Question about Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo Drive
Where do you hook up the power strips from CD Brunner to computer
    Scholar:
  • 150 Answers
There should be a cable coming out of the power supply that will fit with the cable coming out of your cd burner.
Posted on Mar 09, 2009
Srtyws
The cheapest method of all.
Make sure your PC is plugged into a power strip and after windows shuts down just hit the off switch on the power strip.
Unless you want to shell out some cash for a new power board for your monitor.
Mar 11, 2010 | Sony SDM M51 15.1" LCD Monitor
Gateway M520X Plus will not power up?
This is a sample of what you can try to do to diagnose a non-starting computer, If these don’t work, realize that most likely a system board (motherboard) has failed or the actual power trim strip above the keyboard has failed.
  1. Unplug the computer, then take the battery out, push the power button and hold it for about 30 seconds. Plug the system back in (leave battery out) and push the power button. If it starts, Great! If not unplug go to the next step.
  2. You should still have the battery out and the power unplugged. Now turn the laptop over. Take off all the covers and pull out the hard drive and ram and wireless card. Find the screw that has a symbol kind of like this its the CD rom drive screw. Now pull the drive out. Pick one stick of ram and put it back in the computer. Flip it over open it plug it in and hit the power button. If it does not fire up then unplug it and switch the ram. Plug it back in and hit the power button again. If it doesn't start up, unplug the computer and go to the last step.
  3. Pull the memory out and find the screws that hold the keyboard on. There are symbols in the plastic there should be 2 screws holding it in. Now in the battery compartment, there are several screw at the back edge of the computer take them out and also the ones in the battery in the center strip. Some are silver and some are black. Once you have the screws out of the battery area flip the computer over and open the lid. The strip just below the LCD with the power button and controls will now be able to be lifted up. You will probably have to lightly get an edge started before it will come up. There should be several little cables hooked to it. Flip the control panel over and look for some screws holding the keyboard in. I think there's 2. Lift up the keyboard. Making sure there's nothing touching anything important and then plug the computer in. Carefully hit the power button and see if the computer tries to start. If it does try it will probably beep at you. Unplug it and put a stick of ram in it. Plug it in and try to start it again. If not, unplug the computer and Go to the next step.
  4. Carefully put the keyboard and control strip in place. Flip the computer over and loosen all the screws that hold the computer together. Flip the computer over again and pull the keyboard and control strip up again. Flex the inner aluminum plate that was under the keyboard lightly. Plug in the computer and then hit the power button. If it tries to start, Great! put it together again in the reverse process.
If it does not, there are 2 possible things I would suspect the Control strip or the mainboard. If you don't get the computer to start back up please put it back together so you remember where all the screws go. Even if you plan to get another mainboard put it back together.
Nov 08, 2009 | Gateway M520X Plus PC Notebook
Laptop does not turn on have tried a new charger but still nothing
Oct 24, 2009 | Acer Aspire 5500 5570-2609 Laptop
Sony CDX-CA810X / CD-playback drops aux amplifier
Do you have the remote turn on lead hooked up to solid blue wire from the back of the deck? Your amp shoild be hooked up to Bluw w/ white strip as the solid blue wire shuts off when the tuner is off, its used only for the power antenna.
Use Blu w/ Wht strip for amps
Jun 03, 2009 | Sony CDX-CA810X CD Player
No sound from my front and back speakers in my van ive got subs
Make sure that when you hooked up your 4 channel amp to the remote turn on lead it is the same as the sub. Only hook amps to the Blue w/ white strip. The solid blue is power antenna lead and will lose power when on CD, ipod etc and only stays powered when the Tuner is on. Hope this fixes your problem.
Jun 03, 2009 | Kenwood KDC-MP428 CD Player
No sub woffer when playing cds works fine with aux and with tuner
You have the amp turn hooked up to the power antenna lead. It needs to be hooked up to the Blue with white strip not solid blue.
Jun 01, 2009 | Car Audio & Video
Tuner works but when cd or i-pod are selected they indicate theyare playing but no sound.
Is your stereo sytem amplified? if so then the remote turn on wire may be hooked up to your power antenna turn on wire. The amp needs to be connected to blue w/ white strip.......not solid blue. The solid blue turns off to lower a power antenna when the tuner is not in use. Blue with white always stays on with tuner cd or ipod.
May 23, 2009 | Car Audio & Video
Computer boots up when plugged in,monitor powers down
hi there.......
it is the memory it has to be matched with the actual fsb of the cpu if its slower then it wont switch on.....
and some dell pc's wont work with 1gb sticks so accertain which ram is compatible with the motherboard
Feb 24, 2009 | Dell OptiPlex GX260 PC Desktop
Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo Drive Logo
46 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
