I have tried multiple times to burn playlists on wmp. First of all, all the songs that i want to burn act as though they are going to be burned on one disc(all say they are complete), but when i play the mp3 cd, there are roughly 30 songs less than i intended. also, the songs that i burn do not skip when played on the computer, but when burned onto the mp3 cd, they skip... even to the point of my cd player skipping the song altogether. My cd player wont even recognize one of my cds because it is so horribly 'skippy.' any help would be greatly appreciated.
Can you tell me what version of Windows (2000 xp, vista, etc), and what version of WMP you're using (9, 10, 11)?
Also are you intending to burn as an Audio CD or as a Data CD? If it's an Audio CD, then you're not going to be able to fit a lot of tracks. On average you'll get 18 to 20 before the disc is full. When you look at the disc in Explorer, you'll see "Track01.CDA" etc.
If you're using 192kbps MP3s and burning them as a data disc, you'll get roughly 125 to 130 tracks on a disc before it's full. Also if it's a data disc you should be able to re-insert that disc into the computer and then navigate to it in Explorer and see a WPL playlist along with a Music folder that contains Artist folders which each contain Album folders if you're using a recent version of WMP, if it's an older version you'll see a list of MP3 songs and the WPL playlist. Open the WPL playlist in Notepad and you should see all the tracks on the disc listed in that WPL.
You should also be able to play that burned CD of MP3s on your computer. If the files are intact for playback from your hard drive on your computer, they should be intact for playback off the CD on your computer. There is no magic "error correction" code for ripped content during playback.
-- Thanks! Mike Poz [MSFT]
This posting is provided "AS IS" with no warranties, and confers no rights.
Was this solution helpful? Show your Appreciation by rating it:
Show your appreciation by commenting on poor mp3 quality/not all songs burn:
Solution #2
posted on Aug 02, 2007
Reynolds - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
First of all if you're running WMP 11 beta, you really need to get the released version. It's been out for about 8 months now.
Second, if you set the transcode for Data CD burning to be downsampled to 192kbps, any files that are transcoded from higher than 192kbps to that bitrate will be WMA, not MP3. You still aren't telling me what your SOURCE file type is, nor the bitrate.
Third, some people mistakenly assume that since they're using MP3 files as the source, and they're burning them to a disc, that automatically makes it an MP3 disc, even if they have Audio CD selected as the burn type. Are you SURE you have Data CD selected as the burn type? Because if you have Audio CD selected as the burn type, the above downsampling setting won't be effective.
Fourth, you didn't tell me if you looked at your burned disc in Windows Explorer and what you saw when you got there. Did you see .CDA files or did you see a .WPL file and a folder containing music files?
Lastly, this makes no sense - they skip badly, but when burned and played from the player, there arent any skips in the song.
How can you play CDs that aren't burned? A CD is a shiny disc that goes into the CD drive. If the disc isn't burned, it cannot be played so I really have no idea what you're talking about in that sentence.
Solution #3
2Pansy - usenet poster
i am using windows xp, and version 11 beta. i altered the options for burning, so the burn speed is slow, and convert to 192kbps. it says all the songs will fit, and there is no error message of any kind. it just burns. it is an mp3 cd that i am intending to burn, and all the files i want to burn are in mp3 format.
well it is weird if there is no auto correct, because when i play cds yet to be burned on wmp, they skip badly, but when burned and played from the player, there arent any skips in the song.
Solution #4
lawyer - usenet poster
I just re-read what you wrote, the files you've ripped are WMA if the highest bitrate is 192kbps. WMP 10 and 11 both shipped with an MP3 codec, the highest bitrate is 320kbps.
Be that as it may, the information I gave in the other post is still accurate with the exception of capacity for the 320kbps MP3 files if that's what you actually have.
Solution #5
Cato - usenet poster
well actually i changed the bitrate to as high as it will go; 192 i believe. media size... do you mean size as in bites? if so, i burn roughly 650 MB onto a disc. it says i can go up to 702 MB even though it is only a 700MB cd, and there must be room for the text (song name, artist, etc).
i think that there is an auto correct-function on windows media player and just about every other media player that takes out the scratches, i am assuming, but when they are burned it takes the source file, not the file as it sounds on the player itself, and burns that (un corrected). this is just a hypothesis, however...
Solution #6
Green1 - usenet poster
Can you provide a little bit more information for us? I'm assuming the default setting of "copy" rather than transcode to a lower bitrate, so can you tell me the bitrate of the content that you're burning? Also, what is the media size that you're burning to?
