Question about Linksys WRT54G2 Wireless Router
I need to set up security cameras, by opening 2 ports for each camera. I have max on my router of 10 options. I need 12!
  • Anonymous Mar 09, 2009
    THESE DLINK CAMERAS OVERLAP THEIR PREFERED PORT NUMBERS
    Problem Solver:
  • 7 Answers
On most routers there is a place to type in a "Range" of ports. Instead of typing in each port, open the range you are looking for. For instance start 1-20 instead of typing 2 ports per line.
Posted on Mar 09, 2009
How to Watch Security Cameras on the Internet (Port Forward IP Cameras)?
what sort of router is being used ?
are the cameras on static ip addresses ?
google search for
model of router and port forwarding
http://www.wikihow.com/Set-Up-Port-Forwarding-on-a-Router
Oct 19, 2016 | Cell Phones
How do I find my port number to set up a security camera
A port number for the camera? Or do you need to set up a port on the external interface of your router so that you can see the stream from your security camera from the Internet?
Aug 28, 2015 | Computers & Internet
I set up my Surveillance system and I can view the cameras on my iphone at home but when I leave I can not?
Your phone is most likely connecting via Wi-Fi when you are home, but after you're out of range of Wi-Fi, your Surveillance System must be set up to give you access through the internet. The camera instructions should tell you how to set it up and the manufacturer probably has an app that you need to install on your iphone to access your camera system from the internet.
Sometimes setting up internet access is no easy task. You must open a web port on your router in order to send and receive the signal from your security system and communicate with the internet. Determine which port the security system is set to communicate with and open that port on your router.
There are so many different configurations for security systems and routers that it would be impossible to specifically lead you through each step. But I hope this general description will be helpful in getting you started.
Sep 17, 2013 | SVAT Home Security
Failed to connect to camera TV-IP110W
Hard wire it to the router's LAN port
Power cycle the router
Open the Secure view software and search for the camera
Configure it to your IP address
Add it to the secure view app
You will be able to get the live view
match the wireless settings and disconnect the ethernet cable
Aug 28, 2010 | Trendware TV-IP110W Network Camera
How to configure the UPNP in panasonic camera?If we need access from the internet should we register in viewnet.com?
To access your camera from the Internet you will need to configure uPnP (or configure port forwarding manually) and register with some kind of dns service like viewnetcam (or know your home's external IP address assigned by your Internet Service Provider).
1. To configure uPnP on your camera, look in the network settings for an automatic network configuration option - this will trigger the camera to talk to your router using uPnP to set up port forwarding. The default for one camera is to use port 80 for the outside port and something like 192.168.1.253 for the internal network address (internal to your home only). uPnP will try to configure the second and third cameras to external ports 50000 or 50001. My router failed to configure the 3rd camera so I had to manually add a port forwarding option from my router's admin pages. To note, you can configure all port forwarding manually from within the router admin pages. Just list the internal network address to your camera (like 192.168.2.253) and specify a different port for each camera (like 50000 to 50000). You can then access your camera by typing in 192.168.2.253:5000
2. Then, you should register with viewnetcam.com. Adding your cameras on viewnetcam will give you access to them from outside your house without you having to know the IP address to your home network. You will simply type in your viewnetcam url with ":" and the port number (like username.viewnetcam.com:50000).
Note: When trying to access your camera from outside your home (or even pinging your router from outside your home), you need to know the IP address of your home. This is assigned by your Internet Service Provided and can change every time you reboot your modem. Services like viewnetcam keep track of the IP address to your home and update it automatically when it changes (your camera will communicate with Viewnetcam servers occasionally to update the IP address). All you have to remember is one constant URL (the viewnetcam url) and you can get to your cameras!
Aug 14, 2010 | Panasonic BL-C131 Network Camera
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
Jun 10, 2017 | D-Link Securicam Network DCS-950G Wireless...
BL-C131 port forwarding.
So you've configured port forwarding on the router. Do you have any anti-virus applications installed or have your set an exclusion in Windows firewall?
Feb 01, 2010 | Panasonic BL-C131 Network Camera
I cant open port for Zhone 6211-I3-200 Router
Some times you will need to open the Logical Ports on the router.
These are the logical ports.
For this you will need to open the set up interface of the router.
Once you open the set up interface of the router, you will be able to find the settings on the router where you can open the ports for the particular program.
If you are opening the ports for a special device in your network, then you must know the IP address of that device.
For example, wireless camera, DVR, X-box, Play station ...
You can choose the option PORT FORWARDING for a special device application.
If you just want to open the ports for all the network, then you can choose PORT TRIGGERING
Click Here
for more info
Dec 17, 2009 | Zhone 6211-I3-200 Router
Port forwarding? 2wire 2701hg-T
try the link below it may do it for you if your router is supported on the site http://www.portforward.com/
Sep 04, 2007 | 2wire 2700HG-B Router (2700HGB)
Linksys WRT54G2 Wireless Router Logo
41 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
