Question about Creative Labs ZEN V Plus MP3 Player
Screen says re- building library. won't play - Creative Labs ZEN V Plus MP3 Player
  • Donovan Kelly
    Donovan Kelly Mar 16, 2009
    After formatting the zen v plus it is saying re-building library but will not re-build it freezes
You have to format it : follow this procedure:
Posted on Mar 10, 2009
Windows media player won't play any audio selections , says can't find files
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display. The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall." Click to check "Media Center Extenders." Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup." Click on "Set Up Your Speakers." Follow the on-screen prompts to reconfigure your speakers.
and you should run the chkdsk utilty
You could run the chkdsk disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive
or an easier way i have found to run the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers operating system and hard drive.
hope this helps
Oct 23, 2012 | Toshiba Satellite A60-692...
My Computer Completely Freezes Everytime I Listen To Music
You can download a software called CCleaner. This helps clearing all the temporary files in the computer. Once all the temporary files are cleared the problem won't occur. If the problem persists, then listen to music in lighter players like VLC or Winamp.
Jul 31, 2012 | ASUS Computers & Internet
When i click iPhoto it gives me a screen with a symbol going around and around and won't show me any photos
Sounds like you iphoto library is either corrupted or is not well, what I would suggest that you download iphoto library manager from there is a free download which may be able to resurrect your library the cost of the full package is $19.95 and it is well worth buying particularly if you have a large iphoto library. Hope this helps.
Jun 04, 2012 | Apple MacBook Air
I added to much music and it crashed
I use a microsd to load files that i havent tried on the device before, to test safely. If it crashes then i can simply remove the microsd and clear it. If the "bad" or incorrecly encoded files are loaded onto the internal memory of the device then you will be unable to clear or bypass the "building library" stage and the device is bricked. Take it back to where you bought it and get it replaced if this happens, that's what I had to do when I bricked it.
Maybe we all need to write to iriver and request much improved firmware that allows wiping of the internal memory BEFORE the build library stage as well as the option to disable or an improvement of the "build library" functionality. A simple solution would be to set a flag in a config file whenever files are added to the device and it doesnt do a build library unless the config flag says new files are present and that it is required.
Jul 10, 2010 | Nokia 5310 Cellular Phone
ZEN V Plus MP3 Player: turned my zen on, it says "re-building library", w...
the same thing happend to mine and i just let it sit there then it found all the music and i never had that happen again
May 17, 2010 | Creative Labs ZEN V Plus MP3 Player
Frozen mp3
What model is this? I was going to suggest a hard reset or reformat if it is continually locking. Simply resetting it isn't stopping whatever is making it freeze up to go away, so it's time for more drastic measures. Hopefully you can still save your music and connect it to your PC before you have to wipe it out.
Here is a link to a similiar situation with a Zen that might help from our very own fixya archives.
Hopefully something there will help.
Dec 12, 2007 | Creative Labs ZEN V Plus MP3 Player
I've had 2 crashed iriver X20
Hi. I just had solved my Build Library problem. Use my solution on your own risk.
The solution is the following:
1. open up a player (find 8 screws, not 6, 2 of them are on the left side of the player under the round stickers)
2. jently take off a circut board. (you need to access its bottom)
3. Find a memory chip. It is labeled like "samsung k9hbg08u1m"
4. find chip's key meaning start of pin numbering (small circle on the corner). There are 48pins. 24 on the left side (1-24) and 20 on the right (48-25) see chip's manual page 4
5. On the right side find pins 32-29 (find them as the second 4 pins from the chip's circle key opposite corner)
6. Connect them together with some metalic wire (don't touch two middle pins on the right side of chip, it is chip's power supply).
7. Holding those pins together connect USB cable to player's socket.
8. After a while player will show error on its screen, get metallic wire out of pins, and then the player will be available as flash storage on the PC.
9. Format flash storage with quick format.
10. Disconnect and assemble the player back.
11. Connect to PC and upload new music.
12. Feedback to fzymarev()
Oct 12, 2007 | iRiver X20 MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
77 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
