Question about Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A
Reddy Heater 60,000 Model R60 only runs with top off.
I have a Reddy Heater 60,000 Model R60 That will only stay running if the top is off, if I put the top on it will run for about 5-10 seconds then shut down. The heater has new fuel filter, photo cell, and air filters. Wanting to know what could be wrong to cause it to shut down when it is all together, and how to fix it. Thanks
  • 1 more comment
  • cheffery75 Mar 16, 2009
    The heater just seems to shut down after 5-10 seconds. The heater can run on kerosene or diesel, I'm running it on kerosene. No I havent adjusted the air flow dilator.
  • Dominic
    Dominic May 11, 2010
    Does it seem as though the flame "blows out" or does it just shut down after 10 seconds?
  • Dominic
    Have you adjusted the air flow dilator on the back end of the heater?
    This model uses diesel correct?
    New Friend:
  • 26 Answers
I think you probably has a cracked air line. Remove the air line, plug one end with your thumb and put the whole line under water, blow thru the other end and see if there are any air bubbles, if there are then replace the line.
Posted on Jan 20, 2012
    Problem Solver:
  • 17 Answers
Sounds lik the vent hole in the filler cap is plugged. Try cleaning it or replace the cap.
Posted on Oct 15, 2009
SOURCE:
Runs 6 seconds cuts off never lites
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Feb 10, 2011 | Reddy Heater Tools 60,000 Btu Portable...
Reddy heater 60 starts runs a short time and cuts off
heatman101
Jan 26, 2011 | Reddy Heater 60,000 BTU Kerosene...
Heater starts, fan runs, injecting fuel but won't fire up
heatman101
Jan 20, 2011 | Reddy Heater 60,000 BTU Kerosene...
My heater would run for ten mins at a time the other day. today it will only run for like two mins every time. Its only been used like ten times.Ive cleaned the nozzle the cover on back of motor. I cant...
Travis, If you have a R60 you can find the fuel filter in the bottom of the pickup tube. Pull the pickup tube out of the fuel tank, then take a small screw driver and pop the small cone shaped fuel screen out. I take either carb and choke cleaner or brake cleaner and spray it out then blow out with compressed air. I'm having trouble with mine also, and I had to turn down fuel pressure (fuel pressure on R60 is suppose to be 3.4psi) but I don't have a fuel pressure gauge that goes that low!! Go to DESA TECH.com they have a lot of good info there. Hope this helps you out!!!
Dec 21, 2010 | Reddy Heater 60,000 BTU Kerosene...
Reddy heater 60000 btu kerosine heater
it either has too much fuel or not enough air. you will have to adjust both to figure out which is the culprit
Dec 12, 2009 | Reddy Heater 60,000 BTU Kerosene...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater r60
with the top off see if there is an obstruction between the fan and the back of the heater chamber.  also mounted on the backside of the combustion chamber is a hi limit with two wires coming out of it.  this connects to the flame detector which is in the flame path.  it is a copper cappillary with two spade connectors on it.  once a flame is detected, it generates a millivolt signal that opens and maintains the main gas valve. 01e527f.jpg
Oct 13, 2007 | Reddy Heater RLP100 Portable Forced Air...
Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A Logo
937 people viewed this question
Top Reddy Measuring Tools & Sensors Experts
Marvin
Marvin
jdthefixer
Tom Chichester
Are you a Reddy Measuring Tool and Sensor Expert? Answer questions, earn points and help others
