Question about Pioneer VSX-9300TX 7.1 Channels Receiver
Front speaker (L&R) no volume, please help
I have a pioneer receiver VSX 9300 and it is withe me for quite a number of years and recently the front speaker L&R has no volume.
Please help if some one can assist me.
Thank you
I have a VSX-9300s in which the preamp and power-amp are normally linked with short u-shaped connectors, or require RCA plug cables to connect them. If these are missing, no signals can reach the L/R speakers. Check your manual or carefully inspect the rear panel for the preamp outputs and power-amp inputs.
Posted on Jan 29, 2012
  • cesar
    cesar Nov 02, 2014
    thank you PETER . i bought this reciever used . i was very upset , i cuoldnt get a sound . you give me the answer thanks again
Is it the correct mains from reciever?
Posted on Mar 09, 2009
Dear Sirs, I have a Pioneer AV Receiver model VSX-817 and is connected to Monitor Audio Speakers (Fronts: BR5, Center: BR-LCR, Rears: BR1), Sub: MS309 (Mordaunt Short). I have connected each front...
Did you remember to remove the shorting link on the MA BR5 speaker terminal ..When you biwire the speakers you should remember to loosen the speaker terminal nuts and remove the shorting link plate between the HF and the LF terminals or you will short the amplifiers two channels together through the link. And modern amplifiers will take a lot of abuse at low volumes but at high volumes the protection circuit will turn off the device.
Apr 10, 2011 | Pioneer VSX-817-S
On my Pioneer receiver (model # vsx-9100tx) MCACC light keeps flashing and system will not power on. Please advise.
Hi the mcacc light keep's flashing and will not come on. Can you help with this thank you Lee
Dec 22, 2010 | Pioneer Elite VSX-9100TX Receiver
I want to connect a pair of Bose 901 speakers to the VSX and use them as my front speakers powered by a separate amplifier but can't find an appropriate pre-out from the VSX.......what analog VSX output...
It doesn't really have one. The DVR-Out (or any other available Line-Out) COULD provide a mixed-down analog stereo program but it won't be volume controllable from the VSX and it won't be Front-Channel specific. Sorry.
You would then connect the EQ between the chosen Line Out and the amp input. If you had a Pre-Our you would just run speaker assignment, levels, etc and have fun. With a Line Out feed you will have to ride herd on the 901 volume via its dedicated amp controls. Bummer. My older VSX-36TX allows me to have the right setup.
Nov 27, 2010 | Pioneer VSX-818V-K Receiver
Problem for Pioneer VSX-818V-K 5.1 Channels Receiver Surround sound doesn't work, display reads 2CH IN,surround speakers are enabled,automatic test will find surrand speakers
Test with an surround sound media ie. Blu-ray or DVD)_. Disconnect the front and all other speakers that are working to see if sound from the missing speakers are heard. If this doesn't work then start by tracing and checking all the wires from the receiver to the speakers for bad/shorted/open connections.
PLEASE VOTE IF THIS WAS HELPFUL. THANKS & GOOD LUCK.
Oct 23, 2009 | Pioneer VSX-818V-K Receiver
Sound cuts out
No, this sounds like a speaker problem to me.
It sounds like the voice coils in your speaker(s) have been fried.
What happens is the part that is burnt does not funtion, but as you increase the volume/voltage the speaker "jumps" foward to a section of voice coil that is not as damaged.
Check your speakers!
Sep 07, 2009 | Pioneer VSX-816-K/S Receiver
Pioneer VSX 816
The rear signal is generated and separated internally, if either the processing is not correct or the rear channel amplifier has a problem, you can get this type of behavior. Does the static happen more often at higher volumes or is it purely random? Does changing the volume make the static louder or is it always the same level?
Dan
Mar 18, 2008 | Pioneer VSX-816-K/S Receiver
Overload Problem
If your rec'vr worked with the original front and rear speakers, the new speakers are either defective or ar the wrong impedance.
Also, I find this confusing: "I connected the wiring for 1 of the front speakers to the connection on the rear of the receiver". This may indicate wrong wiring connection. Make sure you have connected the speakers properly
Dec 04, 2007 | Pioneer VSX-D608 Receiver
Connecting a sub-woofer to Pioneer VSX-453 surround reciever
I got the same issue. But, I go ahead hooked it up two banana plugs on teh VCR outlet. It works fine on my Cerwin Vega Sub.
Nov 08, 2007 | Pioneer VSX-453 Receiver
Pioneer VSX-9300TX 7.1 Channels Receiver Logo
251 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
