Question about Smartdisk - Peripherals - HARD DRIVE, CROSSFIRE 160GB EXTERNAL (XG160F)
Reformat Hard drive after power failure
Power failure has cused my 400g external USB Drive to lose partiton information as well as the MBR and MFT. I have software to recover my files from it, but would like to reformat the drive once recovered, I cannot find it in disk management but do find it in my computer but won't let me access it without the recover software. All I want is to reformat the drive and get it to work again, weithout spending $200 to have it recovered. Dr. Mike
    Guru:
  • 120 Answers
Try this program http://findandmount.com/ it very well may fix your problem
Posted on Aug 02, 2007
WD1600CO32 hard drive not recognized or system wants to reformat
Your only option is to reformat. This happens when the MFT is damaged. MFT (Master File Table). Once you format the drive, download, install and run Recura and do "Deep Scan". You should be able to recover your files.
Dec 30, 2012 | Western Digital My Book Essential Edition...
Wont boot and says that no operating system can be found
Get a recovery disc for your computer (OS or a partitioning/utlity tool). You need to find out if you lost the MBR (the where is the OS information), the partition, or if the hard disc failed.
It's very likely that any repair attempt may reformat your hard disc. So consider a Live CD rescue tool and backing up if you haven't been consistently doing so. (Attach a USB hard drive or external optical drive for the backup data.)
Good luck and I hope this helps.
(who has a computer smart relative who reformatted the computer without salvaging the data to find out the hard drive was failing and that was why it lost the MBR the first time.)
Apr 17, 2010 | IBM ThinkPad A31 Notebook
Is there any way to reformat my drive without losing all my information?
Only by backing it up to another drive first. Formatting destroys information on the drive.
Apr 13, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
Trying to reformat mini dell with no cd rom drive tried to boot from usb but comes up with No bootable partition in table what does this mean
Recovery discs have certain run procedures, flash drives dont. I would suggest you obtail or lend and external USB writer
Feb 21, 2010 | Dell Inspiron Mini 10 Notebook
Space error
plz formate your drive through cmd after format its not working then your drive is fake space
Aug 30, 2009 | Western Digital My Book Essential 1TB...
Iomega external not visible
Unfortunately, Windows isn't the most efficient operating system when it comes to it's "Plug 'n Play" abilities. In my experience, external hard drives can be particularly sensitive when it comes to unplugging the data cable while navigating the drive. I've had two external drives lose all data because of that flaw in the NTFS file system. The MFT exists on every drive with NTFS storage method. If that becomes corrupt, it can render the drive useless.
The drive may have power, but that quiet beeping you hear is an indication that the reader head is stuck to the platter and may be grinding into it. There is a myth (may or may not be true) that says if you put the drive in your freezer for a few minutes, take it out, drop it from 6 inches onto a hard surface, it may knock the head loose and make the drive work again.
I tried that method, and it made the situation worse for me, but it may work for you. I would resort to that option only if nothing else fixes it.
Aug 08, 2009 | Iomega CORP EGO PRTBL HD 160GB-HS USB 2.0...
Problem with seeing files on external Hard drive
What has happened is that your file system on the hard drive became corrupt becasue windows had not updated the MFT on the drive. THe MFT is a table of contents regarding whats on your drive.
What happened is similar to someone cutting out a few pages of the table of contents in a book that has a lot of pages.
Windows tried to fix this stupid programming method by asking people to always use the "safely remove hardware" button in the taskbar to force it to update the MFT.
In this case yur a victim of the Hard Discs MFT not updating properly probably because software was accessing the drive when it was disconnected from the machine.
You need to run chkdsk to have it rebuild your MFT.
http://support.microsoft.com/kb/315265 <-- How to perform Check disk
*NOTE: Remember to use the drive letter that the USB External is on.. Not just type CHKDSK. It will default to drive C to scan for errors. ex: c:\chkdsk g: (where g is the drive your external usb is)
If you get an error like "CHKDSK is not available for RAW drives.. see my notes below.
Beware that it will take a LONG TIME to perform this procedure.
If this doesn't fix it.. contact a data recovery specialist.. It's worth the cost. There are two types. Simple and Advanced.
Simple= recovering files your deleted with the delete button (fairly easy with the right software)
Advanced = recovering files from a hard disk crash or file system corruption. (Not easy and very time consuming)
Nov 04, 2008 | Seagate FreeAgent Pro Desktop - 320GB -...
Samsung sp2004c drive failure
My guess is that your hard drive is corrupted. If you have any extra hard drives (external or internal), try replacing your current hard drive with that one, and see if that works. If it does, you may have to take your Hard Drive to a computer shop to have it recovered.
If that doesn't work, then something corrupted your operating system. I would re-install the operating system (reformat may not be necessary, but is always better than just a reinstall, although you do lose all of your information during a reformat), and then try.
Feb 10, 2008 | Samsung SpinPoint P120S (SP2004C) 200 GB...
External SimpleTech Simple drive 96300-40001-001
I've had this same problem, and the solution for me was in the USB cord, not the cheap one that came with it I had to buy a more expensive USB cord, one with brass or gold colored ends on it afterwards I was able to retrieve all my photos, music, etc. I hope this helps
Dec 15, 2007 | SimpleTech SimpleDrive Portable USB 2.0...
Reformat of external hard drive
Hi, You may want to try: 1. HP Utility Software (actually intended for flashdrives but I have tried it and it worked with my external USB drive)http://h18000.www1.hp.com/support/files/serveroptions/us/download/23839.html 2. Partition Magic http://www.soft32.com/download_151.html (have used this likewise with no problems just don't forget to set in preferences your main drive as read only) Hope this be of some help and give you ideas. Pls post again how things turn. Good luck and kind regards.
Jul 31, 2007 | Smartdisk - Peripherals - HARD DRIVE,...
Computers & Internet Logo
138 people viewed this question
Top Smartdisk - Peripherals Computers & Internet Experts
Alun Cox
k24674
Are you a Smartdisk - Peripherals Computer and Internet Expert? Answer questions, earn points and help others
