It sounds like you have low/no compression. To be sure use a compression gauge by screwing it into the spark plug hole, holding the throttle wide open and pulling 6-5 times. If it is reading less that 90 lbs on the gauge then you have a problem. Technically the saw should have 120-150 lbs, but it will run at 90 lbs. In the event that you have a low reading you will need to replace the jug, piston, and rings.
