Question about Kenwood KVT-617DVD Car DVD Player
Kenwood ktv617dvd Power shuts off then comes back on by itself?
Hi i have had this stereo for awhile and have had this problem with it for some time actually since it was installed the stereo plays just fine then all of a sudden it will shut off on its own and stay off for no longer than maybe 1 minute then it will turn back on by itself and i dont know if the stereo is doing this or if it is my car my car is a 2002 Cadillac Deville, ssometimes it wont do this at all and it isnt when i hit bumps or anything so i know no wires are touching anywhere. When i first bought this car the factory stereo never had a problem like this so please anybody out there with the solution would greatly be appriciated thank you...
  • joeheinert Mar 09, 2009
    Yeah i might try that but i am getting a kinetik battery and gonna run all my stereo and video equip. to the new battery freeing up my car battery for the cars needs this might be the problem too because the car manual said if the car senses something is not getting enough power it will shut down the less needed (like wipers lighters maybe the stereo)to power other important things in the car so for now i will try running a wire from the fuse box to the stereo to see if this helps or fixes the problem thanks.
    Problem Solver:
  • 5 Answers
It sounds like there is a short somewhere in your wiring. If the problem got worse when you installed the aftermarket stereo then it may be on the factory side of the plug. You may try powering the stereo by some other means. For example, try a wire with an inline fuse directly from the fuse block to the power wire on the stereo. You can also tap into the ignition wire that way the only way it will get power is when the key is turned on. Don't forget the inline fuse if you try it that way. I had to do that with a stereo I once had.
Posted on Mar 09, 2009
  • Jdog07 Mar 09, 2009
    If the car isn't getting enough power you may want to get the battery and altenator checked. I had a vehicle once that had a similar problem and upgraded the altenator to higher charging problem but i hope everything works with the new power plan
I have a Kenwood KDC-MP2032 installed in a boat. I changed the battery in the boat and now I can't get the tuner to power on. If I need to replace a fuse, where are they and what size fuse do I...
Try to check first the fuse on the fuse box of your boat if it is still good then the fuse of your stereo is located at the back of the stereo itself. Detached the stereo from its housing or holder you will see the fuse at the back of it.
Jun 28, 2011 | Kenwood KDC-MP2032 CD Player
I have a Kenwood KDC-MP435U radio in my car and when ever I turn in up kinda loud it will shut off and come back on on its own. Any idea why this is or how I can fix it?
The wattage of the speaker is higher than the required wattage of the stereo. The stereo cannot drive the speaker very well. Use an amplifier if you want to have a loud sounds. Or if you already have sound set-up make sure that you have a capacitor for your amplifiers and fuses to support the power input to your stereo.
Apr 07, 2011 | Kenwood KDC-MP435U CD Player
I got a kenwood stereo it is a vr-209 and evertime i turn it on it shuts back off so i need the code to reset it our get the protection mode code for it i called a stereo place that is wat they told me was...
Do you mean KENWOOD VR-209?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-VR-209-Receivers-manual/id/480dj179/t/2/
Page 21 descriebs the microprocessor reset for USA & Canada; or other countries.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Mar 16, 2011 | Kenwood VR-209 Receiver
Kenwood UD-551M hi-fi stereo ...problem
power problem of power amplifier .
if you can open the cover we can give try to solve this problem.
nuwan
Sep 02, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
KAC-8401 Shuts off Blue light still lit
HI RLF,
You might want to turn your Gain setting down a little. Also Look to be sure you have enough air flow around the amp. If it cannot breath, the heat from the amp will build until it wigs out. Use your Ingenuity to get more air to the AMp.
Nov 05, 2007 | Kenwood KAC-8401 Car Audio Amplifier
Volume turned up, kenwood shuts off briefly...
I had this same exact problem when my last older Kenwood Marine stereo cooked itself while I had it up loud for a few weekends on the lake. (smelled like it had burned inside). I went out and bought a new Kenwood KMR-550u stereo deck. (I do not have an additional amp). I hooked it up to the exact connections where my older Kenwood stereo unit had been hooked up, as I never had a problem with this for the past three years until it failed after smelling of burning elelectrical. I had chalked the problem up to heavy rain we had one day. Every time I turned up the volume, sometimes up to 27 out of 35 possible, or 29, or 32, the stereo would suddenly shut off as if I had turned it off. After a few seconds the stereo would come back on, but unless I was quick enough to turn down the volume it would do it again right away. Of course on a boat, we were beached in a cove and the engine was not running when I encountered this. I searched the internet finding hundreds of similar complaints and several dozen theories of all types, but only a couple that pointed me towards the power (voltage) idea as the problem. I put a volt meter on the positive & negative wires powering the stereo. I watched as I gradually turned up the volume, the voltage on the power wire gradually decreased from 12.5 volts, down into the 11 range, and as it hit 10.9 or 10.8 volts it shut off typically around a volume of 32. The red power wire in my boat that never seemed to have an issue with my old stereo until it fried was determined to actually be inadequate for the power flow for the new Kenwood, and probably was the culprit of my failed older unit. I offer this sound advice: Run a new pair of positive & negative wires directly from the battery (with an appropriate fuse of course (the deck has a 10 amp fuse in it's back so I would use that at the battery) to the stereo. Check the voltage as you turn the volume up into the high 20's and low 30's to ensure you are still getting voltage in the mid to high 11-12 volt range. The stereo is designed to require a minimum of 10.8 volts to operate, and when it drops below that it protects itself and shuts down.
Mar 24, 2007 | Kenwood Sirius KDC-MP522 CD Player
Kenwood KDC 7024
Some flip face stereos use a tiny micro switch to tell the onboard computer when the face is down or up and sometimes it uses the same switch for both positions sensing. It could be this switch is not working properly (dirty contacts, broken, bad wire, mis-aligned, etc.) and that is causing the problem. Good luck.
Feb 12, 2007 | Kenwood KDC-7024 CD Player
Kenwood KVT-617DVD Car DVD Player Logo
420 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
