Question about Epson Stylus R380 InkJet Photo Printer
Ink heads how do i remove the print head to clean them on the epson R380
  • Epson Master
  • 419 Answers
Removing the printheads from Epson printers is not recommended as you can successfully clean them while they are still installed and with less chance of borking the printer by forgetting where that screw went :)
To do this you need to turn the printer on, let the printhead move off the parking pads (where the printhead rests) and then immediately pull the power cord so the printer stops.
This will allow you to freely move the printhead to the far left out of the way.
You now need some ammoniated windex or a similar cleaning solution (try asking your ink supplier) compatible with inkjet printers.
Using a kitchen paper towel, carefully fold it four times and then soak this in the solution before putting the paper pad so it sits over the parking pad. Now move the printhead so it sits over the solution soaked pad and leave for 12 hours (don't turn the printer on or plug it back in).
Remove the original pad and put in a new one and leave for a further 12 hours.
Note: This approach allows the cleaning solution to wick up into the printhead nozzles and break down the clogs, returning them to solution and allowing you to clear them out. It requires time to let the solution do its work which is why it's critical you don't try to rush things..
Now, remove the pad, plug the printer back in and turn the printer on... Wait for the printer to stop it's initial routine and then run a cleaning routine and a nozzle check...
Leave the printer for a further hour just to let things settle some more and then print a new nozzle check...
You should find that that the printhead will have cleared out a great deal of clogging.
If your printhead has been clogged for some months you might want to change the pads more than once and extend the period over 2 to 3 days.
Whatever you do, don't try brushing the printhead back and forth over the soaked pad and avoid more than one cleaning cycle in a 3 hour period.
Hope that helps.
Posted on Mar 09, 2009
I'm getting an error message "Service required. Contact Epson."
Same story...Yes i use brand name cardrige... But i use it one a month since 29 months ! HELP !
Jun 04, 2012 | Epson Stylus R380 InkJet Photo Printer
New ink no print
Hi Good day!! Try to do a printer maintenance
Cleaning a Clogged Print Head
1. Press the cleaning button located on the front of the printer. Hold it down for 3 seconds to begin the cleaning cycle.
2. Run a cleaning cycle using your Epson printer utilities program. In Windows, go to "Start," "Printers and Faxes," right-click on your printer and choose "Printing Preferences." Select the "Utility" or "Maintenance" tab, depending on your printer model, and click "Head Cleaning." When the head cleaning cycle is complete, run "Nozzle Check." Repeat the head cleaning and nozzle check one to three times.
3. To access the Epson printer utility in OS X, select the Epson Printer Utility icon in the Applications folder in Macintosh HD. If prompted, select your printer from the Printer List, then click "OK."
Clean the print head manually. Remove the ink cartridges from your printer according to the instructions in your owner's manual. Turn off your printer. Dip a cotton swab in isopropyl alcohol, ammonia or hot water and rub the swab against the print head. Let the printer sit overnight.
Remove the print head according to the instructions in your owner's manual. Soak the print head for at least an hour in a small dish of hot water or isopropyl alcohol.
Preventing Clogged Print Heads
1. Use your printer at least once a week. Regular use will keep dried ink from clogging your print heads. If you have a color inkjet printer, print full color pages in addition to black-and-white documents.
2. Turn your printer off when not in use. This will prevent warm ink from bleeding onto the print head. If you have to store your printer, remove the ink cartridges.
3. Use a cleaning kit regularly. A cleaning kit usually includes a tube of ammonia that you spray on the printer head to clean dry ink.
Thank you for using FixYa
Please accept if my solution helps you
Nov 18, 2010 | Epson Stylus C84 InkJet Printer
R380: All cartridges OK but doesn't print yellow
the heads are clogged. specially yellow. use the software included to have the head cleaned.
Jun 19, 2010 | Epson Stylus R380 InkJet Photo Printer
Photos print orange. How do I get the settings to print correctly?
you have a clogged head. which is probably your red and blue ones. do a NOSSEL check and or a head cleaning to correct it.
May 09, 2010 | Epson Stylus R380 InkJet Photo Printer
Epson Stylus Photo R30 Printer
Ink are dried out in the printer head. YOu will have to remove the printer head and clean it with mixed windex or nail remover solution. Deep the head but do not submerge the entire unit for 24-48 hour; use 4 toothpicks so the head is not touching the ground this way the solution will losen up the ink. YOu will need a syring and a hose or tube so you can blow the solution from the niddle out to the printer head. Keep doing this until you have an even flow.
Oct 28, 2009 | Epson Stylus R380 InkJet Photo Printer
I just installed a new black ink but it doesn't print black, only printed colors. I thought the ink was a defect so I changed another new ink but it is still not printing. Now, the color stopped working as...
your print heads might be clogged. clean it the hardware way. not the software way. to do this, simply buy a print head cleaning solution for Epson Printers. now pull out all your print cartridges and put a small drop of cleaning solution to the pin-like plastics in the base where your heads are seated. drop and drop cleaning solution to dilute clogs. you can use syringe to sip out the solution from the area. after this hardware cleaning, do a software cleaning through performing a cleaning print heads in the epson tools under maintenance tab
Oct 15, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Printing every few lines blurry, but not every line.
Printer head is clogged, be sure to clean it until you get the solid lines
Jul 11, 2009 | Epson Stylus R380 InkJet Photo Printer
EPSON PRINTER PRINK HEAD PROBLEM
Problem with ink flow. Use original ink or compatible? If original, ink will out and dried after head cleaning many times. If compatible, problem is ink quality. When head cleaning, ink flow to head by suction of head cleaning mech. If use to print, ink at head spray out, but ink ank ink tank not flowing good to head.
Jun 28, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson R380
Turn on the printer. The printer head will start to move to the left; immediately pull out the power cable from the back of the printer. You can now move the print head to the cartridge exchange position by hand. Change the cartridge(s) and close the cartridge cover. Re-insert the power cable, turn the printer back on and it should work OK.
Jan 07, 2009 | Epson Stylus Photo 830 InkJet Printer
Epson Stylus R380 InkJet Photo Printer Logo
817 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
