Question about Water Heaters
No hot water from the Amtrol Boiler Mate model wh7p
The smart control was only reading 140 it never went up or down from that number and now it has an ER3 code seem the circulator just runs and runs
Posted on Feb 14, 2010
    Sergeant:
    Champion:
  • 234 Answers
Http://www.measuredup.com/review/AMTROL-Boilermate-indrect-fired-hot-water-tanks-3245
This something what you got.Here is another place to look answer.
Boiler.JustAnswer.com
Posted on Mar 19, 2009
AMTROL WH7P-41 GAL TANK. 12 YRS OLD. BOILER PRESSURE IS INCREASING ABOVE 30PSI, AND DUMPING SMALL AMOUTS OF WATER FROM RELIEF VALVE ON BOILER. Do I replace coil?, or buy a new tank? Thank you
do you have a pressure tank as part of your water heater and water pipes? if yes, check to make sure tank pressure matches your incoming water pressure from your municipal hook up
Aug 18, 2015 | Amtrol Water Heaters
Er3 flashes hot water will not reach set point
Had this happen to me before, if you have hot water from the boiler going in and out of the boiler mate and the temps are not rising within the hot water means more than likely you may need to remove exchanger and clean sediment off element, basically sediment creates a blanket over the heat source causing poor thermal conductivity. Things to check before removing heat exchanger
- outlet temp of boiler water to aquamate -inlet temp of boiler water to aqua mate= 20-30'F if low then bad thermal transfer or poor water movement
-make sure sensor is reading properly
- get boiler temp higher to speed up thermal gain in water heater
Jan 19, 2014 | Amtrol 2704E76 41 Gallon WH-7C BoilerMate...
AMTROL Boiler Mate no hot water
You might have bad faucet cartridge or check valve.
Possibly a clogged line.
Contact amtrol info@amtrol.com to hear them suggest calling local technician
Otherwise Amtrol does not post service information or service manuals.
Post question on pro water heater forum to hear them suggest a few things before you call local service technician.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Use search feature on forum above, before calling local service technician
Read suggested answers at fixya before calling local plumber.
Call amtrol and ask why they do not post service manuals or service information when so many promoters are selling the product.
May 17, 2013 | Water Heaters
Amtrol boiler mate wh7l error code 2
I have also problem before on my Amtrol boiler mate wh7l but it has a warranty, so I did bring it to my local dealer shop and they had fix it. I think no other solution than bringin them on local dealer shop they had plenty of technician to fix em.
Dec 15, 2012 | Water Heaters
Armitrol boiler mate hot water maker has code er3 and we have not hot water. can u tell us what that code means?
It tells you that your water heater called for heat for more than an hr and never got hot enough to meet the demand. multiple scenarios can cause this
CAUSES
-bad sensors
-no hot water from boiler
-bad thermal transfer
-low delta T across water heater
Dec 02, 2010 | Amtrol ST-120V-C THERM-X-TROL ASME...
Amtrol wh7p
https://youtu.be/pUOBR1k3KvM- try seeing if this video answers anything. If not, there are a bunch of others about water heaters; just look around until you find one that looks similar to the one you have and watch. Sometimes, you get lucky lol
Jun 14, 2017 | Amtrol ST-12-C THERM-X-TROL ASME Expansion...
AMTROL Boiler Mate - No hot water
Most likely either a bad controller (which is the little display you use to reset) or the temperature probe which is accessible on the underside of your tank. Sensor is a 2 wire probe in center of underside and easily replaced.
Jun 08, 2009 | Water Heaters
No hot water at faucet
may need new circulater or bleed air from that zone
Apr 14, 2009 | Water Heaters
Temperature drop
Is there problem with the in coming water to this unit?
Mar 10, 2009 | Water Heaters
Water Heaters Logo
1,758 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
