I need a setup disk for Technicolour TG587n home network gateway
  • 7,627 Answers
How can I set it up using my ipad
Home networking explained part 5 Setting up home router
You will need a wired ETHERNET port to perform the initial setup of the Gateway and IP address.
As the ipad would be configured to access the router at the first place, it is not feasible to setup the router at the first place with ipad.
May 25, 2016 | Computers & Internet
Is the Motorola SBG900 cable modem gateway a router- that is will it enable file sharing between the computers that share the gateway (one wired, one wireless). If so how is this set up?
you should be able to set up a home network you will have to enable file sharing, if you run through the network setup wizzard in the control pannel it should be fairly straightforward
Jan 21, 2011 | Arris Surfboard SBG900 Modem Cable Modem...
I just installed the internet at home from mediacom and i needed to plug my d-link router to have a wireless network at home and i dont have the configuration disk for my router and i dont know how to make...
You NEVER need that CD-ROM disk. :-)
Use an Ethernet cable to connect from a LAN port on the router to the network-port on your computer.
Click Start.
Click Run.
Type CMD
Press Enter.
Type IPCONFIG
Press Enter.
Look for output similar to:
Default Gateway . . . . . . . . . : 192.168.123.456
Start Internet Explorer.
Type http://192.168.123.456 (or whatever value that you saw).
Login to the router (ID: admin, password: [blank]).
Click to run the "Wireless Networking Setup Wizard".
Enter an SSID.
Choose an encryption-level (use: 'WPA').
Choose a password for your wireless network.
Save the changes.
Disconnect the Ethernet cable, and click "View Available Wireless Networks". Connect to the SSID that you chose, and enter the password.
Oct 21, 2010 | Computers & Internet
Roomate controlling wireless router...gateway.2wire.net no one can get any work done he controlls all speeds and so forth please help
You can adjust settings by going into 2Wire Router using your internet browser..
Default IP Address on 2Wire Routers: http://home/ This will take you to manager tools
Default Username / UserID on 2Wire Routers: None
Default Password on 2Wire Routers: Wireless
Default Netmask on 2Wire Routers: 255.255.255.0
If you can’t access management tools because of logon or password, you can reset to above
By following these directions
Apr 29, 2010 | Computers & Internet
Media read error check cable
Your computer tries to boot from various devices:
* CD-ROM
* disk-drive
* USB memory-stick
* 3.5" diskette
* network
in some order that has been configured (either at the factory, or by you, during BIOS SETUP).
So, if there is no media in the CD-ROM, no media in the diskette drive, no connected USB drive, then it will boot from either the network (if there is a network-cable that is connected to a "boot-server" system) or from the disk-drive.
So, is your disk-drive getting power?
Is the "data" cable between the motherboard and the disk-drive connected?
Is the disk-drive "dead" (not spinning) ?
Check your disk-drive.
You may need to purchase a new disk-drive, connect it, and reinstall Windows.
Apr 02, 2010 | Gateway MD2614u Notebook
Wear can i find the network key
in thsi
open internet explorer and enter your default gateway address over there and you can get it by doing ipconfig in command prompt
once you entered the default gateway it will open the home page of router
under that look for firewall or home network and you will find wireless over there and the wireless key would be there
OR you can contact the person who setup your wireless router
Mar 03, 2010 | D-Link WBR-1310/RE 54Mbps 802.11g Wireless...
System recovery on gateway laptop now no internet
do u have a switch enabling/disabling wifi?
if yes, turn wifi on!
Feb 05, 2010 | Gateway NX860X Notebook
My modem has gone haywire since i updated it, is new modem ideal?
THOMSON TG587n Home networking experience will definitely change with the Thomson TG587n. Up to twice the range and 3 times faster than 802.11g, TG587n enables real time multimedia content streaming over WiFi network everywhere in the house. try to visit this one
http://www.thomson.net/GlobalEnglish/Deliver/xDSL-Fiber/dsl-modems-gateways/residential_wireless/Pages/default.aspx
Jan 10, 2010 | Netopia 2247NWG-VGx Wireless Router...
Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
Computers & Internet Logo
199 people viewed this question
David Payne
David Payne
