Question about Sony Playstation 3 (PS3) Console
Ps3 not working...screen turns blue...game stuck at checking hdd
Whenever i try to play a game or dvd the screen turns blue and when i press bottons it goes back to the game but it stays stuck at the "checking hdd" part...i tried reformatting the hard drive from the system settings menu but it stays at 0% for hours
  • 2 more comments
  • asianraider2 Mar 09, 2009
    is there a way to fix the ps3 hard drive when its corrupted or do i have to get a new 1...reformatting it doesnt work it stays at 0% for hours
    my ps3 hard drive is corrupted whats the best way to fix it or do i have to get a new 1
    what is the best way to fix a corrupted ps3 hard drive and if i do need to get a new 1 does it matter what the size capacity the hard drive is???
  • asianraider2 Mar 10, 2009
    does it matter what the size capacity the new hard drive needs to be for replacing the ps3 hdd???
  • 10,515 Answers
Hey look at the youtube.
http://www.youtube.com/watch?v=YWLTxsxrqfE
same blue screen. Its NOT A ps3 error.
steps are there to rectify that.
Thanks for usin fixya.
Posted on Mar 10, 2009
    Sergeant:
    Champion:
  • 289 Answers
Hi..In fact the problem would be the resolution
sent to the screen.The problem was setting in
1080p,try it with 750p.
check this out..
thank u..
  • Hariharanath V Mar 12, 2009
    hi..it doesn't matter,it can be of any size.
    check it out..
    thanks..
  • 15,935 Answers
This is not a corrupted (software damage) issue - you have a platten error (physical damage).
Replacement is your only option.
Any SATA drive will work.
Thanks for using FixYa!!
  • 6,784 Answers
Unfortunately, you will need a new hard drive. i would match the capacity of the original drive to be safe. this hard drive seems to be in a cryogenic state of limbo. its done.
Posted on Mar 09, 2009
  • Sony Master
  • 19,396 Answers
    Scholar:
  • 124 Answers
Sounds like you lost your hard drive.
Check to make sure hard drive is secure.
Check connections to hard drive.
Go into setup make sure hdd storage is on & not locked.
If still not working your drive is more than likely bad.
Hope this helped. Please rate. Good Luck.
  • Sony Master
  • 1,800 Answers
Hello and thank u for using fixya.
i need u to accept this as a matter fact.
ur hard drive is defective and its need to be replaced.
  • 495 Answers
The only advice i can give u is get the latest frimware for ur ps3 u can get it by sony
http://www.us.playstation.com/support/systemupdates/ps3
  • 2 more comments
  • Manoj Rout
    Manoj Rout Mar 09, 2009
    This happened to my friend PS3 also. He put it into another PS3 and
    reformatted it and then when he got home and put it back into his it
    asked him to reformat again and this did the trick. It's been working
    ever since.
  • Manoj Rout
    If that doesn't work, try this also
    turn on ps3 press x to restore on 0 % quikly pull out hdd. then wait
    may take up to an hour a message will come up to formate hdd. put hdd
    back in and press yes to format this process worked with in secounds
    for me but can take longer. it does work but you will lose all saved
    stuff but online stats will still be on the system. good luck hope it
    works for u to
  • Manoj Rout
    One more solution:
    put ur ps3 HDD in your laptop and run ur recovery
    cd and it will format you disk... or you can buy a new HDD for cheap on
    amazon u can get 100 GB to 160 GB for less than 100 dollars sony will
    charge 150 ) to fix ur problem.... or you can buy an external hard
    drive the USB ones and format ur HDD... good luck
  • Manoj Rout
    This is one of the experts solution posted on fixya:
    Our hard drive froze and we got an error message "file system
    corrupted". It would nor reformat. After reading the solutions here, we
    first removed the hard drive but that did not work because we simply
    got a "hard drive missing" error. So the key is to START the console,
    then remove the HARD DRIVE, then wait for the RE-FORMAT instructions.
    This worked like a charm.
  • 64 Answers
Hello, if it's corrupted and formatting does not work you will need to purchase another. They sell for $20-$45 on ebay.
    Brigadier General:
  • 8,619 Answers
Hi!
Please check the cables from your tv to the playstation.
  • 837 Answers
How old is your unit? If it still under warranty I would get it serviced. Your hard drive is failing and needs to be replaced.
  • Jay Glendenning
    Jay Glendenning Mar 09, 2009
    You will need to replace it
  • Jay Glendenning
    No but make sure that you get a SATA interface .. not an IDE drive
    President:
  • 987 Answers
Your hard drive is corrupted ..you need to replace it ...
