Question about HP Pavilion dv6000z Notebook
Cracked HP Laptop Screen
Hello, I've had my HP laptop since April of last year and just recently last week noticed there was a crck on the screen. Since then it has spread a lot. Is this repairable and is it under warranty?
    Problem Solver:
  • 15 Answers
Cracked displays are never coverd by normal warranty. Unless HP is aware of an issue on your model where this happens by itself, the service will not be coverd by warranty. You might want to check if you have any insurance that might cover it.
The LCD can be replaced, althogh it is usually quite costly(depending on the model). You can either send it in for service or do it yourself. If you dont have any experience with opening laptops I would recommend you send it in for service because of the weak plastic in the displayassembly that brake easily.
If you do want to replace it yourselfe I can find you the partnumber for the part. But im going to need the modelnumber from under the machine. It should look something like this AA111BB#CCC.
Posted on Mar 09, 2009
Display
The LCD panel is physically broken and can not be fixed. It can only be replaced. Somehow it got cracked. Sorry for the bad news...
Dan
Sep 12, 2008 | Computers & Internet
Adding additional screen makes it run slower
actually driving two monitors put a heavy load on your video processor
you probably need a memory upgrade at least double what you have
also try this
start
control panel
system icon
on left shows advanced settings(should be last on list)
look for video or visual performance button(should be first under general tab)
change radio button from Let windows decide to
best performance
that might help
Jun 09, 2012 | Dell Computers & Internet
Black Screen with 3 Beep Tones !
Probably memory stick(s). Are you comfortable taking a laptop apart to get at the memory sticks? If not, take it to a repair shop BUT at 9 months old, most units have a 1 year warranty. Contact the mfg with your purchase date, etc.
Oct 01, 2017 | Computers & Internet
Hi. I have a HP Pavillion dv7 Laptop. I've had it for approx. 2 & 1/2 years. For the first year I really didn't use it at all. I was working too many hours and working in a call centre, the...
The problem very likely may be dirt. Dust and dirt accumulate in the air passages and heat sinks in laptops often causing them to overheat. You say that the laptop was serviced by a technician recently.
He should have cleaned it's cooling system but he may not have. I have found that if the machine is not completely dismantled the dust and dirt blocking the free flow of air may not be visible.
Another possibility is that your cooling fans are waring out. These can be replaced. Also you can purchase high performance fans that are quieter, more efficient and last longed than the standard fans that laptops are supplied with.
Being as you have so much invested in this machine it makes sense to check to see if you have these issues.
Hope that helps.
Jul 06, 2011 | HP Pavilion dv7-1245dx Notebook
I have a acer 4740g laptop.I ve got display problem.It shows several lines and i cnt work on it.Recently it got little pressed on its display.Can any1 help me?
Hello shreejan_man
First thing to do is to test the screen. Also you have not mentioned if there is any cracks or damages.
Plug the laptop to an external monitor (any type will do). If the display on the external monitor is OK then it means the laptop screen is damaged.
If the display on the external screen is the same as the laptop then the problem is internal with the graphic chip or the video contacts.
this laptop is not that old since acer released this model last year. Check you warranty status on it. Some acer laptops come with two year warranty. Check the laptop carefully, if there is no sign of physical damage, (cracks, chips ...) then take it back as a warranty issue.
Good luck
please leave comment, vote if this helped.
Feb 24, 2011 | Acer Computers & Internet
I have a HP Pavillon DV 2000 (DV2315 NR) since
Bueno, amigo, al parecer la laptop está fuera de garantía, a menos que hayas obtenido garantía extendida. Las reparaciones de laptop son más costosas que las de las desktop, aún así te recomiendo que la lleves a un centro de servicio en tu país. Verifica primero que los técnicos posean experiencia en laptops.
Apr 15, 2009 | HP Pavilion dv6000z Notebook
Cracked HP laptop LCD
under warranty if it is a defect from manufacture or if you bought extended warranty from retailer, some policy's cover damage. Only covered if policy is still within time of purchase.
If it is not covered it will be cheaper to replace computer than repair.
You can search here for warranty from manufacture.
http://welcome.hp.com/country/us/en/support.html
Hope your covered. Please rate if this fixed you. Good luck!
Mar 09, 2009 | HP Pavilion dv6000z Notebook
HP Pavillion Laptop
HELLO. HERE IS SOMETHING YOU CAN TRY. START UP YOUR LAPTOP. HOLDING DOWN ON YOURSHIFT KEY. WHILE TOGGLEING ON F8 F9F10 AND SEE IF IT START'S IF SAFE MODE,.? LET ME KNOW.OK GOOD LUCK
Jun 18, 2008 | HP Computers & Internet
HP Pavilion dv6000z Notebook Logo
112 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
