Question about Nemco Heating & Cooling
Can I convert the ceiling fan and light fixture switch to individually controled switches
  • 82 Answers
Only if there are two circuits going to the fan. or two switch legs going from switch box to the fan.
Posted on Mar 09, 2009
Hunter ceiling fan/light unit install with 3 pole switches. there are 2 white, 2 black and one orange wires coming out of the electrical box. How do i handle the installation?
Not understanding, three pole switch is a wrong switch, wires in the ceiling or wall electric box.
Needed: What switch is existing and what wires are in the switch box and runs or groups in each run coming in as wire groups. Same for ceiling box, colors and wires in each run coming in.
Basically, remove the existing ceiling fixture and connect the ceiling fan replacing the fixture to the same wires the fixture was connected to. White to white, green or bare to green or bare, colored wire to fan's blue and black. Wired like this one switch controls both fan and light, on and off at same time. Use fan pull chain switch for individual fan or light control.
Oct 22, 2017 | Hunter Dryers
Why Ceiling Fan Fixture does not work
You get what you pay for! Shouldn't buy a store brand.
Jul 14, 2014 | Hunter 52" Ceiling Fan With Light And...
How to wire this fan
The wiring on most paddle / ceiling fans id such:
White = Fan and Light neutral or "common"
Black = Fan line voltage or "hot"
Blue = Light line voltage or "hot"
Green = safety ground
If you are replacing an existing light fixture - be sure to replace the ceiling box with one designed for use with a fan - as per electrical code. If the existing box had only 2 wires (or 3 counting the ground) that connected to the old light fixture and it was controlled from a wall switch, the wiring would be fixture white to ceiling white, fixture black and fixture blue to ceiling black (or red) and fixture green to ceiling bare ground or connected to the metal box. This would power both the fan and light whenever the wall switch was on and the pull chains for each were also on. This is also the preferred wiring for replacement of a pull chain type light fixture (no wall switch present).
If there are other wires in the box that previously were not connected to the old light fixture, using a meter or tester - determine if there is constant power between the ceiling white wire and any of the these other wires (test with the wall switch on and off to be sure). If you do have constant power available, you might consider using the wall switch to control only the light, and using the pull chain to operate the fan (or vice-versa). Simply connect the black (for fan) or the blue (for light) to the "constant power on" wire and that part of the fixture will work by pull chain only - regardless of the wall switch position. If the fan can be shut off by the wall switch, it is very important that the wall switch remain a toggle (or on / off switch), do NOT replace with a dimmer type switch.
If you'd prefer to operate the fan and light completely independently of each other - you can purchase a 3rd party fan & light remote control device for between $30 - $50.
I hope this helps and good luck! Please rate my reply. Thanks!
Apr 22, 2011 | Aloha Housewares (93645) Ceiling Fan
I am attempting to install my Hunter 21095 Westcott fan and am unsure of the wiring. Power is at the ceiling fixture which in turn feeds the next rooms fixture and the switch wire is also in the ceiling...
Black is for the fan motor which you connect to black(hot), black/white is for the light which you connect to the switched lead in the ceiling, the white lead from the fan goes to the neutral lead in ceiling, and tjhe green wire is earth ground and goes to the box screw in the ceiling
Jan 20, 2011 | Hunter (25417) Ceiling Fan
I have a fan with two light locations on it ( one above the motor almost at the cieling and the other at the base of the fan/light) I have 5 wires white, black, blue, orange and green. on the fan I have...
You should be able to trace the wires from the top of the fan and find where they go. Of course you should have green, black, and white in the fan and yes the blue should be for the light. some fans with dual lights will both be controlled by the blue wire, and some will have a separate, so it is very possible it is the orange. If you can't follow the wire into and through the fan and light kit you may just have to "experiment". You said there are "2" switches that control the fan, and they meet at the fixture box? If there are two switches then you will have two hot wires, usually one black and one red (but it could be two black), but you said your fixture box only has black and white. (unless you have 2 black and didn't mention that, then most likely the other switch is for another light, or wall outlet. You may need to trace this to find out for sure. If you have separate switches for the light and fan, then Great! you can hook the fan to one and the lights to the other. Otherwise you'll have to hook fan and light both to the one switch and control them with pull chains. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 01, 2010 | Westwind Classic Hugger Polished Brass 52"...
