Question about Dell Inspiron 1525 Notebook
My printer will not print from the laptop. i have done what pc suggested problem could be. restart pc, unplug usb cord and printer cords and wall cords. plugged those back in. pc relates there is a communication problem.
    Scholar:
  • 54 Answers
Download the most up to date drivers for your printer. You can find these drivers at the manufacturer's website (i.e. www.hp.com for HP printers) by typing in your model number. Once you have these updated drivers, uninstall the printer and reinstall with the new drivers.
Go to the Control Panel (Start button, then select Control Panel)
Select Printers icon
Right-Click on your printer and select Delete
How you re-install your printer depends on the type of file you downloaded. Some manufacturers provide an installation package that handles the installation for you. If this is the case, simply double-click on the file you downloaded and follow the prompts. If not, select "Add Printer" in the printers window and follow the prompts. When it asks for drivers, select "Have Disk" and point to the folder where you downloaded the drivers to.
Hope this helps.
Posted on Mar 09, 2009
When i try to print something a window pops up that says "communication not available" ive tried restarting, unpluging the power cord and the usb cord...nothing seems to work
This problem could be caused by several factors - incorrect USB port selection, your printer is not set as your default printer, firewall, etc. This article in the Lexmark website: Communication Not Available' Error Message and Print Job Stalls in Print Queue will help you determine the cause and resolve your printing issue.
May 11, 2011 | Lexmark X2600 InkJet Printer
My HP C3180 printer has unprinted data stored in it. How can I delete all this data without printing it ?? Thanks,
What i would suggest would be to reset your printer:
***Perform a hard reset***
Follow these steps to reset the product.
-Turn the power off.
-Unplug the power cord and the data cable from the product.
-Unplug the power cord from the wall outlet.
-Reconnect the power cord to the product and wall outlet, and then turn the power on.
-Print a self-test page again and check the print speed.
-If the test page prints in about 30 seconds, the reset has corrected the issue. If that does not resolve your problem, check the link below and follow it as per your issue.
Good luck,
Rodrick
Apr 22, 2011 | HP Photosmart C3180 All-In-One InkJet...
I can no longer print from my laptop unless I plug in the USB cord. Internet is on, on the printer as well as the laptop. Can print from desktop, but laptop will not print. Have unplugged the printer...
Go into the control panel and open printers and hardware. Look to see if your printer has a black checkmark next to it signifying that it is the default printer. If not, right click on it and select "make this my default printer".
Apr 06, 2011 | Computers & Internet
Paper jam
Hi Good day!! Follow this method to remove your paper jam:
1. Check to make sure that the power cord is securely plugged into an active wall outlet if your printer is not turning on.
2. Make sure that the USB cable connecting your computer to your printer is securely connected if your printer powers on but will not perform a print job.
3. Remove a paper jam if the "Check Paper" light on the front of the printer is blinking. To do this, first turn off the printer and unplug the power cord from the printer. Open the front cartridge door and locate the jammed paper. Gently pull the jammed paper toward you. Plug the printer back in and turn it back on.
4. Connect your printer to a different USB port on your computer if you are experiencing slow printing. The slowness could be due to a connection problem with your computer's USB port. After you've switched the port, try your print job again.
5. Make sure that a phone line is securely connected from a phone jack to your printer if you are having trouble sending or receiving faxes.
6. Clean the scanner surface if your scans are blurry or have vertical white or black lines. To do this, spray the a soft, lint-free cloth with a mild glass cleaner. Wipe the scanner glass with the cloth and then dry it with another clean lint-free cloth.
7. Hard reset the printer if you are having trouble solving your problem. Turn the printer off and remove the power cord from the wall outlet. Wait at least 15 seconds and plug the cord back in. Power the printer on and try your job again.
8. Restart your computer if you can't solve your printing or scanning job. Sometimes restarting the computer can solve an unseen problem.
Don't forget to vote thanks!!!
Oct 28, 2010 | HP PSC 1510 All-In-One InkJet Printer
I have an HP laserjet 3300...it has performed flawlessly for several years. It just stopped printing recently, and gives error message that there is no communication with the device. I unplugged the...
Please follow the follwoing steps,
1) unplug the power cord at the both ends from the printer and wall outlet. connect to wall out let directly dont connect to printer.
2)Press and hold # and 6 while reconnecting the power cord to the product hold for 1 min after plugging the power cord, and then release both buttons, this should resolve the issue.
Regards,
raj_p5983
Jan 23, 2009 | HP LaserJet 3300 All-In-One Printer
Zvonko jelusic from belgrade
The print carriage is stuck.
Solution
  1. Open the top access door on the printer.
  2. Remove the print cartridges.
  3. Close the print cartridge flaps after removing the print cartridges.
  4. Turn the printer off and then on again.
  5. Replace the print cartridges.
  6. Close the top access door.
If the resume light continues to blink after the print cartridges are released,
OR
the print carriage is stuck or makes a grinding noise, follow these steps.
Solution
  1. Lift the top cover to the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
  4. Move the print carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
  5. Take out the print cartridges and close the top cover.
  6. Plug the power cord into the wall outlet. Plug the power cord into the back of the printer.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover
Solution
  1. Open the top cover.
  2. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet. Wait a minute or so.
  3. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet
Sep 22, 2008 | HP DeskJet 5550 InkJet Printer
How to reset d5160
  1. If the printer is not off, press the Power button to turn it off.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the printer.
  4. Unplug the universal serial bus (USB) cable from the back of the printer, if connected.
  5. Wait 30 seconds, then plug the power cord back into the printer.
  6. Plug the power cord back into the wall outlet.
  7. Press the Power button to turn the printer on.
  8. Ensure that the memory card has been removed from the memory card slot.
  9. Make sure plain paper is loaded in the In Tray.
  10. Hold down the OK button and press the Right arrow button four times.
  11. If the test page prints, re-connect the USB cable to the printer.
Dec 07, 2007 | HP Photosmart D5160 InkJet Printer
IP1500 won't power on
is the usb cord plugged in properly, try reconnecting the data ribbon from the print heads to the printer. hope this helps
Sep 05, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
Offline and blinking lights
A couple suggestions. Unplug the usb cable from the pc to the printer, make sure there is no paper jammed in the machine, unplug the machine from the wall and see if you can move the print head left to right freely. If nothing is obstructing it plig the power cord in with out the usb cord plugged in. See if the machine goes to ready. If all of these fail, that means the main board has been damaged by a power surge, and it would be cheaper to replace the machine than repair it. Good luck!
Jun 28, 2007 | Dell 942 All-In-One InkJet Printer
Dell Inspiron 1525 Notebook Logo
53 people viewed this question
Alun Cox
