Question about Garden
I have a yardmaster ride on mower with a puncture in the rear wheel and no trailer to take it into town. I have undone the bolt on the rear wheel but the wheel seems to be on a spline or something as it will not come off. I have tried all the gear pullers in the workshop but none of them are wide enough. Do I need a special tool or is there some trick to it?
  • 10,865 Answers
Chances are that rust is the culprit here. you can try hiitting the wheel using a block of wood against it and then a hammer. Another approach would be to bock it up and either use tire slime to make the repair or insert an inner tube. Of course you will then need a way to blow the tire up which could be a compressor or a portable air tank.
Posted on Mar 09, 2009
  • Joe Hogan Mar 09, 2009
    chances are that rust is the culprit here. you can try hiitting the wheel using a block of wood against it and then a hammer. Another approach would be to bock it up and either use tire slime to make the repair or insert an inner tube. Of course you will then need a way to blow the tire up which could be a compressor or a portable air tank.
Yardmaster metal shed model 64PZ2 instructions
Goggle it. manual yardmaster model 64PZ2 shed.
Feb 26, 2014 | Garden
Rear wheel stuck on shaft
should be ale to take the lug nuts off and simply take the tire off if it is stuck on after taking the lug nuts off take a 2x4 and hit the back side of the rim a untill it comes off they do tend to stick on the hub.
Jul 26, 2013 | Toro Garden
WHERE CAN i DOWNLOAD A OWNER'S/USER'S MANUAL FOR AN MTD YARDMASTER 18HP RIDING MOWER
finding the website for MTD and/or AYP would be a place to start. google is there, use it.
Mar 16, 2011 | Garden
Torque for pyutting new rear brakes and rotors on a 2006 Town&Cou
Caliper mounting bracket bolts 125 ft, Caliper guide pins/bolts 26 ft, Brake hose to caliper 35 ft. Wheel lug nuts 100 ft. Wheel speed sensor 115in lbs*** This is for disc rear brakes Teves system. You do know that the rear disc is a Rotor/Drum. The parking brake shoes ride on the inside.
Jan 22, 2010 | 2006 Chrysler Town & Country
Can you use Fix a flat to repair a flat tire on the Cub Cadet LTX 1042
If it's a simple puncture, "Fix-a -Flat" or another product called "Slime" might work for you. I believe Walmarts sells both.
Hope this helps... Good luck!
Oct 19, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Wheel rear wheel removal on a toro riding mower
take the bolt out of the center or the e clip off and the wheel should slide off but dont loose the key
Aug 22, 2009 | Toro Garden
How to replace lug studs on 2002 chrysler town
I'll try to help you. If you are having trouble with 3 out of 5 studs on one wheel you may want to go to an autoparts store or Salvage yard to look at the whole hub. Usually a press is used to remove the bolts so you would be taking off the hub anyway. When you pay for 3 bolts and labor you may be better off in a Salvage yard or parts place for a different hub. The rear hub on front wheel drive cars is like a trailer axle. Much simpler to remove mounting bolts and press in new bolt. But if rear has differential(rear wheel drive) it has an axle shaft. Would be easier to grind and drill out broken stud on car. You can draw new bolt into place by placing bolt through a socket and use the wheel nut to draw the bolt into the hub.
Jul 08, 2009 | 2009 Chrysler Town and Country
Snapper comet rubber drive
Get a new drive wheel.
Put mower in neutral.
Stand mower on rear supports.
Remove the four bolts holding the old wheel.
install new wheel.
Jun 15, 2009 | Garden
Garden Logo
215 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
