Question about Microsoft Xbox 360 Console
XBOX POwer outage?
I was playing on my xbox then it suddenly turned off. Everything was plugged in and the power supply box with the light wasn't on though what happen?
    Novelist:
  • 174 Answers
It is possible that is might have suffered a power surge, i would also check the fuse in the plug if the orange/green light is not on the power supply.
if you have checked this and still not working then try to borrow a power supply from someone and try that with your console - if it works then its your power supply that is dead.
www.fixmyconsole.co.uk
Posted on Mar 12, 2009
My XBOX 360 will not turn on. The power bar has a green light but pressing the eject button or power button on the console will not turn it on. We have tried plugging it in to a different outlet but that...
Hi christoph52893,
If the Xbox 360 power supply light is green, this means the Xbox 360 power supply is ok and it is an issue with the console itself. You will need to contact Xbox 360 customer support to service your console. However, if you have a flashing orange or yellow light, it means that your console is fine but instead there is something wrong with your power supply. It indicates that it's not getting enough power.
Hope it helps.
Thank you for using FixYa.
Jul 05, 2011 | Microsoft Xbox 360 Console
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
Xbox 360 is turning on for less than a second
Got kind of bad news , It is the power supply ,but it's the power supply
in side the box itself. It's more than likely a shorted regulator specifically
one of the 12 volt liner reg chips , I had to swap a few out to resolve
this a few times.
Rob
Jan 21, 2010 | Microsoft Xbox 360 Console
Red light on power box for 360
i have to personally dissagree with 'wildbear' :-)
well not actually dissagree but i think the problem will be at lot less technical than all the writing he has done.
a simpler check.......does the 360 'switch on' ??
i assume with a red light on the power brick it dosnt ??
the problem is more likely a faulty pin (terminal) inside one of the USB slots you have been using for either a controller charger or wired controller (or a usb memory stick to play music thru ur xbox??)......plugging chargers/wired controllers in & out of either the 2 front slots (behind the flap) or the 1 at the back can sumtimes bend one of the terminals causing it to touch the outer casing of the usb slot ?? if it does this it shorts the board of the 360 which in turn stops u powering up the 360 all together :-(
one of the signs of this is a 'RED' light on the power brick & the 360 not powering up at all !! but sumtimes the power brick light will stay orange or even green.....even with this fault ! it dosnt always turn red !
One way to rectify it is (un-plug the powere brick from the mains first) & unplug ALL USB CONNECTIONS TO THE 360 !! (controller chargers ect) & try powering up the 360 !! (after plugging it back in)
if this fails ur gonna need a torch & a little screw driver (or tweezers) un-plug everything from the 360 & look inside ALL usb slots you have used ! check to see if any of the prongs have bent accidently whilst plugging in & out chargers ect ..... if they have straighten them so they are not touching any of the sides of the usb slot....
after doing this ...plug back in and 'hopefully' Whoooop Whooooop :-)
hope this helps ??
failing this it maybe as wildbear suggests & its a problem with the power brick altho i very much doubt it ?? they normally way out live an xbox !
remember thumbs up if this helps :-)
Jan 01, 2010 | Microsoft Xbox 360 Console
Xbox 360 won't turn on
To troubleshoot this problem, try the following steps:
Examine the power indicator light that is located in the center of the Ring Of Light on your Xbox 360 console. If there is no power to your console, the indicator light is off and the fans are off.
* Press the power button. The power button and the power indicator light are located in the center of the Ring of Light on the front of your Xbox 360 console. If your Xbox is functioning correctly, the power will turn on.
* Press the eject button on your console disc drive. If your console turns on when you do this but does not start when you use the power button, there may be a problem with the power button or the console faceplate may not be attached correctly. Contact Xbox Customer Support for more help.
If the above step does not resolve the problem, examine the power cord where it connects to your console and to the power outlet. Disconnect and then reconnect the power cord at each end to make sure that you firmly connect the cord.
If this does not resolve the problem, see whether the power cord is plugged in to any device other than a typical power outlet. For example, the power cord may be attached to an extension cord. If this is the case, remove this device and then plug the power supply directly into a power outlet.
If the problem is not a connection problem, examine the light on the Xbox 360 Power Supply.
* A green light indicates that the power supply is functioning correctly. If the light is not green, contact Xbox Customer Support for more help.If these steps do not resolve the problem, your console needs service.
Sep 01, 2009 | Microsoft Xbox 360 Console
I have a Yellow Led light on power bar, xbox will not turn on
Here ya go! This should help you out, I have also had this happen to me. Don't worry, its nothing like the red circle of death.
http://xbox-360-problems-fix.blogspot.com/2007/11/xbox-indicator-lights.html
Hope this helps you out! Don't forget to rate me :)
Apr 09, 2009 | Microsoft Xbox 360 Console
Xbox360
Sep 06, 2008 | Microsoft Xbox 360 Console
Xbox shuts off
It may actually be that your power box has failed or died. If so than you cant do anything really.Sorry.
Feb 10, 2008 | Microsoft Xbox 360 Console
XBox 360 power problem
The power brick has most likely died.
Dec 14, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
127 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
