Question about Samsung ML1740 Laser Printer
Paper comes out complete black
I have ML-1749 and was borrowed by a Mac user. The user told me that the pages were printing complete black. I got my printer back and it is doing the same on my windows vista computer. Any idea why each printed page comes out completely black? Is the printer dead?
Try another toner cartridge - - particularily if it is a remanufactured unit you are currently using.
Posted on Mar 20, 2009
My samsung ML 2510 prints a black streak on each plus a watermark from previous page
If your paper setting are set corectly (normal paper) and you are getting a "ghost image" from the previous page, most likley the fuser is the problem. On rare occasions, the drum unit could be the culpret (Black lines) down the sides of the page as you indicated.
You may have 2 problems.
I would change the toner drum 1st. If the black lines go away ,yet the ghost image continues, then change the fuser as well.
Jan 16, 2011 | Samsung ML-2510 Laser Printer
Hi, I have a sumsung ML 2510 printer. It was very good until recently it prints paper with lots of black line mark on each page. How can I fix that problem? Thanks. Margaret
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Nov 01, 2010 | Samsung ML-2510 Laser Printer
How to make samsung ml3560 print on both sides of a page?
download the manual from (http://www.retrevo.com/support/Samsung-ML-3560-Printers-manual/id/260ci255/t/2/). it has the complete user guide on how to manage your printer.
May 10, 2010 | Samsung ML-3560 Laser Printer
I have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error...
By deepak_compu on Oct 06, 2009
i have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error show,but print not come. and when i print a test page from printer button it gives print. but on paper write like this toner exhoasted so what i do for this problem please give me soltuion of this problem
Oct 06, 2009 | Samsung ML-1640 Monochrome Laser Printer
Samsung ML-2510 will not print from MAC OS on Macbook
This printer has problems with Leopard last updates.
Contact Apple to see if a patch is available to run the printer on updated Leopard:
Apple - How to Contact Us.
Regards.
May 23, 2009 | Samsung ML-2510 Laser Printer
Samsung ML-2010 Mono Laser Printer leaves unwanted marks on page.
if older printer or well used printer (All laser printers if they have print quality issues - it is mostly either the toner or the fuser). the only way to tell is get (borrow) a toner and see if problem is the same or remove the fuser (the hot thing in the printer) and see if the "ironing" unit or fuser rollers are dirty or worn out or scratched
Mar 01, 2009 | Office Equipment & Supplies
Cannon MP160 How to Print both sides of the Paper???
Set Duplex Printing (Windows) For details on how to set duplex printing, see below: 1. Select 'Properties' from the Print dialog. Note: Properties may be indicated as Advanced, depending on the application software. 2. Click the Page Setup tab. 3. In the Printing Type section, select 'Normal-size Printing', 'Fit-to-Page Printing', 'Scaled Printing', or 'Page Layout Printing'. 4. Select 'Duplex Printing'. Note: When a media type other than Plain Paper, Photo Paper Plus Double Sided, or Postcard is selected in the Media Type menu, duplex printing cannot be performed. 5. Specify Staple Side. 1. The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. 2. Click the Staple Side drop-down arrow and select the setting. If you want to change the setting, select another value from the list. 3. If necessary, click Specify Margin... and set the Margin width 6. When the setting is completed, click the OK button at the bottom of the window. Note: If a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The document will be printed on one side of a sheet of paper when printing starts. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side. If Photo Paper Plus Double Sided is selected for Media Type on the Main tab: The document will be printed front and back alternately for one sheet at a time, when printing starts. Load the paper according to the displayed messages. 7. You will be prompted, while printing, to remove the printed page and reload it in the ASF. 8. Dependent on the number of pages to print, you will need to repeat step 7 until all pages have printed. Back to Top
Sep 10, 2007 | Office Equipment & Supplies
Samsung ML1740 Laser Printer Logo
93 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
