Question about Whirlpool ED5VHGXM Side by Side Refrigerator
Compressor runs 12 seconds then down 2-3minutes
I found the coils cloged under the unit. After cooling the hot compressor it only runs this short cycle then shuts off. there is no ice in freezer coils and the lines from coils don't feel cold. Also the inside light dims slightly when the compressor comes on
  • cgfireman Mar 09, 2009
    I removed the relay from the compressor and one of them rattles pretty bad and sure sounds bad. I will get a new one tommorow and retry
  • 400 Answers
It sounds like you have a blockage in the refrigeration system. This would cause the compressor to overheat and ultimately trip out on thermal overload.
Posted on Mar 09, 2009
Ok so I have a ge cafe. I recently replaced the motherboard as my controls were all messed up and it was not cooling. Afterwards it worked fine except that there was a howling noise inside of the unit. A...
Correct, condenser coils remove heat from the freezer compartment, thusly they will be hot. Sounds like the compressor is failing and that is probably giving off a squealing sound and stops running until it stops. Then your compressor will overheat and stop running until the thermal protector cools down and allows it to run again. Try replacing the compressor cooling fan.
Oct 15, 2017 | GE Refrigerators
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
Cooler not getting cold
By not hearing anything but the fans I would have to say the compressor is not running. Pull the cover off so you can access the condenser area where the coil and compressor are located. Check the coil and ad make sure it is clean. Then feel the compressor and find out if the compressor is hot. If it is hot and the coil is dirty/dusty I would say it was going off on high head pressure/temperature. Clean the coil and let the unit sit off for a while and then try running it. If it is cool then it may have an issue with the refrigerant or other things like maybe start componenets.
Mar 27, 2014 | True GDM-12 Refrigerator Commercial
Model GSI-26 suddenly stopped cooling
It sounds like your compressor is having a hard time starting. Take your model number to an appliance parts store and ask for a compressor start relay. It plugs directly into your compressor and is easily replaced. Remember to unplug the refer first.
Dec 17, 2012 | Frigidaire Refrigerators
A/c has full freon but the compressor clutch wont engage. i have found that the plug going into the compressor is not getting any power. what could be the problem?
COULD BE THE LOW PRESSURE SWITCH ON THE RECIEVER /DRIER CK FOR POWER THERE IF HAS 12 VOLTS ONE SIDE JUMPER TERMINALS AT SWITCH COMPRESSOR SHOULD RUN . IF JUMPER GETS HOT LOOK FOR SHORT TO GROUND IN COMP/COIL CIRCUIT OR SHORTED COIL .
HOPE THIS HELPS
Aug 10, 2010 | 1997 Ford Crown Victoria
Compressor runs only a few seconds then clicks off
The compressor is going bad, check your owners manual for warranty information or look here http://b2b.frigidaire.com/support/manuals.asp if you cant find the manual. Some units have up to 7 years on the sealed system (the compressor, cooling coils, and hot coils).
Jan 30, 2010 | Refrigerators
Found the unit circulator fan running but not cool in the freezer or fresh food compartment. I unplugged and replugged and the compressor started running shortly. I checked the frost-free feature already...
The compressor CAN run and still be defective. It's like having a car engine with a bad cylinder-it loses compression and therefore loses power. Unfortunately, this is indicitive of Frigidaire refrigerators. If the compressor will try and start, maybe for a few seconds, and then shut off, you may have a defective start relay.
Jul 30, 2009 | Frigidaire FRT17G4B Top Freezer...
DOOR JAM BETWEEN FREEZER AND FRIDGE IS GETTING HOT
This usually means that your condenser fan has stopped. That's the fan outisde (under or in back of) the fridge. It should be running whenever the compressor runs. Heavy accumulation of dust or anything that obstructs airflow could also cause it. But the most likely culprit is the fan.
Nov 05, 2008 | Frigidaire Refrigerators
Constantly running
If the thermistor sensor for the temperature control is going out that could cause the compressor the think it needs to keep running to cool the unit. The fan near the compressor should run only when the compressor runs. If the fan is running and the compressor isn't then you likely have a compressor start device problem or the overload is tripping from high heat, etc. That would make the compressor run (or try to) every minute or two if not just run continuously. Make sure all the coils under the unit are clean of fuzzy's and hair, etc. by doing a good vac. clean on them also. The compressor can be slightly warm to the touch but shouldn't be so hot that it is hard to keep you r hands on it for long. If it's around 130 degrees F, then it may be the start device problem and is in an overheat condition.
Dec 09, 2006 | Roper RT21AKXKQ Top Freezer Refrigerator
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
144 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
