Question about Canon BJC 2110 InkJet Printer
Ink cartridges are wobbly & not sitting properly-No ownermanual
Ink cartridges are wobbly & not sitting properly-No owner manual for diagram
  • 53 Answers
Tis happens only when u change the places of black and colour catridges
try fitting correctly
if still the problem retains then u must hav got the wrong catridges
Posted on Mar 09, 2009
Ink cartridges keep popping out when i close the printer door
The cartridges are not seating all the way - are you sure all the tape has been removed from the cartridge? Also, use a flashlight and look on the ink cartridge carriage - make sure there's no paper of tape sitting on it that would keep the ink catridges from seating properly. The ink cartridges should go in and you should feel them click into place.
Nov 16, 2013 | HP Officejet 5610 All-In-One InkJet...
Need owners manual for GXT740 two way radios
here : http://www.midlandradio.com/Resource_/OwnerManual/155/GXT740%20Owner%27s%20Manual.pdf
Mar 04, 2011 | Midland GXT740VP3 Two Way Radio
Where can I find a diagram of the black ink cartridge so I can locate the proper place to re-ink it?
NOTE: If a refilled or re manufactured print cartridge, or a cartridge that has been used in another product, is installed the ink level indicator is inaccurate or unavailable.
  • Make sure that the product is turned on and connected to the computer.
  • Click Start and click Control Panel .
  • Double-click the Printer and Faxes folder.
  • Right-click the icon for the product and click Preferences .
  • Click the Services tab, and then click Service this Device .
  • The printer Toolbox opens. Click the Estimated Ink Level tab. A graphic showing the estimated ink levels appears. The graphic shows both the color and black ink cartridge with the ink level indicated by the fill inside the cartridge diagram. Figure 1: Estimated ink levels - both cartridges lowc738e3b.gif
    Sep 12, 2010 | HP DeskJet 6540 InkJet Printer
    I replaced some empty ink cartridges and now the printer does not print at all. goes through the motions of printing, but nothing.
    Did you get the inks from the printers' authorised distributors?, Did you touch the gold electronic prints on the ink cartridge? Did the ink cartridge site in properly in it seating?
    Get the ink from authorised reseller, re-sit the ink cartridges and let the key into the seating properly.
    Dec 27, 2009 | Epson STYLUS R350 Photo Printer
    HP 3310 lid wont close after ink install
    Hi!
    You need to make sure that the cartridge is inserted correctly on the right slot.
    Please see the steps and diagram from the user manual for the proper installation of the inks. (Page 148 to 150)
    http://h10032.www1.hp.com/ctg/Manual/c00486336.pdf
    Nov 08, 2009 | HP Photosmart 3310 Printer
    My pixma mp 145 is not working. it shows error 5.please give me its solution
    Error 5 means
    The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
    try to change your catridge if it is old one.
    Hope this helps
    Thank you
    Oct 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
    How do I remove printhead?
    same as when you change ink tanks...
    1.follow the same procedure you use to change ink tanks/cartridges to remove the current ink tanks
    2.remove all ink tanks/cartridges
    3.the printhead is what the ink tanks/cartridges sit in, the furthest half of the part the ink tanks/cartridges sit on is the removable part/printhead, it is loose so you can simply reach in and carefully pull it out.
    Easy as 123 ...
    eSid
    Mar 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    Printer not printing properly. top of letters not being printed
    Bad printer cartridges. Turn off the unit and clean the golden contacts on both the ink cartridges and the printheads (the place where the ink cartridges sit on).
    Be blessed.
    Sep 29, 2008 | HP Office Equipment & Supplies
    Changing cartridges
    Did you get the answer for how to replace the ink cartridge, because I don't have a manual myself and I can't even figure out where the ink cartridge is located?
    Dec 11, 2007 | Office Equipment & Supplies
    Black cartridge not printing
    Three things peggye: one you have bought a dud cartridge. It happens. Two: you did may not have removed all the protective tape or it is not a comapatable cartridge by mistake. If tow is not the issue, try 3 first before resorting to 1. Three: your printheads are blocked for black ink. Manually clean with proper cleaning solution, using cotton buds, right doen where cartrisge sits, and use a baby wipe (unscented to press firmly on bottom of cartridge where ink comes out. Put it back in. Print now. Post back if no good. Cheers, lilacgerry
    Sep 02, 2007 | Lexmark X4270 All-In-One InkJet Printer
    Canon BJC 2110 InkJet Printer Logo
    91 people viewed this question
    old marine
    old marine
