Question about Cobra 18 Wx St Ii Mobile Cb Radio
Radio sticks in TX mode after I let go of the button on the mic
I changed mics, tried three different antennas, sent it back to Cobra twice and they say there is nothing wrong with it. I used my swr meter on it and went to a professional and had him check the swr's.
  • williamhicks Mar 17, 2009
    Do you have a part number so I can replace it myself. I paid $69.00 dor this unit new and I already spend $36.00 in shipping it back to Cobra Corp. twice.
  • williamhicks Apr 06, 2009
    Do you have the relay part number so I can tell Cobra. The unit is still under a 2 year warranty. Or I can change it myself.
    williamhickstein@yahoo.com
    Genius:
  • 1,139 Answers
Hello williamhicks,
There is a relay in side of the cb that might be sticking. The problem is that this situation might be environmental. You say that you sent it back to Cobra twice for repairs. I think that the place you are sending it to differs enough environmentally so that the problem does not manifest itself. You can test this by exposing the unit to different temperatures, to determine if the internal relay is sensitive to variations in temperatures.
If you do find that the relay has become tempurature sensitive, you can order the part from Cobra, or strangly enough from Radio Shack, since they do carry the same part just by a different part.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Mar 11, 2009
  • Henry McKelvey
    Henry McKelvey Apr 07, 2009
    I believe it's a solid state relay, It's been awhile, I tried looking for my copy of the schematic but I could not find it. Call Cobra, give them the model number and they should be able to find the part number for you.
    I hope this helps,
    Thank you,
    Shuttle83
No rx or tx driver and 1969 are ok pa works
Check mic wires inside connector. Try a different mic from another cobra radio.
Dec 25, 2011 | Cobra 29 LTD CB Radio
When Mic is keyed TX illuminates but no green nand red bars light up. Anh help appreciated.
Get a SWR-PWR meter to put on the line between the radio and antenna to see what it is doing.
Feb 16, 2011 | Cobra 19 DX IV CB Radio
The radio does not transmitt but I can here other radios
CHECK SWR's, and check for loose coax connectors and try a different microphone. new stock mic's $6.99 max price here in temple, TX, and rk56 noise cancelling mics$38.99 Max here too Temple, TX.
Feb 13, 2011 | Cobra 29 LTD CB Radio
I have a cobra 19 plus cb that someone gave to me and I finially got a cb antenna for it. I hooked it up and the channel numbers light up and the red tx lights up when I press the mic button but no sound...
Hi danimal, my name is John. Welcome to FixYa. Try a different mic. that fits the radio. Then if you have further problem, let me know. Thanks for choosing FixYa. Happy holidays........John
Dec 16, 2010 | Cobra 19 Ultra II CB Radio
My radio recieves ok but only whistles when i key the mike is this a major fix?
Do you have talkback installed? It my be too loud and causing feed back. Back the mic gain down if so.
Could also be improper mic wiring. If you use a mic that is wired for a different radio, it could just cause a hum, buzz or squeal.
Another thing that can cause a hum, buzz or squeal is a faulty volume and or squelch knob depending on the radio.
  • Turn down or disable talk back.
  • If you cannot turn off or disable talk back, lower mic gain.
  • Try a different mic that you know is wired for cobra.
  • Play with volume and squelch knobs while TX and see if it stops at all. If it does replace knob.
Oct 12, 2010 | Cobra 150 GTL DX Base CB Radio
Cobra 18 wx st receives-wont transmit
Take the cover off, flip it over solder side up, check all solder joints for cracks, cold solder joints, check the safety diode where it comes in the radio, before I go further, can you pick up the weather channel?...Does the PA work?...need to check the pre-driver and finals,audio chip, hook up the power meter using a coax three foot jumper from the output from radio to the input of the watt meter, then the antenna, first check the SWR, on the scale on the meter to cal/swr mode,adjust it to spec, then while still keyed down turn the dial to SWR,if it is the safe range your ok,then turn the Dial to 10 or 20 watt scale and key the mic. Does it have any wattage? If not suspect the finals, they are located on the back rail, if it does have RF then its the audio chip, its located on the right side rail facing you,closest to you.remove it and replace it with same ....hope this helps....
May 21, 2010 | Cobra 18 WX ST 40-Channels Base CB Radio
I have a Cobra 25 ltd classic that when you key the mic it will tx for about three seconds and then stop, if you unkey the mic for about 12 seconds it will reset itself and then tx again, it will repeat...
I assume the the antenna is a good match and it receives well. An over heating final can be the culprit, can be caused by poor heat transfer from the final and the protection circuit will kick in. The final may be damaged and replacement is needed but without looking at the radio my self, these are only best ideas. If I can be of more help email me at.... poikaa@yahoo.com
Feb 26, 2010 | Cobra Radio Communications
I have an old 23 channel cobra 29. it lights up but does nothing
It is not a dirt issue, the final transmitter is bad. This is caused normaly from a bad antenna or wire going to the antenna. These can be replaced. There is one big on near the back of the radio, 3 prong black transistor connected to a piece of metal (heat sink), unsolder the old one and obtain an exact replacement. (perhaps radio shack or repair shop), solder the new one in. This will sometimes be screwed to the heatsink on the very back of the board connected to the rear of the radio.
Before reconnecting the radio have the antenna checked for damage.
Sep 20, 2009 | Cobra 29 LTD CB Radio
"squeak" when transmitting
Make sure you have a good ground for the radio and antenna. How long is the antenna coax if a little to long and you have extra what did you do with it coil it if so uncoil it and lay it out try it. If no luck I would shorten the coax and recheck your SWR.
Jun 22, 2007 | Midland 1001Z 40-Channels Base CB Radio
Cobra 18 Wx St Ii Mobile Cb Radio Logo
111 people viewed this question
Top Cobra Boating Experts
RFburns
Level 1 Expert
Electro Med Services...
Are you a Cobra Boating Expert? Answer questions, earn points and help others
