Question about Lexmark X2350 All-In-One InkJet Printer
I waNT TO stop the registration reminder window
I want stop the registration reminder window that pops up every time I print something.
If you are on Windows 7, go into "regedit" and navigate to "HKEY_LOCAL_MACHINE\SOFTWARE\LexmarkInkjet\IjPrtSettings\OFN1" and then delete the following two keys:
CustomerConnectInstallTime
InstallTime
You can also manually do this in Vista, just its under "HKLM\SOFTWARE\LexmarkInkjet\IjPrtSettings\OFN1".
Posted on Aug 13, 2009
  • 2 more comments
  • PEX Tech Jan 17, 2011
    this worked the comment about changing the data to 1... didn't work.
    downloading the patch from lexmark... didn't work.
    DELETING:
  • tracy623
    tracy623 Aug 30, 2012
    If you are on Windows 7, go into "regedit" and navigate to "HKEY_LOCAL_MACHINE\SOFTWARE\LexmarkInkjet\IjPrtSettings\OFN11" and then delete the following two keys:
  • bksager
    bksager Jan 29, 2013
    Dude, you are the bomb!!! Thanks!!!!
  • jt4590
    jt4590 Apr 16, 2013
    You don't have to delete any. Just set the keys that say "Reminder" in the name to a value of 0.
Right-click on "ShowRegistrationReminder" and select Modify.
Change the Value data from 1 to 0.
Click "OK"
Posted on Aug 16, 2010
Http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:0:0:0
This is the support address for Lexmark - get your model and search "registration reminder" .. they've got a patch to download
Posted on Apr 17, 2009
  • danleywolfe Jul 08, 2011
    I started getting the popup when I moved to a new hard drive and moved from vista to Windows 7. They have a patch for W7 64 bit but not W7 32 bit which I unfortunately have. I will try the suggestions given on this page.
Go into "regedit" and find:
Then set the keys that say "Reminder" in the name to a value of 0.
In Vista, this can be found in: "HKLM\SOFTWARE\LexmarkInkjet\IjPrtSettings\OFN1".
Posted on Apr 16, 2013
I started getting the registration reminder popup after moving to a new hard drive and moved from Vista to Windows 7. Lexmark has a patch for W7 64 bit but not W7 32 bit, which unfortunately is what I have. I will try using suggestions given on this page.
Posted on Jul 08, 2011
4 Suggested Answers
  • 2973 Answers
SOURCE: lexmark x9350-every time I print
Carol, All such notices have the following options: 1. Register, 2. Register later, 3. Do not register. Or words to that effect. Select #3, Do not Register.
Posted on Nov 07, 2010
  • 10406 Answers
SOURCE: How do you stop the registration reminders for
After downloading the patch, did you actually "run" the '64RegReminder.exe' program?
Posted on Dec 28, 2009
SOURCE: Lexmark registration reminder pops up everytime i
64-bit.exe is only for 64-bit vista, not 32-bit, so it will not work! you have to track the registry reminder portion of that lexmark you have down. regedit its registry entry so it cannot autostart. will be looking for details.
Posted on May 23, 2010
Registration reminder wont go away
Please download and install the patch found in this article from the Lexmark website: Registration Reminder Keeps Displaying Every Time You Try to Print.
Feb 03, 2012 | Lexmark X6570 InkJet Printer
Tip
Removing Cyberlink Power DVD Registration Pop Up
Are you using Cyberlink Power DVD version 6 or later.
these version keep popping the registration menu quite often which makes it somewhat annoying if you don't want to register it.
here is how to stop the pop up.
Close the Cyberlink Registration pop-up and shut down the program.In Windows XP, Go to "Start" > "My Computer" > "C drive".
In Windows Vista and 7, Go to "Start" > " Computer" > "C drive".Click on"Program Files" > "Cyberlink" > "Power DVD"> OLRSubmission".
Right-click on the "OLRSubmission" folder and choose "Rename".
Type"Submission" in the box and press "Enter" to set the name.
This will disable the pop-up.
on Mar 03, 2011 | CyberLink Power DVD 5.0 (cd-powerdvd5) for...
Hi
Not sure but if you go into the add and remove in your pc it might be in there just remove that part of it, but be careful not to delete your driver.
All The Best: Pineworks
Feb 02, 2010 | Lexmark X5070 ALL-IN-ONE InkJet Printer
How do you stop the registration reminders for Lexmark X5070?
Go into Safe Mode, then Explore/Windows32 directory and look for any files with "Lexmark"; usually you can figure which files are the ones, even if they are not exactly named "Lexmark". Next, go into Start, Run, type Regedit you are now in the Register. remove only what you exactly need to remove .
Dial this structure:
H_KEY LOCAL MACHINE
SOFTWARE
MICROSOFT
WINDOWS
RUN
Single-click on RUN; in the Right pane are all the programs that are loaded to run on boot; look for any references to Lexmark and delete them. At least that will stop the Lexmark drivers from loading. While you are at it, click Edit, Find, type in Lexmark and search the whole Register for Lexmark references and delete them. It will help to clean out your register a little, but be careful. If you don't feel comfortable doing this, then it's really not necessary for your particular problem.
Dec 28, 2009 | Microsoft Office Home and Student 2007...
Dell Inspiron 1526 notice problem
Tell it "decline." ....end of problem ...but your computer is not registered.
Dec 26, 2009 | Dell Inspiron 1526 Notebook
I have Outlook 2007. Reminder problem
Quite often if you recreate the old appointment and then clear it out a second time you will rid yourself of the phantom reminder.
Aug 12, 2009 | Microsoft Office Professional 2007 Full...
Reminder has stopped working on MS Works calender
your anti virus is blocking the pop up for your reminders .... Try to restart the cmputer in windows safe mode ....
Ti restart in windows safe mode > When you computer restarts keep tapping F8 key till you get advanced boot option using up and down arrow select windows safe mode and hit enter
if it is working in windows safe mode then its your antivirus Soft ware blocking reminder pop up
Let me know if it works
Apr 20, 2009 | Microsoft Windows 98 for PC
Web cam registration
Sir,
Check when the popup is displayed below there is "Never show This message again" u just click the Check box and they never displayed the message again. ok
Thanks
Don't forget rate the solution
May 09, 2008 | Creative Labs WebCam Live!
Lexmark X2350 All-In-One InkJet Printer Logo
11,553 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
