Thanks for your question! I'm sorry that you haven't received an answer yet. The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when: 1. the question is unclear, incomplete, or poorly worded... 2. the question is mis-categorized - so the correct experts aren't viewing it... 3. the question requires an answer for something that cannot be explained online adequately... 4. specific training, tools, or equipment are required to avoid injury or death... 5. the Experts that are online simply don't have the resources to answer your question fully... Please feel free to re-work your question if you feel one of these may be the reason. Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well. Normal rates for FixYa are... $ 9.99 answer for one question. $12.99 Live Real-Time online chat or premium e-mail support. $29.99 Live Real Time phone support Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership. Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Hello, Invacare does not have Reset Buttons on the power for the batteries. They only use fuses. Now if the joystick has a display and it says to press a reset button and it did not used to say that then the programming has be lost or changed by the rain or battery power. You will need to have someone with an Invacare Programmer reprogram the chair or a reset switch can be purchased that will plug into the joystick and allow you to get pass the Press Reset command on the joystick.
I understand that your Frigidaire air conditioner, model# FAM187S2A, beeps and flashes lights when you first plug it in. First, test the power supply cord by doing the following:
1. Plug in your air conditioner.
2. The power supply cord will have TWO buttons on the plug head. Press the TEST button. You will notice a click as the RESET button pops out.
3. Press the RESET button. Again you will notice a click as the button engages.
4. The power supply cord is now supplying electricity to the unit. (On some products this is also indicated by a light on the plug head)
NOTE:
• Do not use this device to turn the unit on or off.
• Always make sure the RESET button is pushed in for correct operation.
• The power supply cord must be replaced if it fails to reset when either the TEST button is pushed, or it cannot be reset. A new one can be obtained from the product manufacturer.
• If power supply cord is damaged, it CANNOT be repaired. It MUST be replaced by one obtained from the product manufacturer.
NOTE: Some plugs have buttons on the top.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
Sharp updated the procedure for resetting the E1 code.
1. unplug unit 2. hold the Power button while plugging the unit back in 3. keep holding the Power button until the unit beeps 4. unplug unit again 5. plug it back in and it should be good
If you will look where the power cord is plugged in, somewhere immediately close to there you will see a reset button or buttons similar to those you may find on electrical receptacles in the house. It is like a circuit breaker. Press it in to reset. It should be clearly marked as well.
Yes, there must be a protection device on the unit somewhere. It should be indicated in the owners manual. It may be on the box the outlets are in, or built into the cover of the generation unit.
RE: Garmin Nuvi 260W Grrrrrr...I could not get my new GPS to turn on straight out of the box, even after charging it in my car for hours. I watched the on-line video - but could not find the reset button (different location than what was on the video). I finally thought I couldn't reck anything worse so pressed the tiny reset (sticker) - not button with my fingernail so hard I practically went through the sticker - and that worked.
Quick Start Manual should state SOMEWHERE that your unit might have to be reset before being able to be powered on. Clarify that it is a button hidden under the sticker in really small print. This was very frustrating.
BUT - Once I figured it out - it was so easy to work - I was impressed!
Did you try to plug a lamp into the same outlet as you have the A/C plugged into? It could be that you have no power at the outlet or the circuit breaker could be off or tripped. Something should run like the fan only position.
