Question about ASUS P4PE-X Motherboard
Power switch notworking ( ASUS P4PE-X Motherboard)
I connected the cpu ram and power supply then i tried to connect the on off switch but it wont work when i push the switch. the motherboards power indicator light is flashing green so i know that there is power. what do i do?
  • 158 Answers
Please refer your motherboard manual and fix the front panel cable including power button. After this if power button is not working than swap the power button cable and reset button cable.
And then start your PC by pressing the reset button.
Else you just recheck all the cable + RAM + CPU.
Posted on Mar 09, 2009
I have recently made a new computer and it just wont power on i have installed all the compents right and when i push the power button the cpu fan makes a few cirles(3-10) and then stops....If I try to hit...
Hi, Check whether you have connected the motherboard controls(power_button,rest_switch) correctly.Check it in your motherboard manual and also check whether the cooler fan on the CPU along with the heat-sink are placed properly and attached to the respective connectors. Thanks, C Rahul.
Jul 04, 2011 | Computers & Internet
Asus P5 GC-MX Board proccessor does not get power what parts should be changed
First, check if the connection from the power supply to the motherboard is properly inserted. If it's loose, that may be whats causing you to receive no power from the supply. Check the wall socket to make sure it works, as well as checking if everything is plugged in properly. If you are still getting no power, then it maybe time to buy a new power supply. If there is some indicator of power to the mother board , such as an LED or light that turns on when plugged in, there may be a problem with your power switch.
Mar 29, 2011 | ASUS P4PE-X Motherboard
Asus M4A785-M will not post. I have completely removed motherboard from case, removed all components except CPU (AMD Phenom II X4) and CPU cooling fan. When power supply (which I tested in seperate...
All I read properly .Please remove power supply from HDD and CD /DVD RW. If you face the same problem Open the mother board on a open place and try it again ,because there are some particles witch has made the short sercit in your M. Board.Cgeack all voldage socket plkaced properly,MAY BE CAN SILLY MISTAKE FOR 4 pin socket .
If you face same problem please install in another mother board .Post me please imediate next result.
Dec 12, 2010 | ASUS M4A785M (890552666775) Motherboard
When I power on my PC it shuts down during the POST. I have tried removing the hard disk, changing RAM and other add on boards but to no avail. Regards P. Keswa
I would disconnect everything. To the motherboard I would connect the power supply , one stick of ram , video card if there is not video intergrated on the motherboard already. Leave the cpu fan plugged in of course. Leave the power on button connected, disconnected all usb, audio, everything. Remember what you disconnected and where so you can reconnect later. After all this , see if you can get BIOS. If that didn't work I would switch the stick of ram out try again.
Nov 03, 2010 | ASUS P4GE-MX Motherboard
My power supply died (popped), so I replaced it (Antec SL350 with an Antec SL350S). However, when I turned on the switch on the back of the power supply, the motherboard powered up immediately (tower...
If you "popped" the power supply, I would check to see if the RAM might have taken a hit as well. Ram chips and CPU are sensitive when it comes to power surges. I would troubleshoot the system, unplug everything. you need monitor, power, cpu, and ram (1 at a time). Check to see if the system will POST. if you do get it to POST, start with 1 item at a time and see if the system will POST every time. If nothing happens, there is a chance you may have a damaged motherboard or cpu.
Mar 28, 2017 | ASUS A8V Motherboard
Asus M2N / Antec SP-350
Things to try:
1. Check that the cpu fan is properly connected to the correct port marked CPU FAN.
2. Make sure the power cables are connected correctly to the motherboard.
3. Test the button switch with a multi-tester to make sure that it tests good.
4. Make sure the power switch is connected to the correct pins on the motherboard.
5. With the computer off pop the cr2032 battery out and pop it back in after a few minutes.
6. Test the power supply with either another motherboard or a power supply tester.
7. Test the motherboard with another power supply.
8. If all else fails replace the motherboard I have had a bad one from time to time even out of the box, and if you have a spare cpu you may want to test with that also. Cpu's hardly ever go bad I think I have had two go bad ever, not counting power surges and storm damage.
Sep 10, 2009 | ASUS Computers & Internet
Connecting my PSU to my Motherboard
The bare essentials to start a computer are PSU, Motherboard, CPU, RAM and Video.
Its possible the PSU arrived DOA. Though I've only had 2 DOA PSU's in the 15 years I've been building custom computers.
Hope this helps.
Mary
May 21, 2009 | ASUS P5QC Motherboard - Intel P45, Socket...
Screen black out, but the cpu fan is running.
it could be two reasons.
1. your RAM has a issue ( try a different ram from a friends pc)
2. your Graphics card is having an issue. ( try removing & fixing back on, if it does notwork.. either get a friends graphics card & ifix on to your pc & chk or fix your VGA card on to another PC & chk if the VGA card works. either way you will find out what wrong.
let me know the out come.
hope it works
cheers..
Mar 19, 2009 | ASUS P4P800 SE (890552603657) Motherboard
Asus A8N-VM CSM wont boot, no fans come on or anything, green light comes on the motherboard, is the CPU dead? tried different ram still the same. any help would be great!
CHECK ALL JUMPER ON THE BOARD AND MAKE SURE THE BOIS RESET JUMPER IS ON JUMPER 1-2, SOUND LIKE A POWER SUPPLY PROBLEM NOT ENOUGH WATT TO RUN THE SYSTEM
2ND OPTION, REMOVE ALL WIRE AND ADDTIONAL CARDS, MIN. MEMORY, LEAVING 1 STICK OF RAM, VEDOI CONNECTION , AND THE POWER TO THE BOARD, CONNECT ONE WIRE AT A TIME AND RESTARTING THE MACHINE EVERY TIME UNTIL YOU FIND THE PROBLEM.
CANDYMANGANDY
Feb 05, 2009 | ASUS A8N-VM CSM (00610839133826)...
Not powering up
First test the MB with only the minimal components (ie. cpu + ram + vga card if not onboard). Disconnect all other components. If still not starting, try using just a single ram module, if you have more than one, to try & determine if one of them is faulty.
Dec 25, 2007 | ASUS P4PE Motherboard
ASUS P4PE-X Motherboard Logo
704 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