Both the fan and light have ceased to function!!!
As an electrician, this is a fairly common problem with any kind of fixture - not limited just to paddle fans. The problem is likely a loose connection in the ceiling box, or even elsewhere in the circuit, as the chance that both the fan and light failed at the same time is very slim. Since the fixture is a paddle fan - when it is operated it causes movement and is a dynamic load - as a opposed to a static load that a non-moving simple light fixture would present. The constant movement can loosen a connection over time. Before we go any further, operate any speed control / light switch on the fixture itself to make sure they haven't been accidentally set to the off position.
Shut off the power. Loosen the screws on the cover or canopy that that will allow access to the wiring compartment in the ceiling. LOOK for anything obviously loose. You may need to have someone hold the fixture once you remove it from the hanger to see the connections - or simply disconnect the fixture wires from the house wiring completely. There may be 2 or 3 wires besides any bare or green ground wire that supplies the fixture. Photograph or otherwise mark the wires before removing the fixture wires.
Turn the power back on, and use a tester (preferably a meter) to see if power is present on the ceiling box wires that supplied the fixture. If present, the problem lies in the fixture wiring or individual fan / light pull chain switches. Wires do not fail along unbroken lengths unless cut. They will fail at places they are joined together. There may be a wiring compartment in the light fixture that has a loose connection. Inspect for loose or bad connections with power off and continue testing as above until you isolate the bad connection.
If there was no power in the ceiling earlier when the power was restored, there is a break elsewhere between the power source and the ceiling box. You'll have to look in switch boxes and outlet boxes in the room and possibly adjoining rooms to find the loose connection. It may even be in an adjoining room's ceiling box, too. This is a labor intensive job - and can take some time to locate and repair. Take your time and only turn power on when ready to check for the presence of power.
Of course, you could call an electrician to do the work for you. I hope this was helpful - good luck!
Aug 10, 2010 | Hampton Bay 52 In. White Redington...
Chain to light does not work
Most paddle fans that come with a light kit (or provisions to add one via plug / jack later) provide at least 3 wires (most times 4 though) that will need to be connected to the house wiring. Those wires are:
1) Green, or Green with a Yellow stripe - this is the grounding wire and is connected to the grounded metal junction box or other ground wires.
2)White - this is the neutral wire and is connected to both the fan motor and light fixture.
3)Black - this wire connects to the fan motor. This wire along with the white wire completes a circuit for the fan.
4)Blue - this wire connects to the light fixture. This wire along with the white wire complete a circuit for the light fixture.
Ideally, the junction box in the ceiling has a neutral, ground and both an unswitched power source *and* a switched power source. An unswitched source is always on (regardless of any switch's position) while the switched source is controlled by one or more switch(es) near a door(s). Use a meter or tester to determine which wires are switched (probably black or red) and unswitched (probably black but may be red, too). Label them or orient them in such a way that you'll remember which is which. Turn the power off.
Connect the paddle fan's blue wire to the switched wire, the black wire to the unswitched wire(s), the white wire to the other neutral (most likely white wire(s) and finally, the ground wire to the rest of the ground wire(s). Turn power back on.
Wiring in this way allows the light fixture to be controlled by the wall switch(es) and the fan by the pull chain on the fixture. Turn the wall switch on and pull the chain until the light turns on. You can remove the long chain once the switch turns the light on and off so it is not accidentally shut off at the paddle fan later. Change the fan speed from high to low and eventually off with the chain.
If you only have a switched or unswitched power source in the ceiling, you'll have to connect both the black and blue paddle fan wires to whichever type power you have in the ceiling (switched or unswitched). If you're using a switched sourced, that switch will have to be left on in order for the fan or light to work.
If you have wired in any of these methods already, it could be that the switch for the fixture has failed, and should be replaced with a like-type switch.
I hope this helps!
May 20, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Light will not shut off on fixture (replacement of ceiling fan)
One of the two cables in the ceiling box is power and the opther is a switch leg .. what you need to do is connect the two black wires together at the ceiling, connect the white power wire to the white fixture wire ,.,. connect the white switch wire to the black fixture wire .. put some black tape on that white to make it legal .
Sep 27, 2009 | Hampton Bay 52 In. Black Huntington III...
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Heating & Cooling Logo
Top Nemco Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Nemco Heating and Cooling Expert? Answer questions, earn points and help others
