Question about Black Box Media Converter Transceiver
Bought the converter box for my tv ,... only get 2 plus channels
I bought a box for my TV.... It is about 15 years old... Box works great on channel 4. I looked around and realized I should probably have an antennas on my roof. I live in a valley between two hills. I can go to a store and buy the antenna -- but will that resolve my tv problems. ...and then who will put up an antenna?
  • Oblivion
    Oblivion May 11, 2010
    I don't understand your problem/question?
    If you’re saying you are getting bad reception? Then yes... getting a new antenna, and getting it as high as possible will help you greatly.
    What is "a box" and "the converter"? Is that a digital to analog converter for the digital conversion of all public TV stations? If so then you would tune your TV to one channel (channel 4 for you apparently) and then you would change the channel on "the box". Kind of like a VCR or A/V to RF modulator.
    I think the reason I'm confused as to what you want is because part of your question is in the heading and it got cut off.
  • 30 Answers
Yes, make sure you get that antenna up as high as you can with masts. Some places will offer installation when you purchase the antenna set up (although it usually is pricey), I know RadioShack will. I might suggest instead of getting a professional installer, post an add on www.craigslist.com, college kids will do nearly anything for a 24 pack of beer or a few dollars for gas!! :-) Good luck!
Posted on Jun 02, 2009
I need to tune my sharp tv to a set top box but am not having any luck. It only has an antennae connection and no AV channel. I have done an auto tune but cant get the set top box to work.
I have no idea what an antennae connection is. I assume you are talking about a Coaxial cable converter (large box that connects in line on the cable input). If this is the case, the box is override either channel 3 or 4. It either has a switch to pick which one of these to use or it is written on the box which one it uses.
If you are using a VGA connection (3 pins with 1 yellow, 1 white, and 1 red connector), then you have to find the AV channel. Every TV has one, unless it is like 4 decades old. If the TV is a few decades old, it may not have a channel called "AV" or "AUX". For example my dad's 25 year old TV uses 91 as the AUX channel. It is common for channels in the 90's to be used for this or channel 0. Best to just turn all the manually add/remove channels while the box is on. Then you can spot the right channel and add it to the listings.
May 09, 2011 | Televison & Video
Hello, I am currently having a problem with my Audiosonic KM0767 Standard Definition Set Top Box. When we first bought it we wired up all the plugs and it worked great. We then moved onto Foxtel...
did you switch the TV's incoming signal to digital antenna? For the cable box it was probably set to cable antenna or analog inputs, not all TV's have automatic switching for antenna feeds. My Mitsubishi has 1 digital and 1 analog antenna input and the cable box will only work through the antenna input if it's the analog antenna input and it's tuned to channel 3 or 4, -(or through a seprate HDMI, PROSCAN, SVCR,or a yellow RCA plug input)- and when the analog antenna input is selected the TV will tune all analog cable channels that the cable service offers if a box is not used. likewise the TV will not tune any channels at all if it's set to digital antenna inputs. It will tune all local channels only when set to digital antenna inputs.
Dec 26, 2010 | Televison & Video
Old tv plays dvds but when cable box is on or off image scrolls vertically on the screen. wondering if this is an issue that can be fixed or is symptomatic of a 15 yr old tv. thanks.
I'm not sure what you mean by "cable box is on or off". Do you mean connected? If the cable box is connected to the TV through a 300-ohm antenna input, you are probably getting a lot of interference from the workings of the cable box. Try moving the cable box away from the TV.
If the TV is connected to the cable box with a 75-ohm cable, it may not be properly grounded - try another cable.
Also try manually tuning the channel on which the cable signal comes in, usually 3 or 4. Try an alternate channel.
If the DVD player is built into the set, the signal is less subject to outside interference. If the DVD player connects to RCA jacks on the set, it is also less subject to interference.
Vertical hold problems can be caused by aging capacitors in the "sweep" circuits but usually one sees that as loss of vertical hold on the DVD signal, as well.
Good luck.
