Question about HP Compaq nc6000 Notebook
Where and what (sim card only, wireless card+sim card ??) to put into an hp nc6000 laptop to have benefit of what is yet inside (or supposed to be inside like the antennas ) and access to internet , msn...?
  • 41 Answers
A wireless card should be already be in that system. There is no SIM card. According to HP's specifications, your laptop should have one of the following wireless devices integrated into the laptop:
The HP nc6000 notebook supports a broad range of secure, integrated wireless LAN options featuring support for the latest industry standards. Integrated Bluetooth is also an option and can be combined with any one of the supported wireless LAN options. All integrated wireless LAN options Wi-Fi certified
Cisco Compatible Extensions support
Wired Equivalent Privacy (WEP) support up to 128-bit keys
Wi-Fi Protected Access (WPA) support
802.1x standards support including EAP-TLS, Protected
EAP (PEAP) and Cisco-EAP (LEAP)
Dual antennas integrated in the display enclosure HP W500 802.11a/b/g Integrated support for 802.11a, b and g
Up to 54mbps throughput performance
Advanced Encryption Standard (AES) support Intel PRO/Wireless 2100 802.11b wireless LAN Intel® Centrino™ mobile technology
Integrated support for 802.11b
Up to 11mbps throughput performance Intel PRO/Wireless 2200 802.11 b/g wireless LAN Intel® Centrino™ mobile technology
Integrated support for 802.11b and g
Up to 11mbps throughput performance Integrated Bluetooth Designed to the Bluetooth v1.1 specification
The full information is here:
http://h18000.www1.hp.com/products/quickspecs/11794_na/11794_na.HTML
If everything is working properly, all you have to do is find your local Starbucks or other WiFi hotspot and connect.
Posted on Mar 11, 2009
Wireless connection problems
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
Apr 19, 2012 | HP Compaq nc6000 Notebook
Je trouve pas les driver de ma carte réseau 'contrôleur Ethernet' de mon lape-top hp compaq nc6000 j'essaye tout les driver qui existe sur le site officielle de hp
I hope you understand English. The problem is not your drivers it's the graphics card on your motherboard. It's a common fault with these. The graphics card, ethernet controller and wireless card all run from the same part of the motherboard and they overheat very easily making them stop working properly.
Jan 14, 2011 | HP Compaq nc6000 Notebook
Reloaded HP nc6000 laptop with Window XP Pro and cannot seem to find the driver needed for the wireless NIC....the wireless NIC does not even show up and there are no devices with a ?
Sounds like you may need to get another wireless card if the one you have isn't showing up.Alot times that's how it will do when it goes bad.
Jan 05, 2011 | HP Compaq nc6000 Notebook
Just bought this laptop - cannot get the Wireless
If wireless card is listed in device manager under network adapters-that means you dont have to install it. If you running on vista, go to control panel and find ssomething like wireless contol manager or wireless assistant and see if its not disabled there. may also be disabled in bios settings. on windows xp-check if windows has possibility to manage wireless networks or its blocked by third party software. for example i use bt voyager wireless card and its managed by bt software. built in cards are likely managed by windows. type services.msc in run box and see if wireless zero configuration service is enabled.
Oct 21, 2009 | HP Compaq nc6000 Notebook
My HP NC6000 network cards aren't working now but device manager says it's working properly. When I connect wireless can't find any network and same for the wire network connection. I just got back from a...
try uninstalling the wireless driver wit the wired & reinstalling them if problem persist...backup ur files & do a clean installation of your Operating system
Oct 17, 2009 | HP Compaq nc6000 Notebook
I have a hp compaq nc6000 no wireless option
if u truely wanna see u have a wifi then go to device manager from my computer and click device manager and go to network adapters and explore it u must see it there and to get connected to awireless network, get closer to atmoast 100m from a wireless source and the network connections tab will give a message if not then u lack driver
Apr 19, 2009 | HP Compaq nc6000 Notebook
Wireless is not working on my hp nc6000 laptop
I had the same problem but I solved it by downloading a driver from the HP support web site. You might have to try out a few different drivers before you hit on the right one.
Apr 11, 2009 | HP Compaq nc6000 Notebook
Compaq nc6000 laptop wireless connection
Wireless connection? If so, make sure the wireless device is enabled on the newer one. If it's a red light, the wireless device may be faulty. If so, just get an external USB wireless device and use that. Check to see that the same lights are on with both PCs.
Mar 04, 2009 | HP Compaq nc6000 Notebook
My neighbor's signal
If your neighbors know that your using their router, you might ask them to reset it. If they moved it, this could cause the weakening of the signal, walls drastically decrease a wireless signal. You might also refresh your wireless card by uninstalling the wireless drivers and reinstalling them.
Aug 05, 2008 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
266 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
