Question about Westinghouse Washing Machines
I NEED A repair manual for WHITE WESTINGHOUSE TOP LOADING WASHING MACHINE MODEL LA68VSXW2''?
5 Suggested Answers
SOURCE: Sears Front Loading washing machine Model 45991 400
go to wwww.managemyhome.com and look for Search Product Manuals on the home page. Input Kenmore as brand and 45991 as model.
Posted on Oct 02, 2008
SOURCE: washing machine White-Westinghouse LB-42 door stuck?
The Inside Handle was Broken (from Iside) ! I had to remove the cover and replace the broken handle !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Dec 17, 2008
  • 1937 Answers
SOURCE: My Kenmore Elite top loading washing machine won't spin or drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Dec 07, 2009
SOURCE: manual for westinghouse lt959s
Hi, our lt959 is tripping the power mid cycle. just wondering if any one can help...
Posted on May 25, 2010
Where can I find the manual for WHITE WESTINGHOUSE model WW105. Thanks in advance.
Options I can think of:
1. Contact your local Westinghouse reseller, and ask them to purchase it
2. Contact Westinghouse directly http://westinghouse.com/customer-care/
3. Use their troubleshooter here http://www.westinghouse.co.nz/Troubleshooter
May 08, 2014 | Washing Machines
Washing Machine will not spin , also looking for Manual
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Here is a link to the part you need.
Jan 09, 2011 | Westinghouse WWS833ES Super Capacity Top...
How do you clean the mould build up off the flexible door seal of a front loading machine. Can I take out the door seal safely to do it. Westinghouse front loading washing machine model LF711C
Bleach:Water solution 1:2 should kill the mould effectively.
What they should have told you when you bought this machine and what it almost certainly says in the owners manual is that front-loading washing machines, all brands, are prone to this problem. You must wipe the rubber gasket/door seal off when done using. Every time.
Dumb, I know, but necessary.
Sep 08, 2009 | Washing Machines
Excessive vibration since moving--not before
is the place you moved the washing machine level are the legs level if so you have a blocked sump
Jun 24, 2009 | Washing Machines
My washing machine does not have a spin cycle
I just solved this problem myself. It's the lid lock mechanism which is located under the top cover. When I manually moved the aluminum locking tab over my washer prompty drained and spun. There are four wires total going to the switch. Well, the solid white and the white/red wires control the lid lock mechanism. You can either replace the entire switch or bypass the lid lock by wire nutting the two wires I previously mentioned together. Now, if you bypass, be forewarned the lid will open while the washer spins very fast which presents a potential danger. For immediate use, bypass until you get the replacement switch. Hope this helps your problem.
May 10, 2009 | Westinghouse WWS833ES Super Capacity Top...
White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
Nov 26, 2008 | Westinghouse WWS833ES Super Capacity Top...
Removing agitator
Sorry, I can't help you. This is the area for asking questions about computer monitors, not washing machines. You clicked the wrong link.
Look at the top of the page, click the Westinghouse link and then on washing machine. Enter your question there.
Mar 28, 2008 | Westinghouse L1975NW Monitor
Westinghouse Top Load Washing Machine
Possible your outlet filter is blocked, it need periodic cleaning, which the user can do himself. Locate where this is from your user's manual. Clean out, re-fix. Next it could be the hose that goes from the bottom of the tub to the filter pump; check the former first. Well, you have a record of sorts, 30 years!!
Jun 13, 2007 | Westinghouse WWS833ES Super Capacity Top...
Washing Machines Logo
85 people viewed this question
Top Westinghouse Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Westinghouse Washing Machine Expert? Answer questions, earn points and help others