Jan 02, 2010 | Televison & Video
Built in tuner not working since digital transition
I do not know if you will get this message but if you do. Here goes. The protron PLTV3250 does indeed have a digital tuner that can be used with an over the air antenna. You need to push "source" on the remote until DTV is selected. With this selected and your coaxial cable from your antenna hooked up to the digital connector (not analog) on the back of this tv you can then press Menu and you will see a totally different looking menu that you are probably not used to seeing and then from there you can do an auto scan for the digital channels and it works great. I have rabbit ears hooked up to this Protron PLTV3250 and this has a beautiful picture. Far better than the picture I get from just the standard digital Directv receiver. You do not need a seperate digital tuner box to use with this TV. It does indeed have an ATSC digital tuner and it works great. You probably are selecting Source "TV" in the menu and that is not what you select for this TV to use the Digital Tuner. You need to select DTV from the source menu. Good luck and please let me know if you already knew this or if this helped you. Thanks, Tom
May 27, 2009 | Protron PLTV3250 32 in. LCD Television
Is the tv that I have bought about 6 years ago ready for DTV?
6 year old tv probably not digital ready. The converter box will work if tv is on channel 3 and you use a UHF antenna. Most converter box connections have 75 ohm connectors, your tv may have the round connector to accept the input signal. If you have screw on terminals on the tv you will have to go to Home Depot or Lowes and get a matching transformer to go between the tv and the converter box. UHF antenna can be made out of a coat hanger. Just make a circle clean the paint off ends and attach. Or just buy a digital booster antenna at WalMart.
Jan 11, 2009 | Daewoo DTQ-27U4SC 27" TV
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Is my Toshiba 27AF42 TV bought in 2002 capable of receiving digital signals? And whether it is or not, how do I integrate my VCR into the TV and my converter box? Right now the TV is hooked up with the...
This is probably way too late an answer, but I just ran across your post. No TV made in 2002 has digital tuning, so you would need the converter box to watch off-the-air digital broadcasts.
To hook up the pieces, take the converter box output and run it to the VCR antenna input jack. Then run the output from the VCR to the TV's antenna input. Leave the VCR and TV both on channel 3 (or channel 4 if that's what you have the converter box output set for).
To watch TV, leave the VCR off and the signal from the converter will pass right through to the TV. You'll do your channel changing with the converter box, so the TV stays on channel 3. To record a program, just remember that the VCR will always need to be tuned to channel 3 (4), since it will have to be on the converter box output channel. Again, you pick the actual TV channel with the converter.
Note that this arrangement will allow you to program your VCR to record while you are out, but there are some limitations. You can't record things on different channels, since you won't be home to switch channels on the converter. The VCR is always recording on channel 3 (4), and the program you'll be recording is whatever channel the box is set for. If another program comes on on a different channel later, you won't be around to switch. But you could program different recording times on the same channel, anyway. You also can't record one program while watching a different channel, unless you had a second converter box.
Hope you can still use the information provided here. If this has been helpful, please take a moment to rate this a fixya. Thanks for asking here!
Dec 16, 2008 | Toshiba 27AF42 27" TV
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Digital TV Signal
Not if you cable TV, DirecTV, Dish network, or FIOS. The converters are not usable with those services.
If you use a regular TV antenna or rabbit ears, then, yes, you will need a DTV converter box. If so, I'd suggest getting one well before next February. Why? 'Cause the pictures are better, and you'll have access to "virtual channels", where broadcasters send more than one program on channels like 4.1, 4.2, etc. Also, if you have poor reception, you may need a better antenna to see the DTV signals. Better to know that before DTV is all that is being broadcast over the airwaves.
Jan 19, 2008 | GE 19GT243 19" TV
Black Box Media Converter Transceiver Logo
502 people viewed this question
Top Black Box Computers & Internet Experts
Johnny Massengill
Johnny Massengill
Glyn
Are you a Black Box Computer and Internet Expert? Answer questions, earn points and help others
