Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
Can not power up monitor
Ed, I just bought a new LCD Monitor.  L2210NW model.  The instruction manuel does not give instructions on how to power up the monitor.  Can you give me some help. Thank you Fred
  • 3,051 Answers
Hi there
you have a couple of options you can find the website of the manufacture of the monitor and they should have a troubleshooting section or in your manual there may be a number that u can call.. my new dell monitor i had to hold the power button in for 30 seconds
Posted on Mar 09, 2009
L2210NW does not turn on
There are one or two capacitors that are open in the power supply, they often show a bulge at top showing they are leaking.
May 07, 2012 | Westinghouse Electric L2210NW Monitor
Greetings! We are using IBM E74 model CRT Monitor, The monitor was dead, No power, no display How can i rectify that? please give me the instruction
Jun 11, 2011 | IBM E74 17" CRT Monitor
Describe your best resolution for model L2210NW Problem; the letters are blurry and the stuff on screen is so big..
1680 x 1050 should look the crispest with the most on the screen. Hope this helps =] Please rate!
Mar 04, 2011 | Westinghouse Electric L2210NW Monitor
Display issues, need driver dowload, where can I find it? Model: L2210NW
Westinghouse products are known to have many issues. The only option is to get it fixed from
Westinghouse service center.
May 19, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
My Westinghouse lcd monitor L2210NW does not turn on everytime. Right now for three days - despite rebooting, etc - I cannot get the screen to display and there are no lights. Power is going to it. Ideas?
anngallant, Yes, I, and all the other "LCD CCFL back-lit monitor" repair guru's on fixya already know what your L2210NW suffers from. You will do a DIY repair to the monitor's SMPS/inverter circuit board, or contract out the work to a qualified electronics technician, or do a cash+trade for a refurbished unit, or trade-in for new monitor. Do NOT attempt the first two "IDEAS" without an extensive speed reading session of the FIXYA profiles of "budmrtn", "buddymc", and other tech's that deal with the very common single cause of black or black and blank screen lcd failure and what it takes to repair/refurbish them! You can also (FYI) do the YOUTUBE thing and view some of the longer and more informative video clips on "LCD monitor disassembly" , "LCD monitor repair". Some are pretty good! Good luck with your unit, whatever route you take. I'm 12fixlouie on fixya.
Feb 17, 2010 | Westinghouse Electric L2210NW Monitor
Out of focus 22"LCD Monitor
Since you have your reciept you should be able to get a refund repair or replacement from Best Buy.
If it's past the warrenty date then you could ring a repair shop and get a quote on the cost to fix but would probobly cost more than the monitor is worth
Feb 06, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
Can't remove cover of Westinghouse LCM-22w2 monitor
Hey Ed,
I hope I can help, It doesn't open from the back, it opens from the front.... carefully! There are four support screws, which hold the LCD screen to the desk stand,after removing all the support screws (4) on the back under the support stand cover.(which pull up to remove) (Remember! the whole case and face frame is plastic, so take your time). Work to separate the black face frame around the LCD from the silver case. Its held together by small plastic clips on the face frame to the wall on the LCD case. Start at one of the corners and slowly pry the face frame and silver case apart. (separate it inch by inch, work your way around the case carefully. If one corner doesn't give, go to another side.
Putting back together works reverse, the face frame and the case snap back together, Carefully! And replace screws (4).
P.S. I have three LCD models from Westinghouse, LCM-22w2, L2210NW and the L1916HW. They all open the same way.
Dec 07, 2008 | Westinghouse 22" Widescreen LCD Flat Panel...
Monitor loses power randomly.
It could be the solder conections that go to the board . Open the init and check the solder thaere first. Go here for instructional videos on opening the unit.
May 22, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Lcd monitor problem
use the economical approach replace the ac power supply if this doesnt work replace your monitor with a new one.
Because its probably the same amount of cost to fix it as it is to get a new monitor.
Jan 01, 2008 | HP Pavilion F1703 17" LCD Monitor
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
315 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
