SOURCE: IBM Infoprint 1332 paper jam
one of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
SOURCE: my printer is saying tray 1 paper jam but there is
I'm not sure how to fix it yet but I have two of these printers and if I use the tray from my other printer it works. I'm not sure what's wrong with the tray but it is the tray for sure.
SOURCE: Hello I am getting a paper
Error 241 indicated the printer was not able to pickup and pull the paper into the unit. This is caused by worn pickup rollers. The rollers are user replaceable. If you pull the paper tray out and look under the printer you will see the pickup assembly and 2 rollers , one on each side. When these rollers get worn down they can not pick up the paper correctly and you get the 241 error. The part number for the rollers is 99A0070 and you can get them here:
http://www.ccl-la.com/catalog/product_info.php?products_id=94
I hope this helps,
BuddyMc