  • Sibananda Mar 09, 2009
    1. Power Off the PS3 via the power switch in back and power back on w/switch.
    2. Hold Power Button on the Front until you hear 3 beeps.
    3. Then go through the initial setup and then run a full Format
    via System > Format. (will take approx 3 1/1 hours). You may need to
    have our AV cables ready if your using HDMI (in case HDMI isn’t
    detected after initial reset).
    4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
Can not create internal memory card, whenever I try I returned back to the screen that says name a internal memory card.
http://ps3explained.com/intermediate/internal-memory-cards/
Create an Internal Memory Card on the PLAYSTATION 3 system HDD as follows:
1. Navigate to [Memory Card Utility (PS/PS2)] under [Game] on the XMB.
2. Press “X” to bring up the “New Internal Memory Card” option.
3. Tell the PLAYSTATION 3 which format you want it to create. PS2 or PS1.
4. Highlight “OK” and press “X” to finish creating the memory card.
Note that you can make new saves on this card while playing PS2 or PS1 games on the PS3, but it does not allow you to transfer saves from a physical memory card to the PS3's HDD. You need the memory card adapter to do that.
Apr 06, 2010 | Sony PlayStation® 3 (80GB) Console
PS3 Games work, DVD's don't play-
it might help you if you install updates,but check if the movie disc is compatible with the region of your ps3.
Mar 08, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont play blu-ray but will play dvd
ps3 drive and blu ray drive inside of your ps3 went out. try cleaning them and if that doesn't work replace them or send it to sony.
Dec 15, 2009 | Sony Playstation 3 (PS3) Console
Game freezes when 'ps' button is pressed
perhaps your ps3 need a firmware update...enter in sony official website and download your ps3 latest firmware...check if your ps3 hdd is ok...bad hdd´s can cause game freeze...
Sep 10, 2009 | Sony Playstation 3 (PS3) Console
My PS3 playd cd dvd but not blue ray games
Problem with the laser it sounds like. If you still have the system apart with the dvd drive out, go ahead and replace the laser. You can usually find them on Ebay.
Aug 08, 2009 | Sony Playstation 3 (PS3) Console
AFTER WORKING FOR A YEAR, PLAYING BOTH GAMES AND BLUE RAY MOVIES, MY PLAYSTATION 3 WILL NOT PLAY MOVIES. WHEN A BLUE RAY DVD IS INSERTED IT BRIEFLY SHOWS THE TITLE ON THE TV SCREEN AND THEN THE SCREEN GOES...
1. Turn off the ps3.
2. press down on the on/off button on the front of ps3 while turning on the button from the back. DO not let it go until you hear 2 beeps and will show a red light.
3. press the on/off button again and do not let it go until you hear 1 beep, paused, and two beeps. Let it go.
4. There should be a prompt asking you what to do. If you have hdmi, answer all the question yes etc.
5 there should be a menu list asking what you need done.. setting wise..
6. Choose the # 3rd list (not sure how many they were).
7. IF it tells you that your data is corrupted etc.. just click ok
8. wait till progress ends ( if it tells your your data is corrupted again, just click ok again).
9. It's going to do some loading again...
10.. end of restoring and you should see your ps3 menu
Jul 28, 2009 | Sony Playstation 3 (PS3) Console
Tried to get internet
hi...please verify:
  • your dvd disc region (must be region free or 1 - for USA)
  • playing blue-ray MOVIES disc, to check a possible problem with your reader .
if the blue ray movie doesn't work, you have got a possible problem with your blue ray dvd reader .
then, take it to an assistance center for hardware repair ..
thank u
rate me!!.
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
PS3 will not play Blu-Ray movies or Video Games any longer
I had the same prob. Did a game freeze on you and you turned off from the back of ps3? If so it probally fried the blue ray and only plays dvd's and ps2 discs. if in warranty call sony
May 13, 2009 | Sony Playstation 3 (PS3) Console
PS3 wont load or play games, Just a blank screen.....
Try playing a Demo game, if you dont have any download it from playstation network. The point is just to force the sytem to play games and if you notice, movies and games are listed under a different folder in the icon's list, so playing a demo game will force the system to play the game and you should be able to play your games fine after that,. Thing is that a game's info might've got stuck in freeze mode when the system was shut off unproperly while a game disk was still inside, that's all. Good luck, dont wanna see any PS3 comrades suffering the unspeakable horridness of not been able to play games. Be strong my friend.
Mar 09, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
150 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
