 00010020. Thanks
  • 412 Answers
Try this may be it helps you --
00010020 CSIC read / write --
Just like any other mechanical equipment, a printer requires attention to keep it running smoothly. So, just like when the spanner light illuminates on your cars dashboard so does your printer, but instead of a spanner the error 00010020 will appear on your control panel LCD which is informing you that there is a problem communicating with an ink cartridge. This can be caused by a faulty ink cartridge chip or bent pins. This problem can be undertaken here at Large Format Repairs for the Epson Stylus Pro 3800 right upto the beast that is the Stylus Pro 11880.
Posted on Mar 09, 2009
Epson 9800 Cleaning Unit Replacement
you don't need to replace any thing just before on your printer press and hold Down, Right and enter buttons on printer panel and than on the printer after on leave the pressed buttons its show a new menu on it press down on adjustments and than enter again press down on counter clear and than enter again reset it than restart printer. thanx
Jan 08, 2013 | Epson Stylus Pro 9800 InkJet Printer
Epson stylus pro 9800 - service call error 00010020
Hi, I would suggest that you take it to your nearby epson trained technician who can fix this issue. as this issue is related to the ink cartridges and its pins....
Please feel free to ask for more help :) thank you...
- Always there to help :)
Nov 29, 2010 | Epson Stylus Pro 9800 InkJet Printer
Ink shows empty when toner is not even close to empty
there is one thing that if you refill the cartriage and then use again then still ink indicator shows low ink as its' ckt is designed so.
there is no problem you can print easily.
your printer will show correct ink level when you put in new cartriage.
but remember one thing that if your printer stops printing and shows message on computer that no ink in cartriage ,, then you need to reset printer counter, (this resetting process is present in your printer manual)
so no problem in printing, it shows low ink because the circuit inside it is designed soo.
so that you purchase new cartriage.
(remember : you need to reset the counter , refer to manual)
Jul 09, 2009 | Epson Stylus Pro 9800 InkJet Printer
00010020 error
CSIC read / write error - this is the chip on the cartridges and maintenance tanks
Dec 17, 2008 | Epson Stylus Pro 9800 InkJet Printer
000100200 error
Remove the printer in printers and faxes and reinstall it with your original install cd
Nov 01, 2008 | Epson Stylus Pro 9800 InkJet Printer
Stylus pro 9800
you have left it on sheet feed what you need to do is press the button on the top which is furthest to your left until it shows the paper until the led panel shows a pic of a roll of paper with scissors
Oct 06, 2008 | Epson Stylus Pro 9800 InkJet Printer
Epson service call error message 00010014
The 00010014 error code indicates that the Ink System Pressure Sensor reports low pressure.
This error usually is caused by an Ink Cartridge that leaks pressure.
thanks for rating
Jan 09, 2008 | Epson Stylus Pro 9800 InkJet Printer
Epson Stylus Pro 9600 InkJet Printer Logo
529 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
