Question about Hoover HTC243 Top Load Washer
Excessive lint using Hoover 500MD top loader washing machine
I clean the little lint bag every time I wash, however all my items still seem to come out covered with lint. Is there any other lint filter that I can check?
I suspect mayeb there's something under the agitator, but I don't know how to remove this either.
  • 1 more comment
  • Anonymous Apr 19, 2009
    i have the same problem
  • victoria386 Sep 12, 2009
    No idea as to wether belt driven or direct drive.
    I foudn the nut at the bottom of the agitator and got a special spenner so I could remove it, but even once the nut was off, I could not get the agitator off. Is there a special trick to it? I am convinced all the lint is stuck under there!
  • dionne68coll May 11, 2010
    top loader washing machines are they belt driven or direct drive
  • 3422 Answers
SOURCE: hoover 750L top loader washing machine
The load might be unbalanced, and will not spin at full speed as it could damage the machine. Try reloading the machine
Goodluck,
Dont forget to rate me as Fixya..
Posted on Jan 30, 2008
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
Machine unbalanced or belt is worn maybe
Posted on Apr 04, 2008
  • 188 Answers
SOURCE: cleaning washing machine filter
There is no filter on this machine. The gray gooey substance is sludge (dirt) build up inside the tub. This can be caused from using too much detergent or a detergent that is not HE (high efficiency).
You can try running an empty cycle using the hottest water available with products such as "washer fresh", "affresh" or a cup of bleach to remove the build up.
Remember to use a HE detergent and you only need about 2 tablespoons per regular load.
Posted on Mar 01, 2009
  • 69 Answers
SOURCE: How do I remove the agitator in a Hoover 500MD
Most Hoovers have a 10mm bolt down inside the agitator. Remove the fabric softener dispenser from the top of the agitator, and look down the centre of agitator. You need a long extension socket to undo the bolt (anticlockwise). Be careful not to turn bolt too hard- sometimes the bolt is seized where it goes into top of gearbox, and if you turn bolt too hard, you can break the bolt. Once bolt is removed, agitator just pulls straight out
Posted on Aug 25, 2009
rylee_smith
  • 8619 Answers
SOURCE: we have a problem with excessive lint on our
Hi
To resolve this issue you'll need to clean your top load washer. Try the steps mentioned below to clean it--
Remove the dispenser and spray with white vinegar. Then spray the agitator with it too. You can pretty much wipe it right out. Vinegar dissolves softener very quickly. The dispenser just wash out with warm water after the vinegar sits on it for a minute, and you hardly have to wipe at it at all. try adding bleach to the dispenser and clean it with a small brush.
The dispenser will pull off from the agitator and you can run hot water in it from the sink. The agitator is not as easy but has a 1/2" bolt holding it to the shaft. remove the bolt and pull up. but you can clean the whole washer with a cup of bleach and that will also clean the agitator. Now run a full tub of hot water and then add a cup of bleach with no soap. After the washer has filled up, then add another gallon of hot water and that will help to rinse out the residues that cause odors. then after that dont use too much soap and you wont have residue build up. Only use the smallest amount of soap that the cup has marked in it.
After performing all these steps if you still get lint on clothes then it is due to a clogged drain pump and/or drain filter.
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Posted on Sep 28, 2009
I HAVE A WHIRLPOOL TOP LOADER MODEL 3LSR6253E01 MY WASHING COMES OUT COVERED IN LINT. I CANT FIND A FILTER ON THE MACHINE IS THERE ONE? PLEASE HELP THANKS KATE
All washing machine have lint filters to protect the pump, but they generally have quite large holes and although called 'lint' filters, they are to stop baby socks and coins getting into the pump. They are always at the bottom of the machine behind the front kick panel on a front loader or under the agitator on a top loader.
If your washing comes out covered in lint, you need to find the item that is shedding it. May also be paper tissues left in pockets. We only have one item that sheds lint and that is a bathmat. We wash it separately.
Take a look at this video.
Washer Filter Plug Kit part 285868 How To Replace
May 26, 2016 | Whirlpool Washing Machines
LG fuzzy logic top loader leaves black marks on white. Happens when doing a large wash-eg; blanket -it looks awful. I'm thinking the insides might need cleaning? How is this done and with what product
If this is moldy looking you should use 1 cup of bleach in the drum with no clothes on the longest wash cycle with the hottest water. But I believe this is oil from the drive train and the seals on the bottom of the drum are going bad. When you wash something heavy like the blanket, it leaks.
Nov 25, 2013 | Washing Machines
After every wash the lent stays on the clothes
here are a few suggestions Two things that come to mind...1) Your wash time is too long. Unlike front loaders, top loaders clean quickly. No need to use the longest wash setting unless the item is really dirty.
2) You are overloading the machine. Items should move freely and circulate from top-to-bottom several times during the wash.
3) try using more detergent, One of the things good detergent does is keep lint (and dirt) suspended in the water and off your clothes. 4)http://www.ehow.com/how_2083872_clean-washing-machine-lint-trap.html
check that link for lint traps in washers
Jul 21, 2011 | Washing Machines
I have a Hoover 500mb, 5kg HD Top Loader washing machine. The problem I am having is the clothes always have lint and other stuff on them after being washed. I have tried taking the agitator off and seeing...
have you done a clean ,hoover have this built in you need to do every so often the filter could be clogged do a clean don't put anything in when your doing this ,how old is it
Jun 16, 2017 | Hoover Washing Machines
Does the hoover 200m 4.4kg top loading washing machine have a lint filter if so where is it
Hi just read your posting.It should be in the center of the agitator.Pull the center out and there should be a lint bag attached to it.Unfortunately they do not stop much lint from getting on the clothes.Hope this helps and please reply if you need more help.
Jun 17, 2010 | Hoover HTC243 Top Load Washer
Washer not cleaning clothes
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Next run your washer with 2 cups of bleach, hot water. After it starts agitating stop the washer & let it remain for 2 hours. Then continue the wash.
Try using powders for 'front loaders'
Apr 05, 2009 | Kenmore HE2 Plus Front Load Washer
Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Jan 13, 2009 | LG WFT1071TP Top Load Washer
Washing machine
The filter on your pump is probably clogged with lint and other stuff. Lift washer up a bit. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. Drain off excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water or a wet vac. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Nov 27, 2007 | Whirlpool GHW9150 Front Load Washer
Hoover750l
Please help
My Hoover 750 L Top Loader leaves a lot of fluff when I wash my dark clothes. I have been looking for a filter on it but no success. Any one have an answer please.
Sep 07, 2007 | Hoover Nextra HNF 3167 Top Load Washer
Excessive lint on clothes and smell
There is many solutions that work some. The best analogy I have seen is to reduce the wash time as the newer soaps are more efficient at removing dirt which also softens the fabric. Any excess in soap regardless of type in combination with water type will cause an odor, why is the contaminents in the water plus the junk on are clothes to be polite. It builds up under the basket and along the top water line in the tub plus creates a film from the tub through the hoses, pump and house drain. Lint is a product of excess washing and too much soap. Whirlpool stated for there front loaders no more than two TBL of liquid soap which is like 3/8 cup max for the old top loader. SearsTechToo
Apr 27, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Hoover HTC243 Top Load Washer Logo
394 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
